Anyone running the OME 'lift'?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slowboater, Jan 30, 2020.
  1. Jan 30, 2020 at 3:11 PM
    slowboater
    slowboater [OP] Well-Known Member
    I just got a quote for:
    2887 Coils
    1017 Struts
    And EL096R Leaf Springs
    20091 Struts
    Of course bushings, u-bolts, etc. And, alignment.​
    About $2600 installed out the door.
    This is my daily driver and I don't have a garage to work on it so I need to hire someone else to do the work. I'm in Vancouver but this quote was from near Seattle. I'm down here a lot so that's not a problem.
    I'm running a GFC and a a small drawer. So, maybe 500#'s constant weight.
    I've always thought the suspension (even pre-GFC) was a bit soft. And now with the GFC those Forest Service Roads make me hit the bump stops.
    2500 bucks seems like a reasonable price. I don't really want a 'lift' just need better handling on the dirt - especially given my extra weight.
    I'm running 265/70/17's.
    Thoughts?
  2. Jan 30, 2020 at 3:20 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Recommend to add extend brake lines (I put in +2”) and 2-3 degree shims in the rear. Hitting the bump stops? I also added Timbren bumpstops.
  3. Jan 30, 2020 at 3:26 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yep this.
    $2600 for knowing it is done right (if the shop is trustworthy) and having it done ASAP sounds like a fine deal.
    I paid about $1250 for my 1st gen OME suspension with extras (extended brake lines, shims, etc) and installed it over two days without rushing, but I had a garage at the time.
    This was after going through Death Valley and riding my bump stops the entire time.
  4. Jan 30, 2020 at 3:53 PM
    slowboater
    Yep. I was thinking to add bump stops too.
    Are brake lines and shims needed? I don't think there's going to be a noticeable lift...
