anyone use a manual pipe bender?
Discussion in 'Off-Topic Discussion' started by Zombie Runner, Feb 24, 2011.
  1. Feb 24, 2011 at 10:30 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  2. Feb 24, 2011 at 10:34 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Keep in mind that this is a pipe bender so the Dies won't work for bending tubing. Tubing is measured by the OD (outer diameter) while piping is measured by ID (inner diameter)
    If you are going to go that route, go with one of the benders from harbor freight that uses a hydraulic bottle jack rather than the one you posted which requires strength.
    Either way you will need to rig up some custom tubing dies.
  3. Feb 24, 2011 at 10:38 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    I see electricians use those to bend small pipes I dunno if they can bend the size of tube you would need for a bumper. like the above said hit up harbor freight, might not be the best stuff but its somthing
  4. Feb 24, 2011 at 10:44 AM
    tacoman85
    tacoman85 Active Member
    Erik
    Fort Worth, TX
    White TRD PRO
    Use one almost every day in my job good luck bending pipe for a bumper by hand. Its possible depending on the diameter and the wall thickness the biggest we bend by hand is 3/4" steel line or 1" aluminum...but you got to put some balls on it...
  5. Feb 24, 2011 at 10:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Turns out I may have access to a mandrel bending machine. I just asked on my facebook and a buddy's dad has one. Im gonna try and see if he will make a few bends for me.
    Thanks for the replies guys
  6. Feb 24, 2011 at 10:49 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    buying a bender and all your material, then the time it takes you to build it, you could probably be pretty close in costs...
    g by some local fab shops and see what they can do it for
  7. Feb 24, 2011 at 10:52 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    nvm saw in your OTHER thread you only need a few bends, so just get the shop to bend the metal... it's gona be a lot cheaper than buying a bender
  8. Feb 24, 2011 at 10:58 AM
    tacoman85
    Erik
    Fort Worth, TX
    White TRD PRO
    good find. learn how to use it tho since you have access to one... its not hard at all, just takes a couple of tries when your first getting familiar with it. It will save you a shit ton of money.. I glad I have the job I have now in the AF I'm sure you know what Sheet metal is if you where ammo...:D
  9. Feb 24, 2011 at 11:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    haha yup, I knew a fellow taco owner that was in sheet metal shop in Mt. home.
    hopefully Ill get a chance to use this mandrel bender in the next couple weeks.
  10. Feb 24, 2011 at 12:58 PM
    tacoman85
    Erik
    Fort Worth, TX
    White TRD PRO
    you know some one named O'connel he was there... the only one I know...
