Anyone used this electronic "rust proofing" method?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lightfire, Dec 18, 2009.
  1. Dec 18, 2009 at 7:14 PM
    lightfire
    lightfire [OP] Well-Known Member
  2. Dec 18, 2009 at 7:23 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    i don't use it but before anyone says it a bunch of shit. metal ships use the same method to prevent rust, we call it cathodics at work it basically sends an electric current into the water to prevent different parts of the hull from becoming anodes and cathodes basically the pos+ and neg- side of a battery and turns the whole hull into a cathode so it does not rust.
  3. Dec 18, 2009 at 7:43 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    It works for buildings, ships, and bridges but is a crock for a vehicle. Why? The vehicle isn't grounded due to riding on 4 rubber tires. Google it.
    The body man at my FIL garage had a late model Silverado in the paint booth this past spring with a unit installed. We get allot of road salt here so the owner thought it would be a fine investment. The only place that wasn't rusted on the chassis was where he removed the control box - the rest of the frame was like a ships anchor.
  4. Dec 19, 2009 at 12:38 PM
    lightfire
    My thoughts as well. Now if you dragged a chain behind you grounding the chassis...:eek:
