Anyone using a Viair 400P Portable 12 volt compressor to air tires up tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DESportTRD, Jan 14, 2018.
  1. Jan 14, 2018 at 8:11 AM
    DESportTRD
    DESportTRD [OP] Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    What are the likes and dislikes on using a Viair 400P Portable 12 volt air compressor to air up tires after coming off the beach or after off roading from 20 lbs. to 32 lbs.?
    I am tire of using State Park compressors and hoses that have defective valve chucks.
  2. Jan 14, 2018 at 8:18 AM
    Dcwn.45
    Dcwn.45 Well-Known Member
    David
    2013 dcsb trd off road
    OME suspension ARB front bumper Warn M8000
    I have one
    Works great
    I don’t like the screw on chuck, I’m going to adapt it to a conventional quick release hose and chuck
    I wired a heavy duty electric plug to my front bumper so I don’t have to open the hood and connect to the battery
    Greg.Brakes.Tacos likes this.
  3. Jan 14, 2018 at 8:20 AM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    It is amazing, easy to use, and fast. The screw-on chuck takes a few seconds longer, but is much more efficient than a clamp-on chuck.
  4. Jan 14, 2018 at 8:23 AM
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    I had one and it worked well enough... figure a couple minutes a tire with the stock-ish tire size. 3-4 minutes to air up 33's from low teen pressures when doing any serious rock work. The problem with them is the duty cycle... go out with a group and you usually end up airing up everyones tires and the compressor gets HOT and exceeds the duty cycle quickly... Doesn't take long to kill a compressor that way.
    I ended up finding a GREAT deal on one of these 12V Puma compressors last year and have been using it exclusively on my wheeling trips. It airs up twice as fast as even the biggest Viairs--it fills a 265/75s from 15 to 35 in about 45 seconds. The air tank also means you can use it to run air tools in short bursts or use it to knock the dust off all your gear after a long day in the dirt. The 100% duty cycle also means you can run it constantly without fear of burning it up. The only downfall of it is that it's a somewhat on the large/heavy side but it's not completely unwieldy, especially considering how well it works. I think eventually I will end up tearing mine apart and stashing the tank and compressor motor somewhere under the hood or frame and just add a quick disconnect somewhere.
    https://www.amazon.com/PD1006-Puma-Volt-Compressor-Gallon/dp/B00W1TNO6U
    '16goingon'17 likes this.
  5. Jan 14, 2018 at 8:26 AM
    DESportTRD
    Thanks for the info. The Viair 400P I am looking at has a 33% duty cycle, will run for 20 minutes, and had a "snap-on" air chuck. Maybe a newer model? Found a new one on internet for $143.99 out of Nebraska. Think I am going to pull the trigger.
  6. Jan 14, 2018 at 8:39 AM
    Old_Guy
    Old_Guy Well-Known Member
    2017 Tacoma Off Road DCSB
    I haven't had mine long, but it has worked great the few times I have used it. I'm trying to figure out a quick connect like dcwn.45 did. But I want to also keep the battery clamps in case I need to use it on another vehicle.
    Edit: I got the 450p not the 400p. It cost more but has 100% duty cycle.
  7. Jan 14, 2018 at 9:11 AM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    2nd the pump 12v...totally awesome setup!
  8. Jan 14, 2018 at 9:13 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What type of plug did you install, do you have a link? Thanks!
  9. Jan 14, 2018 at 10:25 AM
    loastad
    loastad Well-Known Member
    Denver
    2016 AC OR Tancoma
    5.29s, CBI T3 f and r bumpers, ADS suspension, AT Habitat, various small mods
    I'm also curious.
  10. Jan 14, 2018 at 10:40 AM
    DESportTRD
    We all are....so please post. Thanks
  11. Jan 14, 2018 at 11:46 AM
    Dcwn.45
    David
    I don’t have a pic but it is a heavy duty 2 wire plug for a trolling motor that I found at Fleet Farm
    I ran it from the battery to my front bumper by the winch and cut off the battery clips and put the other half on the compressor side so I can plug it in easily without opening the hood
  12. Oct 8, 2019 at 7:11 AM
    2barevo
    2barevo Member
    sorry, a little off topic. I just purchased one of these and the previous owner had it custom wired. Would you mind sending me a pic of how the wires are oriented under the control box cover?
