Anyone w/ a 4 cyl Prerunner and a ARB Locker?
Discussion in '4 Cylinder' started by PSJ, Aug 25, 2011.
  1. Aug 25, 2011 at 10:36 PM
    PSJ
    PSJ [OP] Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Just wondered if anyone beat me to the punch? I have not seen a 4 cyl "prerunner" with a rear locker yet? Show me I am wrong!
  2. Aug 26, 2011 at 9:29 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    me, i got the arb in the diff just havent hooked up the compressor yet
  3. Aug 26, 2011 at 9:35 AM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
  4. Aug 26, 2011 at 9:39 AM
    08pretaco
    az
    were you the one that was helping me out figuring out the wiring and placement for the compressor like 6 months back?
    mind posting up a picture of where you mounted the compressor? did you get the H.O. one?
  5. Aug 26, 2011 at 9:41 AM
    08pretaco
    az
    maybe, it was someone lol i really gotta get on that. been geared since what like february haha
  6. Aug 26, 2011 at 9:49 AM
    MartyMcfly
    Rob
    Pahrump Nevada
    This is the only pic I have with me. Compressor is behind the battery. It's the ckma12. High Output with like 33% duty cycle. I can fill up 2 tires straight from 12psi to 35 psi in less than 10 minutes, wait 5 minutes, then do the other 2. Pic doesn't show the tire inflation kit adapter, I added it later on. I'll have to dig up some more pics when I get home.
  7. Aug 26, 2011 at 9:50 AM
    08pretaco
    az
    well on the first day i was on my way to BAP. and the gears were used so dont tell me i should have broken the gears in properly cause well they were already broken in haha
  8. Aug 26, 2011 at 9:51 AM
    08pretaco
    az
    perfect! thank you, thats the only place i could figure out to mount it. did you have any problems mounting because the fender surface is curved and the compressor base is flat
  9. Aug 26, 2011 at 10:15 AM
    MartyMcfly
    Rob
    Pahrump Nevada
    Wasn't that big of a deal actually. the wheel-well just kinda flattened out a bit for the plate when you tighten down the bolts. It's already fairly flat around that spot anyway.
    To mount it, I figured out where I needed the plate and made sure there would be enough room for the compressor and that it wouldn't run into the fuse box. Then I marked through the four holes with a pen, and drilled the fender well.
    The most difficult part was getting the bolts through the compressor, and the plate and the fender-well, because you have to thread all four bolts through the compressor and the plate before mounting it. Since the compressor can be rotated clockwise or counter clockwise on the mounting plate, the bolts where dangling loose and hard to match up to the four holes simultaneously. What I did was, thread all four through the compressor and the plate, then kinda threaded them one at a time through the fender-well, put a washer and nut on the other end to hold it, and then moved on to the next bolt.
  10. Aug 26, 2011 at 10:16 AM
    08pretaco
    az
    thanks for the tips!
  11. Aug 26, 2011 at 6:58 PM
    PSJ
    Sebastian Inlet
    So only two guys thus far. I am sure this will be a small club. McFly, how do you like it? Does it work well with our 5 spd? Do you use it often? Do you feel like you can go just about anywhere you want?
  12. Aug 26, 2011 at 7:41 PM
    PSJ
    Sebastian Inlet
    Did ARB offer a template or suggest where to mount the compressor? I have been told they recommend where to mount the compressors and all the extras?
  13. Aug 26, 2011 at 11:10 PM
    MartyMcfly
    Rob
    Pahrump Nevada
    I love the locker. The locker and the regear are the best mods I've ever done to a truck. I use the locker at Pismo and a few times in my dirt driveway which is kinda steep in places, and I can tell you this: I don't know how anyone can move around in the dunes at Pismo in a prerunner without a locker. It makes a difference. Don't get the wrong impression. It's not 4wd, but it does make a big difference. In my 4x4 taco (r.i.p.) I felt like i could go anywhere. In this, I feel like I can survive in places that I couldn't before without it, but it still couldn't tackle stuff my 4x4 could, no way.
    The locker also helps with acceleration in the dirt or sand, and that's good when you need to get up to speed in order to get over dunes or get past sketchy patches of super soft sand. When at Pismo,, the locker stays on the entire time. I don't turn it off. The compressor is also nice to have for refilling the tires when I'm done.
    If you install a locker, do a regear at the same time to save $$$
  14. Aug 26, 2011 at 11:15 PM
    MartyMcfly
    Rob
    Pahrump Nevada
    The only thing I can remember from the instructions is they wanted you to mount it on a flat horizontal surface out of the reach of dirt and debris and water/moisture.
    I don't know about "extras". I have the tire inflation kit if that's what you mean. I keep that in the cab of the truck and bring it out when I need it.
    The air hose to the locker you want to run it along the frame, tucked up out of the way. Running it along the brake lines is suggested by ARB. Try to run it smoothly so there are no sudden bends in the line.
    ARB includes thou rough instructions with the locker and compressor.
