Anyone Wired the Factory Aux Jack into an Aftermarket HU
Discussion in 'Audio & Video' started by 95SLE, Sep 2, 2011.
  1. Sep 2, 2011 at 6:39 PM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Has anyone wired the stock AUX jack into an aftermarket HU?
    The AUX connector, N2, shows 5 wires with the sheild of the cable being one lead. I usually use 3 leads to provide connectivity for a stero connection, so I am confused by the stock 4th wire.
  2. Sep 2, 2011 at 10:27 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Was actually going to do this sunday. Just got a nee headunit and wanting to keep the stock input. Shouldn't be too hard right? Was thinking I could just use a normal 3.5mm aux cable and cut it and wire it up to the aux harness.
  3. Sep 3, 2011 at 3:25 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I am going to do the same with a new HU install. The wiring diagram looks like the AUX jack wires go right up to the radio connecting jack with no connection points in between. I think all I have to do is pull the pins out of the radio connecting jack and attach them to a 3.5mm plug.
    Sounds simple enough but I know how that goes.
  4. Sep 3, 2011 at 8:27 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah, Its a single blue plug for the aux. Should be able to cut It, then wire up the 3.5. I'll try it today or tomorrow. Need to wire up everything else first.
  5. Sep 3, 2011 at 11:07 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Josh:
    Thank you for the help. Might as well use the factory jack if I can.
    I hope to start my install next weekend.
  6. Sep 7, 2011 at 9:27 AM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    Check out the text file in the first post of this thread. It has the pin outs for the factory aux cable.
    Good luck!
  7. Sep 7, 2011 at 10:22 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    THX guys. This should be enough to get me through. I do have the factory Toyota wiring manual.
    FWIW it seems the regular radio and the JBL radio uses the same wiring connector for the AUX plug.
  8. Sep 7, 2011 at 10:32 AM
    fbconvert
    Brian
    Seacoast, NH
    This is correct...
