anyone with a 2012 4by4 v-6 auto trans Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silverfoxvtx, Aug 5, 2012.
  1. Aug 5, 2012 at 4:03 PM
    silverfoxvtx
    silverfoxvtx [OP] Active Member
    I have a 2012 4 door 4by4 with a auto trans.....with a shifting problem.........1st to second is rough second to third is ok third to 4th is ok but 4th to 5 clunks in half the time....when it does it feels like a u-joint or something in the rear-end...taken it back 3 times dealer is saying its the way i am driving it.....its a auto put it in drive and mash on it.......taking it to a different dealer anyone else having this problem.....i have 5k miles on it.....Chuck
  2. Aug 5, 2012 at 4:06 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    I would really question the "driving style" problem, and ask them to in detail explain how that is the problem, come back here so we can point out the bs in there return to you.
    5k on it shouldnt be any kind of failure but we have all seen it worse, I would go back and refuse to take it back until its problem is identified.
    Driving style is not an adequate answer.
  3. Aug 5, 2012 at 4:30 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    One thing to consider is reflash the transmission computer. Disconnect both battery terminals and let it set for 10mins then reconnect. The computers "learn" your driving habits and adjust the shift patterns. They also have some strange shift/downshift points themselves.
  4. Aug 5, 2012 at 4:35 PM
    Tacoma Mike
    Southern Maine
    It sure is on some instances.
    Had more than one that wouldn't shift correctly.
    All sorts of different parameters from shifting like your saying as well as not shifting into second till 30 miles an hour.
    All came back to how the driver was beating the snot out of the vehicle in a couple of instances as well as running the trans as a stick in others.
    The ecu has adaptive memory and learns this and tries to adapt.
    Have also seen an issue or two right off the lot.
    What should be done is a ecu memory reset and then the tech needs to drive the truck easy (like grandma) for 15 or 20 min in stop and go as well as easy acc to speed. Let it cool off to cold and drive it normally again to see if the condition has improved.
    Any shift concern like harsh shift or irregular response throws red flag up to me and before I go to far I road test it and if I think it may benefit I do a reset.
    A lot of the time it resolves the issue.
    Not saying this will resolve the issue but it should be tried.
    Just because you may not like the answer doesn't mean it's wrong.
    Sorry to disappoint you but not all of us throw BS....
  5. Aug 5, 2012 at 4:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I thought there was a TSB for reflashing the computer on the '12's. [​IMG]
  6. Aug 5, 2012 at 4:44 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Telling him its his driving style and sending him on his way IS a BS answer. Thats why I told him NO that is not an adequate answer, explaining how his driving habits is causing an adaptive system to not be able to correctly learn it, offer to reset the ECU and teach him how to allow the ECU to learn is the CORRECT NON BS answer. so back to what I said earlier.
    ITs a BS answer go back and ask specific questions.
  7. Aug 5, 2012 at 4:51 PM
    Tacoma Mike
    Southern Maine
    Maybe he did and maybe they did.hehenehe
  8. Aug 5, 2012 at 4:54 PM
    Larry
    Larry CARL
    CARL
    hard to break :D
  9. Aug 5, 2012 at 4:59 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    On paper document the time, date and person you are dealing with. If after several attempts you are still not satisfied contact your State Attorney General office and open a file with them (It is free to you, compliments of your taxes) Then sit back and wait for the fireworks as the Big Dogs rip them a new asshole. [​IMG]
  10. Aug 5, 2012 at 6:21 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    My 2012 is a little rough between 1st and 2nd but thats it. I've heard others say the same thing.
  11. Aug 5, 2012 at 9:23 PM
    silverfoxvtx
    The truck had 70 miles on it when I got it....Some one went and got it in a different town....Maybe he ran the shit out of it....I am 59 a old man and a truck driver for 35 years I drive like a old lady....the more info you all give me is good when i take it back to the dealer...
  12. Aug 6, 2012 at 5:29 AM
    Tacoma Mike
    Southern Maine
    Just ask them if the would please do a reset. These trans are not what anyone is use to. I did a reset on mine when I got it.
    They downshift on decel with your foot off. If it shifts and you take your foot off it can do some weird stuff.
    Myself I don't like software in these transmissions.
    Mine shifts harsh (old days normal) sometimes.
    I bought mine over a year ago and I'm still getting use to it.
    Until they come out with a software update to smooth things out not to much we can do on our end.
    They all act a little different.
