anyone with rear fox shocks
Discussion in 'Suspension' started by markmatters, Jan 19, 2012.
  1. Jan 19, 2012 at 4:16 PM
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    i was curious about these shocks...with the info pprovided...the dude said they would indeed fit a tacoma with the stem conversion and 3 to 4 inch rear lift...anyone have experience with these and is the price is right? he said pretty much new...
    http://yuma.craigslist.org/pts/2808325958.html
  2. Jan 19, 2012 at 5:25 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I can set you up with a set of ICON 2" Fully Rebuildable Rear shocks for your truck for $291.000 for the pair.
    About Icon's new Aluminum 2.0 VS Series Rear Shocks:
    These aluminum 2.0 VS Series shocks feature polyurethane mounting bushings for direct OE fitment. Nitrogen charged mono-tube design with internal or remote reservoirs. 6063- T831 hard anodized honed aluminum cylinder tubing for superb heat dissipation, excellent corrosion resistance and high tech appearance. Premium grade 7WT shock oil for high performance in extreme temperatures. One piece linear/digressive piston design for unsurpassed performance and ride quality on- and off-road. 100% rebuildable 6061 aluminum dual stage seal head with high temperature seals and o-rings. 5/8” polished nitro steel shaft does not flake and pit as easy as the industry standard chrome shafts. 6061 aluminum rod ends insure strength and durability, 90 day warranty.
  3. Jan 19, 2012 at 5:46 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    i want to see if these are compatible with my truck with 3 to 4 inch lift...for $180...not a bad price...ill definately keep your offer in mind...thanks!
  4. Jan 19, 2012 at 11:21 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    For 3-4" those icons prob won't work!
  5. Jan 19, 2012 at 11:27 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    How about the Fox on the Craigslist link? 8" travel? Know anything about those?
    I'm guessing 8 inch would be stock travel?
  6. Jan 19, 2012 at 11:36 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    umm those are air shocks.
  7. Jan 19, 2012 at 11:38 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Please explain...dude said they would fit my rear...is he just as clueless as I am?
  8. Jan 19, 2012 at 11:46 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Air shocks are more used for like buggy's, they can replace springs because they are meant to hold weight, since you already have leaf springs in the rear it would be redundant, you need the kind dan posted, you don't have to go with icons if you don't want though, thats preference.
  9. Jan 19, 2012 at 11:54 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    ahhh, I see. I guess he's just trying to make the sell. Thanks for the explanation.
  10. Jan 20, 2012 at 12:12 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    No problem :D
  11. Jan 20, 2012 at 1:45 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    What rear lift do you have? Best thing to do is measure without a shock mounted and buy accordingly. I'd say 10-12" for a 3" lift????
  12. Jan 20, 2012 at 2:56 AM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Well, after some homework...and hoping the Maxtrac spindles come through...they will be roughly 3.75" according to Maxtrac..not a full 4". For the time being, I plan on running the 5100's at either .85 giving me roughly 4.5" or at 1.75 giving me 5.5" up front until i can afford some coilovers...I currently have them set at 2.5" and have a rear 2" AAL..and i'm butt high. Being used to sand and all the prerunners in the area, i like my nose high. I have all pro's gathering dust in my garage until I have the spindles and install them at the same time....so whatever setup I end up going with I want to be .5-1" higher up front...if I have to add a .5 or 1" block...so be it...so I figured atleast use some decent shocks in the rear..Pro comp makes a resi mx6 shock...heard anything positive about those? I'm just trying to figure this stuff out...Fkn essay. Tips are welcomed.
  13. Jan 20, 2012 at 6:37 AM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    Here are my 10" Fox 2.0 resi's installed that I got from ORW. The 10" Fox fit the 3" All Pro Expedition Leaf pack (actually around 4") perfectly I only had about .25"-.50" left out of the shock at full suspension drop below the factory mount. If you go higher than that on your rear leafs you will need to go 11" Fox or else you will destroy your shocks if doing full drop on offroad. A 12" shock would be too much.
  14. Jan 20, 2012 at 7:17 AM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    im leaning towards spindle's 3.75" plus .85" plus watever the all pros give it...fox or bils or even the pro comp mx6 resis for 4" rears..dependind on the price...would the 5160s 10" be anydifferent?
  15. Jan 20, 2012 at 7:21 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Up travel is more important anyways. And 12" version of what you have on expos leaves only 3" of up travel. Lol
  16. Jan 20, 2012 at 7:21 AM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    you think if i go with lets say a block i would need 11s?
  17. Jan 20, 2012 at 7:29 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    :DTempting
    Sorry to thread jack.:cool:
  18. Jan 20, 2012 at 7:30 AM
    PLC721
    Patrick
    Chandler, Az
    No still too long of a shock unless you have like a 6" leaf pack
  19. Jan 20, 2012 at 7:33 AM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    ^ im talking abt allpro and maybe a 1/2"block..wat would be ur input on that?
  20. Jan 20, 2012 at 7:34 AM
    PLC721
    Patrick
    Chandler, Az
    The Oakley trd shock would be fine. 10" travel fox RR
