Anything Pizza
Discussion in 'Food Talk' started by la0d0g, Apr 29, 2017.
  1. Jan 4, 2025 at 2:43 PM
    #2921
    MGMDesertTaco
    I did a counter test with yeast, water and sugar. I think I got a bad batch of Fleischmann's. :boom:Going to try red star's rapid rise next time.
  2. Jan 4, 2025 at 8:36 PM
    #2922
    la0d0g
    la0d0g [OP] Its 4 o’clock somewhere
    running for the hills
    For crawling not hauling
    Bummer! There's always next time, pizza time!
    w.adventures and wilcam47 like this.
  3. Jan 5, 2025 at 6:38 AM
    #2923
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    This happened to me once
    Now I just proof the yeast, every time - even if it is from a known good batch
    It is worth it to me to know [in case of failure] and I can kinda see how active it is given my kitchen temp
  4. Jan 5, 2025 at 10:29 AM
    #2924
    amyracecar
    Virginia Applejack
    SouthEast USA
    What temp water did you use?
    I google it and it says 100deg F
    But use water that is in the mid 80's - no higher than 90 . . .
    And yea I temp the water every time with an instant read
    @Kwikvette had pointed out long ago that too hot was also not the best so I started dialing it back and found that the yeast I have [a 1# brick of whatever was cheapest on Amazon] seems to like the mid 80s = most active; when I used hotter water, it seemed less active and cold water slows everything way down
  5. Jan 5, 2025 at 11:03 AM
    #2925
    Kwikvette
    Fresno County
    4 run, 2 don't
    Too cold and yeast won't even activate, too hot and you will kill it.
  6. Jan 5, 2025 at 2:35 PM
    #2926
    MGMDesertTaco
    The Fleischmann's yeast was made with water about 90 degrees. (1/8 t yeast, 3/4 cup water, 1/8 t sugar) Water could have been too cold, I dunno.
    The King Arthur 00 Pizza flour (Neapolitan style) calls for
    1/8 t yeast
    2 cups of flour
    1 1/4 t salt
    1/2 t sugar
    3/4 lukewarm water
    The yeast ratio seems low, but from what I've read that's normal for this brand and type of flour. I usually do 1/2 teaspoon of yeast per cup of flour.
    Yesterday, I bought some Red Star quick rise yeast in the 4oz jar. I tried a few test batches with different water temps 90, 100, 120ish, and 130. Each time I added 1 teaspoon cane sugar and 1 teaspoon yeast to 3/4 cup of water. I let them sit for 5-10 minutes and still got the same results with little to no yeast reaction. :confused:
    Maybe the red star was bad too?
    Nevertheless, in the mix it went and the dough rested on the counter in a bowl overnight for 12 hours. :playball:
    It rose a pinch, but not much. I went a head and baked it at 475 for 8-10 minutes. It was okay, but the dough was a little chewy.
    The recipe says it should have yielded 2 10" pizza doughs. I got 1 dough out of the entire batch that made a 10 inch.
    I'm going to try a few other recipes with different flour and likely another new jar of yeast. :stirthepot:
  7. Jan 5, 2025 at 2:59 PM
    #2927
    amyracecar
    Virginia Applejack
    SouthEast USA
    I have found that water in the mid/low 80s works the best for me
    So you had two batches of bad yeast?
    If that was the case, something else may be wrong
    What water are you using?
    Do you have city water?
    Aka water with chlorine in it?
    Had the dough risen properly, you would have gotten the 2 pizzas out of it
    It should have 2x overnight [or at least been substantially larger]
    MGMDesertTaco[QUOTED] likes this.
  8. Jan 5, 2025 at 3:31 PM
    #2928
    Kwikvette
    Fresno County
    4 run, 2 don't
    90-95 degrees is my go to.
    Interesting theory on the chlorine part, I mean chlorine levels are normally really low in general where it would take awhile for it to be effective.
    I say this as a fishkeeper since chlorine + aquarium = bad news
    But I never noticed chlorine being an issue (or chloramine, my city uses chlorine) and I do know it exists in our water as I use it for my fish tank and need to treat it
    Bad yeast could definitely be the case? I too use Fleischmann's and whenever it isn't used, I store it in the freezer. Our chef taught us that it can indeed go bad even if kept in a cool dry place and the freezer was the best way to preserve it.
    nobescare and MGMDesertTaco like this.
  9. Jan 5, 2025 at 4:03 PM
    #2929
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Something is not right. Maybe one batch would be bad but not 2.
    Water might be too chlorinated
  10. Jan 7, 2025 at 1:51 PM
    #2930
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    A lot of colder states add more chlorine to the water system in the winter time to change the freezing temps. I've had issues with it in the past.
  11. Jan 13, 2025 at 6:10 AM
    #2931
    wilcam47
    Will
    Bourbon state
  12. Jan 13, 2025 at 6:46 AM
    #2932
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Hmm. I use city water, hard, chlorinated, summer and winter, I add (rapid rise) alongside salt, I never measure water temps - it's either kinda room ish or warmer, maybe hotter, maybe it's chilled. I am NOT an exact science with that. I got 2 bricks (1lb each I think) of Fleischmans Instant Dry yeast at BJs (Costco) a little over a year ago. The second brick was just opened, after the first brick was left at the in laws. They're stored in a jar in the fridge after being opened. I know sourdough bacteria die in the freezer, but I also know bakers who keep their yeast in the freezer and it's fine.
    I never had an issue with the yeast rising.
    Try packets before you go all in on another jar. ("So costly", my 2lbs that has lasted me over a year and looks to last me another maybe 18 months was about 5.50$)
    Counter rise for 12 hours and NOTHING?
    1/8 tsp yeast = 0.6g
    2 cups flour = ~240g
    I think you are not using enough yeast.
    https://www.kingarthurbaking.com/recipes/pizza-crust-recipe
    I don't do much pizza dough, to be honest, but my breads I do - are around 1-2% yeast in bakers math. That recipe you listed is 0.25%, just seems way low.
    This is the recipe you are using:
    https://www.kingarthurbaking.com/recipes/neapolitan-style-pizza-crust-recipe
    There's a note to try it for a shorter-rise version with more yeast. Maybe give that a whack?
    For a shorter-rise version of this recipe, proceed as follows: Increase the yeast to 1/2 teaspoon. After mixing the ingredients into a rough but cohesive dough, cover and let rest for 20 to 30 minutes. After this rest, grasp one edge of the dough, pull it up and out, and tuck it into the center. Give the bowl a quarter turn and repeat three more times, until you’ve gone all the way around. Cover and allow the dough to rise at room temperature for at least 8 hours; this can be done before leaving for work. When you're ready to bake pizza, follow the recipe above starting with preheating the oven and then dividing the dough in half.
    More than anything I am so intrigued by this :rofl:
  13. Jan 13, 2025 at 3:01 PM
    #2933
    MGMDesertTaco
    I don't know what the issue is. There were a handful of reviews claiming that recipe on the bag was a disaster. King Arthur claims that ratio works. (not for me obviously)
    Every jar and packet of Fleischmann's yeast I've tried recently at various temps and ratios has been a failure.
    I've tried switching to Brita purified water and Red Star rapid rise instant yeast from the jar. A little more luck, but still not the rise I would expect.
    I'll try more yeast next time.
    nobescare likes this.
  14. Jan 19, 2025 at 3:03 PM
    #2934
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Bought a Pizza oven and made some pretty tasty crispy crust pies. Knocked them out one after another. Enjoy my friends.
  15. Jan 25, 2025 at 9:09 AM
    #2935
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    Show off that new oven!
    dand and wilcam47 like this.
  16. Jan 25, 2025 at 9:29 AM
    #2936
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Me as a kid, high school yearbook shot...:cool:
    Thats not a UFO above my head, its in my blood...
    Pizzas look great guys,
    I try to avoid as on a stay jacked health journey but its a weakness...
  17. Jan 26, 2025 at 5:00 AM
    #2937
    Mully
    CA
    Nothing fancy, just the Cuisinart counter top.
    Got it with 33% off, works pretty good, you just have to turn the pizza 1 or 2 times. Got better with it as we went along. Family had alot of fun and laughs with it.
  18. Jan 26, 2025 at 7:14 AM
    #2938
    amyracecar
    Virginia Applejack
    SouthEast USA
    Pan Pizza!!! @GarlicFarts
    Sausage
    Made the dough with sourdough starter and yeast because I am impatient
    Crust got all nice and crispy
    Super yummy - froze the rest; reheat @ 350 in my toaster oven for 15 and I have homemade pizza on the spot!
  19. Jan 26, 2025 at 7:48 AM
    #2939
    slater
    San Diego
    Slater, step away from the pizza thread, & go to the fucking gym....o_O
  20. Jan 26, 2025 at 9:50 AM
    #2940
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
