Anything Pizza
Discussion in 'Food Talk' started by la0d0g, Apr 29, 2017.
  1. Mar 2, 2018 at 5:01 PM
    #721
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Wish i had 2 olives for eyes now..
  2. Mar 2, 2018 at 6:16 PM
    #722
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I just checked something, the side cooker box I just put on my smoker fits a pizza stone almost perfectly. I may need to trim a little piece off the stone but not much to close the lid all the way, its open just a bit.
  3. Mar 3, 2018 at 12:28 PM
    #723
    81shark
    81shark Well-Known Member
    Dough be rising. Going to make a thin crisp crust with green olives and shrooms.
    DubfromGA, la0d0g[OP] and TacomaUSA like this.
  4. Mar 3, 2018 at 12:46 PM
    #724
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Dough also be rising over here!
    DubfromGA, la0d0g[OP] and 81shark like this.
  5. Mar 3, 2018 at 1:27 PM
    #725
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Have you checked to see if you can calibrate your oven? Also, oven temps are just an average. At 350 desired temp, your oven will swing 4-5 times before it is somewhat settled. Normal operation will swing like a pendulum and get as hot as 385/390, then drop down a similar amount below your target temp, like 305/310, rinse and repeat. This usually happens 3-4 times but can happen more.
    They’re not regulated, so they’re either hot or cold, it can’t self regulate to maintain a temperature setting, hence the pendulum of temps.
    wilcam47[QUOTED] likes this.
  6. Mar 3, 2018 at 1:36 PM
    #726
    81shark
    ^^ i'm going to bake my pie with the igrill in the oven.
  7. Mar 3, 2018 at 1:39 PM
    #727
    PNWskibum
    PNWskibum Well-Known Member
    2018 TRD off-road Access cab,blue
    LED interior lights,LED lows/highs,window rain guards
  8. Mar 3, 2018 at 2:04 PM
    #728
    wilcam47
    Will
    Bourbon state
    I havent checked that but a 5 degree swing I can deal with, a 25 degree off is way too much. Might get a new one this summer,
  9. Mar 3, 2018 at 2:11 PM
    #729
    T4RFTMFW
    25-35 is normal swing range for all manufacturers.
    I’d check into calibration on your oven if the settled temp range is low, a new one isn’t necessarily a fix in and of itself.
    FWIW, I’m an appliance repair technician.
  10. Mar 3, 2018 at 2:16 PM
    #730
    81shark
  11. Mar 3, 2018 at 2:24 PM
    #731
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Dough proofing today, will cold ferment overnight and then into pies tomorrow.
  12. Mar 3, 2018 at 3:08 PM
    #732
    wilcam47
    Will
    Bourbon state
    so for instance, if I set our oven for 350 I think it should get to 350+ or - 5, so 345 to 355. If we set it to 350 it barely reads 325 on a separate oven thermometer...thats just on an empty oven, but if you put something in there to cook/bake it drops even more. I would think that is too much...
    DubfromGA likes this.
  13. Mar 3, 2018 at 4:01 PM
    #733
    T4RFTMFW
    Normal.
    I verify temp. using a DVMM with a temp unit and ignore the first full temp swing, record the next 5-6 before I can get a trustworthy reading. Not before then can you really condemn an issue. That’s how they’re manufactured, how they’re programmed to work, etc. Most can be calibrated, like I said, so you can usually decrease or increase temps by 25-35 degrees on either side, so if your oven sees 350* and the actual temp is more or less, you can dial it in to where YOU want it. It’s a pretty common complaint, actually.
  14. Mar 3, 2018 at 5:31 PM
    #734
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    Nice view!
    PNWskibum[QUOTED] likes this.
  15. Mar 4, 2018 at 7:20 AM
    #735
    Polymerhead
    Missouri
    Built...
    Baked!
  16. Mar 4, 2018 at 1:14 PM
    #736
    wilcam47
    Will
    Bourbon state
    I had the back off of it but there wasnt anything that looked like it could be adjusted. just a couple sensors and access to the temp gauge.
  17. Mar 4, 2018 at 1:21 PM
    #737
    T4RFTMFW
    PM and the model number and manufacturer. I’ll see if I can find any technical info.
  18. Mar 4, 2018 at 1:31 PM
    #738
    wilcam47
    Will
    Bourbon state
    Pm sent thanks!
  19. Mar 4, 2018 at 4:05 PM
    #739
    la0d0g
    la0d0g [OP] Its 4 o’clock somewhere
    running for the hills
    For crawling not hauling
    That looks great!
    Dough recipe?
    :drool:
  20. Mar 4, 2018 at 7:20 PM
    #740
    Polymerhead
    Missouri
    Standard Neapolitan dough. 20 oz flour, 13 oz water, some salt and yeast. Mix to combine, let proof for 8 hours or so and then into the fridge for a while. 2 to 3 days seems to be best. I only let these proof overnight.
