Anything Pizza
Discussion in 'Food Talk' started by la0d0g, Apr 29, 2017.
  1. Jan 4, 2020 at 8:06 AM
    #1361
    la0d0g
    la0d0g [OP] Its 4 o’clock somewhere
    running for the hills
    For crawling not hauling
    French bread pizza last night. This was the wifes. I made mine on garlic bread because I'm a piggy :anonymous:
  2. Jan 5, 2020 at 8:37 PM
    #1362
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Whats the secret to crispy crust and soft interior? I made diominoes knockoff recipe but it wasnt crispy outside.
  3. Jan 5, 2020 at 8:45 PM
    #1363
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    I don’t eat Dominos barely ever but some of them use oil in the bottom of a pan to almost fry the bottom of the crust.
    Others use high heat and a stone to crisp it up.
    truchador and wilcam47[QUOTED] like this.
  4. Jan 5, 2020 at 8:46 PM
    #1364
    wilcam47
    Will
    Bourbon state
    Yeah even the top has a crisp crust also
  5. Jan 5, 2020 at 8:55 PM
    #1365
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I saw a cooking show recently where they discussed this. It had to do with moisture content. The moisture expands as it evaporates and makes the crust puff up.
    Maybe your dough was too moist?
    Or, maybe brush the crust with olive oil or melted butter before baking.:notsure:
    It works for garlic bread.
    wilcam47[QUOTED] likes this.
  6. Jan 5, 2020 at 9:07 PM
    #1366
    wilcam47
    Will
    Bourbon state
    Dunno still learning;)
    https://lingeralittle.com/pizza-dough-by-hand/
    Thatbassguy[QUOTED] likes this.
  7. Jan 5, 2020 at 9:10 PM
    #1367
    Thatbassguy
    James
  8. Jan 5, 2020 at 9:16 PM
    #1368
    wilcam47
    Will
    Bourbon state
    I love pizza
    NV.ENGINERD and truchador like this.
  9. Jan 5, 2020 at 9:51 PM
    #1369
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    In the oven I've had the best luck getting crispy pizzas using a pizza screen and high heat (525F). I feel like the open mesh helps the crust lose moisture and cook more quickly and thoroughly. Convection also helps if your oven has that setting.
  10. Jan 5, 2020 at 9:56 PM
    #1370
    wilcam47
    Will
    Bourbon state
    What kind of flour you using?
  11. Jan 5, 2020 at 10:07 PM
    #1371
    CrustyTaco
    Todd
    Louisville, KY
    Great River All Purpose from Costco. Bread flour will work fine too. I don't think your issue is too much moisture in the dough, your recipe has a 41.6% hydration rate, my normal recipe is 58%. Here's a pepperoni pizza I made last week that came out nicely.
  12. Jan 5, 2020 at 10:35 PM
    #1372
    wilcam47
    Will
    Bourbon state
    What recipe do you use? That looks great!
  13. Jan 5, 2020 at 10:49 PM
    #1373
    CrustyTaco
    Todd
    Louisville, KY
    This is the recipe I normally use. Did a bunch of searching on the Forno Bravo forums to get a feel for the ingredient ranges
    500g flour
    290ml water
    5g dry yeast
    13g salt
    2tbl olive oil
    1 tsp honey (or sugar)
    5g Diastatic Malt Powder (optional, but recommended)
    1.5g garlic powder (optional)
    Add honey, olive oil and yeast to water, then incorporate the dry ingredients. Knead by hand or with a stand mixer for 4-5 minutes or until the dough passes the windowpane test. Recipe makes three 270-280g dough balls. Cold ferment them for at least 2 days, sweet spot is 3-5 days.
    This article improved my pizza making more than anything:
    https://slice.seriouseats.com/2010/09/the-pizza-lab-how-long-should-i-let-my-dough-cold-ferment.html
  14. Jan 6, 2020 at 11:50 AM
    #1374
    wilcam47
    Will
    Bourbon state
    sounds like a good recipe thanks! I have to find some of the malt powder.
    *edit-- ordered
  15. Jan 8, 2020 at 8:57 PM
    #1375
    wilcam47
    Will
    Bourbon state
    You sure these are right measurements? I followed them and the water was lacking.
  16. Jan 9, 2020 at 7:29 AM
    #1376
    CrustyTaco
    Todd
    Louisville, KY
    Yea, I just double checked it. 500 grams of flour and 290 milliliters of water. 58% hydration. Should be equal to about 1 1/4 cups of water, but I use one of these to measure the water:
    The flour should be weighed ideally, but it usually ends up being around 3 rounded cups worth. I make exclusively thin crust pizzas, if you're wanting a thicker crust you might consider bumping the hydration up to 65-70%. Could also just be the differences in flour being used.
    https://pizzaotherbread.wordpress.com/2016/02/28/pizza-dough-hydration-trial/
  17. Jan 9, 2020 at 3:31 PM
    #1377
    wilcam47
    Will
    Bourbon state
    I think my scale was off...:annoyed::goingcrazy::goingcrazy:
  18. Jan 10, 2020 at 6:57 PM
    #1378
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Took like 2 min each lol
    I don’t think I posted the finished peel on this thread yet:
  19. Jan 10, 2020 at 7:15 PM
    #1379
    wilcam47
    Will
    Bourbon state
    Well that other batch ratios were off but it tastes good considering i messed it up! So started again, but i figured out what happened last time was, the scale was sitting on something soft so it made it have inaccurate readings! The second batch should be good monday
    CrustyTaco[QUOTED] likes this.
  20. Jan 10, 2020 at 10:19 PM
    #1380
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    Nice. Pizzas look like they turned out (blazing heat helps) and that is one nice peel.
    wilcam47 likes this.
