Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Feb 5, 2014 at 7:19 AM
    #2461
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
  2. Feb 5, 2014 at 7:19 AM
    #2462
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    +1 for the sickest Radio Flyer mod on the planet!
  3. Feb 5, 2014 at 8:51 AM
    #2463
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I run one of these for general cutting and they're awesome saws.
    It's a non-lubricated cold saw so the metal barely heats during cutting so you can touch it after a cut and little burring, no sparks or dust comes out, just metal chips (they're pretty loud though). Blades last well when properly treated and can be resharpened several times to get the most out of the cost of a blade.
    http://www.amazon.com/Evolution-Pow...8&qid=1391619027&sr=1-6&keywords=evolution+14
  4. Feb 5, 2014 at 9:09 AM
    #2464
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    The only problem that I did not like about the metal blade chops is the fact that if you dont tighten the material down all the way every time you can bind the blade and chip a tooth. The cut is nice but composite blades are more forgiving.
  5. Feb 5, 2014 at 9:09 AM
    #2465
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You should be fine with a chop saw for home use they are loud and messy unless you get a steel blade. Cold saws are not really for mass production they are great for short runs and custom stuff but for production you want a hydraulic feed band saw. I have a Ellis 1600 in my shop and it's great I can do short production runs of nine 2"x 2" tubes at once just start it ans walk away wile it cuts it really speeds up the production when you have to cut 1000+ slider legs in a day :eek:.
    This is what I think of when I think of a production saw and something like it will be my next saw :cool:
    http://metal.baileighindustrial.com/automatic-bandsaw-bs-20a
  6. Feb 5, 2014 at 9:11 AM
    #2466
    Phil Dammit
    Your Mom
    Tempe, Arizona
    yeah I convinced the last multi-million dollar residential builder to buy a 12" horizontal. Before I showed up they were cutting 20' sticks of 6-12" 1/4 flat with horses and Milwaukee metal skill saws.... fucking shop was a joke.
  7. Feb 5, 2014 at 9:19 AM
    #2467
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    Sounds like my current shop. An aluminum shop with no shear, a 4 foot brake press, and a panel saw thats out of square.
  8. Feb 5, 2014 at 10:38 AM
    #2468
    YOTA LOVER
    NH
    Pretty much what I'm thinking.
    Duly noted.
    Thanks for the feedback guys!
  9. Feb 5, 2014 at 11:08 AM
    #2469
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    For tube, you could also use a porta-band with a Swag stand if you don't have much to cut. A chop saw with steel blade would be better. The composite blades throw a lot of sparks so you need to watch where that goes. They also leave a lot of slag on the table-which makes it useless for anything else.
  10. Feb 5, 2014 at 11:27 AM
    #2470
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I feel your pain brother, we had a plasma but it couldn cut through anything greater then 12ga and they didn like the look of a plasma edge. :facepalm: Some quality fabricators in that shop, but because of their ancestral back ground they did not think they had the ability to speak up about the tools they needed to do the work properly and efficiently so they milk the system and the higher ups fuck them over. I rolled in and turned that place on it's back and started shifting shit around before I finally said fuck it and moved on to bigger and better things, for the most part.
  11. Feb 5, 2014 at 11:38 AM
    #2471
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    A horizontal band saw is going to be my next investment.. Give it some serious thought.
    Built a backstop for my abrasive chop saw that I can use to repeatedly cut and notch tube; but honestly the dust, noise and general inaccuracy of the saw typically adds more time to the job. Blade deflection/kerf will change as they get worn down, everything in your shop is going to get coated with dust - and the noise is insane.
    Check Craigslist for used horizontal band saws.. I've seen quite a few on there that were reasonably priced.
    Got bored.. Built a welding cart. All out of scrap - that tube is DOM.. it's an odd size, and I didn't think I'd ever have a usage for it. Made my tank tabs too low.. Plasma cutter is freakin' awesome!
  12. Feb 5, 2014 at 12:01 PM
    #2472
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Consider a portable band saw. I do a lot of fanning, and that saw is just as important as the welder, and they don't take up a lot of space.
  13. Feb 5, 2014 at 12:16 PM
    #2473
    YOTA LOVER
    NH
    Thanks! I'll definitely have to check them out.
  14. Feb 5, 2014 at 4:17 PM
    #2474
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Laid my first beads today. Was told they are pretty good for my first time. Need to work on seed a little and staying in a nice steady movement. [​IMG] [​IMG]. [​IMG]. [​IMG]. [​IMG]
  15. Feb 5, 2014 at 7:29 PM
    #2475
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    slow down, try doing small e or c with the arc and wheeve it back an fourth... also check out welding tips and tricks.com he offers a lot of good info, happy welding...
  16. Feb 6, 2014 at 6:27 AM
    #2476
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ^^ yeah I know I need to slow down. I was practicing the C and I was mostly just going back and forth side to side on it.
  17. Feb 6, 2014 at 6:48 AM
    #2477
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Rest the torch right in the crevasse to help you stay uniform when doing C's. I end up doing circles for a simple filet weld. If your puddle starts pooling up when you slow down slow your wire speed down a bit so you are not feeding so much material in. What machine are you using?
  18. Feb 6, 2014 at 6:54 AM
    #2478
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    Ok. Thanks for tips. And idk it was a miller, it was a bigger mechine not something really small. It is not mine, one of my cousins owns a welding and fabbercating shop and I was down there messing around. I'm looking at starting welding school in the fall so he was letting me play around some. I want to say temp was set at like 230 but could be wrong.
  19. Feb 6, 2014 at 8:15 AM
    #2479
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    What's this fabbercating shop you speak of?
  20. Feb 6, 2014 at 1:32 PM
    #2480
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
