Anytime Backup Cam wiring question (rear only with ch4x4 spst switch)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by COS_TACO, May 11, 2020.
  1. May 11, 2020 at 2:37 PM
    COS_TACO
    COS_TACO [OP] Well-Known Member
    Colorado
    2018 SR5 ACLB V6 4x4
    Creating a new post for this question as after a lot of searching, I found search results mostly took me to: posts including front cameras; posts with different coloring wires on the harness or switches; etc... So I hope this helps me as well as others in the future.
    --I have the ABC harness ABC-28 (for rear cam only; with "orange" and "red" wires).
    --I have a ch4x4 spst switch (with green, red1, red2, & black wires).
    --I simply want the rear camera to display when I push the switch to "on," but also I'd still like the switch illuminated when the switch is "off."
    1. Can someone confirm (or offer a fix if I have something wrong) for my plan below?
    2. I don't need to add any inline fuses, correct?
    SWITCH:
    green ----------> to red wire from ABC harness
    red1 ----------> to orange wire from ABC harness
    red2 ----------> to red wire from ABC harness
    black ----------> to ground anywhere behind the dash
  2. May 12, 2020 at 1:54 PM
    COS_TACO
    Colorado
    Bumps for help please :thumbsup:
  3. May 12, 2020 at 4:54 PM
    caribe makaira
    Caribbean, Puerto Rico
    Terrible choice of switch...
  4. May 12, 2020 at 5:06 PM
    COS_TACO
    Colorado
    I appreciate (and totally welcome) constructive criticism... but the "constructive" part seems to be lacking :confused:
    Can you offer more insight? Are they prone to failure? Is there a better/more popular switch choice for a simple rear camera push button switch? I appreciate any additional feedback.
    To anyone else that can help, still looking for advice about the wiring part. Thanks in advance.
  5. May 12, 2020 at 5:53 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Absolutely terrible description on the ABC page for wiring, but yes that looks right. (That is If by ‘load‘ they actually mean ‘trigger’). You’re better off illuminating the switch (red 2) from the dash light circuit though.
  6. May 12, 2020 at 6:01 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I agree. Otherwise this switch light won't dim to levels matching the other buttons (and dash lights.)
  7. May 12, 2020 at 6:16 PM
    COS_TACO
    Colorado
    Thanks @mutely and @Gen3TacomaOBX for the tips! Is it common to tap into that via the other nearby switches (and the wiring going to them?)
  8. May 12, 2020 at 7:24 PM
    Gen3TacomaOBX
    S
    You're welcome. Yes, I used a Posi-tap splice connector to make it simple.
    This post may be of help Tapping the Dash Lights Circuit
    COS_TACO[QUOTED][OP] likes this.
  9. May 12, 2020 at 7:49 PM
    COS_TACO
    Colorado
    Thanks again @Gen3TacomaOBX, and thanks for pointing me to that article about tapping into dimmer wiring. Much appreciated!
    Gen3TacomaOBX likes this.
  10. May 18, 2020 at 4:04 PM
    COS_TACO
    Colorado
    Following up to complete this thread - as I got my switch working with illumination and dimming working properly...
    In the taco pdf manual that I found on this site, I found the wiring for the Parking Sonar Switch. Pins 4 and 5 are ILL- and ILL+.
    Here is how I wired things up:
    Here is the back of my Parking Sonar Switch:
    -- so in my case pin4 (ill-) is the tan wire, pin5 (ill+) is the turquoise wire (not sure if those are the "official" wire colors but thats what they look like)
    -- I used Post-Tap connectors to tap into these wires
    Ta-da:
    --works like a charm
    --illumination and dimming also work, woot!
  11. May 18, 2020 at 5:41 PM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Just in case anyone is wondering, for my 2017 TRD sport 4x4 Toyota also used the Tan wire to power/ illuminate the switches on the driver side console.
    Here is a recent video I posted installing the 2nd red wire. Photos of the wire are at the end. At this point I feel like all the switches are illuminated with the Tan colored wire. Thanks for posting this. It makes future installs a bit easier.
    https://youtu.be/U1UFbys9Pvo
  12. Apr 1, 2021 at 10:33 PM
    Tarnold77
    Tarnold77 Member
    Tom
    2021 Tacoma Army Green OR
    @COS_TACO Thank you for posting the diagram. Super helpful! I searched the forums and the ABC website and was having a hard finding good information on wiring just the backup camera to a SPST switch. Always appreciate it when folks circle back to share their successes and close the loop. Thanks man!
    COS_TACO[OP] likes this.
