Anytime foglight mod for 2006 taco.I'm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rdbtaco06, Mar 21, 2017.
  1. Mar 21, 2017 at 10:10 AM
    Rdbtaco06
    Rdbtaco06 [OP] Well-Known Member
    Russ
    2006 Toyota Tacoma 4 X 4
    I have a 2006 taco
    I have the fogs that come on only when low beams on. I want the fogs to come on independent of the headlights and only when the key is turned on in ignition. I think my fog stock bulbs were 55 watts. I want to put in the 6 in jumper wire attached to the fog relay prong run it to the green power wire to splice into. What would be the recommended gauge wire to use? What about if I get LED bulbs? Can I still use same gauge? Yes or no? Does it matter the much if gauge is on the thicker side?
  2. Mar 21, 2017 at 10:12 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Don't put LED bulbs in halogen housings, light scatters, you see poorly and blind other drivers.
    There are a gazillion threads here on these topics. Search please. I would find them for you, but I added my own fogs and wired them straight off the battery
