Anytime Front and Rear Camera Mod
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Logistics91, Apr 3, 2018.
  1. Aug 8, 2018 at 8:05 AM
    #701
    SCUBADIVINGJOE
    SCUBADIVINGJOE Well-Known Member
    Mark
    2017 Toyota Tacoma
    Seat covers, LED Low Beams, LED FOG Lamp, Dash Cover, Pop and Lock Tailgate, Tuffy Security Console Insert, Steel Nerf Bars I want to add Hood QuickLIFT ELITE Gas Struts and High Beam LEDs
    I want JJ to know I like his Mod Better and want it.
    SilverJack likes this.
  2. Aug 8, 2018 at 8:46 AM
    #702
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
    Tacomaworld needs you, and your camera.
    JJ won't you please come back?
    (To the tune of "Harry Truman")
    9TRDTCO likes this.
  3. Aug 8, 2018 at 9:16 AM
    #703
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Pissed at myself for not getting it when it was available :frusty:
  4. Aug 8, 2018 at 10:09 AM
    #704
    SCUBADIVINGJOE
    Mark
    2017 Toyota Tacoma
    Same Here:facepalm::frusty:
  5. Aug 8, 2018 at 10:48 AM
    #705
    SilverJack
    SilverJack no one
    :spending:
  6. Aug 8, 2018 at 12:43 PM
    #706
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Sounds like @mesojdm
  7. Aug 11, 2018 at 3:11 PM
    #707
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    jbcanes likes this.
  8. Aug 11, 2018 at 4:13 PM
    #708
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    Trying to install this and when I got it hooked up the dash lights no longer work. I also have several lights on the dash saying check the brakes, abs and others.
    Has anyone else had these problems and know what could be the problem?
    I unplugged the connections behind the radio and those dash warnings are no longer there and the dash lights now work again.
    Any help is greatly appreciated.
  9. Aug 11, 2018 at 5:38 PM
    #709
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    Possible something wired wrong. What did you do with the black wire coming off the 28 pin harness?
  10. Aug 11, 2018 at 6:07 PM
    #710
    COSD
    Denver Metro
    2017 MGM DCSB OR
    I attached the black wire from the 28 pin to the green wire on the rear camera as the instructions said.
    While trouble shooting this problem it has something to do with the 28 pin because the light and dash messages all come on only when I have it plug up.
    Still can't get it to work right. Rear camera would come on though but had all though messages that wouldn't go away and the dash lights wouldn't work. And the front camera would only come on if I had the rear camera on.
  11. Aug 11, 2018 at 6:17 PM
    #711
    jbcanes
    Justin
    Tampa, FL
    Only other thing might be the diodes in the wrong directions, possibly? Maybe
  12. Aug 11, 2018 at 6:22 PM
    #712
    COSD
    Denver Metro
    2017 MGM DCSB OR
    What are and where are the diodes?
    I hooked everything up per the instructions.
  13. Aug 11, 2018 at 6:29 PM
    #713
    jbcanes
    Justin
    Tampa, FL
    There are to small diodes that should have come with the kit. They need to be wired in line for Each switch to the red wire from 28 pin. The diodes need to have the dark band facing away from the switch when wiring in. Link below is similar to what they looked like. Mine where in with one of the switches attached to paper with tape.
    https://www.addicore.com/1N4148-diode-p/232.htm
  14. Aug 11, 2018 at 6:33 PM
    #714
    COSD
    Denver Metro
    2017 MGM DCSB OR
    Didn't get any of those. And what you're talking about with them is the switch function right and not the other problems I having right?
  15. Aug 11, 2018 at 6:37 PM
    #715
    jbcanes
    Justin
    Tampa, FL
    Yes switch function for sure. Put could help with the other issues. Not sure I am not an expert at wiring. The instructions should say the style diode if I remember. You can get them from Amazon.
  16. Aug 11, 2018 at 6:39 PM
    #716
    jbcanes
    Justin
    Tampa, FL
    1N4007 diodes
  17. Aug 11, 2018 at 6:41 PM
    #717
    jbcanes
    Justin
    Tampa, FL
    In wiring diagram the blue triangles with a line over it are the diodes. The line represents the line on the diode.
  18. Aug 11, 2018 at 6:55 PM
    #718
    COSD
    Denver Metro
    2017 MGM DCSB OR
    @jbcanes thanks a lot for your help and I will have to try that and or some from Amazon.
    :fingerscrossed:
  19. Aug 11, 2018 at 7:00 PM
    #719
    jbcanes
    Justin
    Tampa, FL
    Hope it works for you. I almost missed the diodes when I was doing mine thought they were extra lights for the switches when I was opening the kit up. Read the install instructions a few times and realized that I need those.
    COSD likes this.
  20. Aug 11, 2018 at 10:22 PM
    #720
    Slim_shadowz
    Slim_shadowz Well-Known Member
    17 Sport DCLB MGM 4x2
    Cosd are you using two switches or just one? I think the diodes are only used if you have a single switch .
