Anytime Front and Rear Camera Mod
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Logistics91, Apr 3, 2018.
  1. Sep 24, 2020 at 3:04 PM
    #1521
    JRLYON
    JRLYON Well-Known Member
    Portland, OR
    2020 Cement TRD Off Road DCSB
    KDMaxx Tuned Bilstein 6112/5160 set at 2” w/ 1.5” Icon AAL 2020 TRD Pro Shocks and Struts (no longer installed) 2020 TRD Pro 16" Wheels Goodyear Wrangler Duratrac 265/75/16 tires Alpharex LUXX Series LED Taillights Black/Red (no longer installed) 2020 TRD Pro Taillights TRD Performance Air Intake TRD Performance Exhaust TRD Front Skid Plate Tyger T3 Soft Fold Tonneau Cover TacoGarage Pro Grille w/OEM sensor garnish Taco Garage DSM w/ magnetic phone mount Runnin4Tacos Smoked Amber Grille Lights (CURRENTLY NOT INSTALLED) Runnin4tacos amber grille lights) Runnin4Tacos Lower Control Arm Skid Plates Katzkin Black Leather Interior with red stitching and TRD logo in seat back TRD Pro Shift Knob TRD Oil Cap TRD Radiator cap TRD Off-Road Special Tailgate badge JLT 3.0 Oil Separator Catch Can Demon Brackets w 3/4" red/black Autmatch D-Ring Shackles Black Emblems and Tailgate badge OEM Bed Lights OEM Predator Tube Steps AVS In Channel Window Visors MESO Total Tail Stage 1 MESO Ultimate Map Lights (Dual Color) (CURRENTLY NOT INSTALLED) MESO Ultimate Map Lights (White) MESO Ultimate Dome Light V2 (Dual Color) MESO Chrome Delete Kit Red MESO Customs Red Start/Stop Ring MESO Customs Red 4x4 Select Ring MESO Customs Red Start/Stop Button (Small Letters) MESO Customs V5 Ultimate Turn Signals (Reverse Sequential) MESO Customs TRD Stearing Wheel Emblem cover MESO Customs red door handle chrome delete (CURRENTLY NOT INSTALLED) MESO Customs black door handle chrome delete TVDVinylDecal red door sill protector letters TVDVinylDecal red glovebox letters Redline Tuning Hood Struts Diode Dynamics SS3 Pro Fog Lights (White) (CURRENTLY NOT INSTALLED)Diode Dynamics LED 194 HP5 Map Lights (CURRENTLY NOT INSTALLED) Diode Dynamics LED HP6 29mm Festoon Dome Light Bulb (CURRENTLY NOT INSTALLED) Diode Dynamics LED 28mm Fuse Vanity Bulbs Diode Dynamics LED 194 HP3 License Plate Bulbs Taco Vinyl TRD Grille Badge Black/Red Cupholderhero cupholder/door/pocket rubber liners Front Tinted Windows to match rear OEM tint OEM Tacoma Rubber Bed Mat OEM Tacoma Bed Extender Tacos4Cheap TRD Coin Box JDMCAR Glove Box Organizer Insert JDMCAR Center Console Organizer Insert CeramicPro 9h Lifetime Ceramic coating
    Cut Green wire gets rid of guide lines
    Cut white flips image for front facing cam
    On my natika cam anyway
  2. Sep 24, 2020 at 5:11 PM
    #1522
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
  3. Sep 24, 2020 at 5:16 PM
    #1523
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    On mine the white is the guide/parking lines, cut that one first. I have no need for that. The green one, when I cut it goes from backwards to upside down and backwards. Thought I just wired something off inside the dash.
  4. Sep 24, 2020 at 7:54 PM
    #1524
    JRLYON
    Portland, OR
    Your camera has to be mounted with the metal nipple pointed up and the green wire cut
  5. Sep 24, 2020 at 9:00 PM
    #1525
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    It is. And like I said, if I cut the green wire the image flips upside down.
  6. Sep 24, 2020 at 11:15 PM
    #1526
    JRLYON
    Portland, OR
    Something defective for sure then
  7. Sep 25, 2020 at 5:29 AM
    #1527
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Can you post a picture of the camera mounted on the grille?
    DSRamsey13 likes this.
  8. Sep 29, 2020 at 4:18 PM
    #1528
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    So just an update on the wiring for the anytime front camera install on a 2020 Tacoma DCSB...
    Connect all the matching color wires from the harnesses to the switch (blue to blue, gray to gray, red to red, orange to orange, black to black, green to green). Ground all the black wires. The red wire from the front camera goes to the green wires on the switch and the black is also grounded.
    Everything is working great thanks to a little help from Brian at anytime.
    Hopefully this will help anyone else with a 2020 having issues with the front and rear switch showing either just the front or just the rear the entire time. That was my issue before getting the updates for the wiring from Brian.
  9. Nov 4, 2020 at 10:30 AM
    #1529
    RuckusTRDPro
    RuckusTRDPro Well-Known Member
    Jeffrey
    2019 Tacoma TRD Pro-Voodoo Blue
    Anywhere to order just the rear kit? Don’t plan on running a front camera. Seems like none of them sit flush
  10. Nov 4, 2020 at 2:15 PM
    #1530
    AtomicRyan
    AtomicRyan Well-Known Member
    So my RCA cable that goes between the harness and the camera is different than the instructional video. On one side it has a small connector that attaches to the camera along with two long red and black wires (power and ground). On the other side, it has the RCA termination that goes to the harness along with a short red wire. Can I hook this short red wire up to the green wires in the harness and then on the other end, clip the red wire and then take the black wire to ground? Will that power the camera? I was planning on running an add-a-fuse, but I would much rather power it from the harness.
  11. Nov 11, 2020 at 4:46 PM
    #1531
    Mt133677
    SoCal
    2020 DCSB TRD OR
    All the things
    ya the red wire from the rca goes to the greens. I didn’t put a fuse and so far so good.
  12. Nov 11, 2020 at 10:24 PM
    #1532
    casenator
    casenator Member
    2018 Tacoma trd off road dcsb
    Are the rear camera kits still available? Looks like the order link website is expired.
  13. Nov 30, 2020 at 6:55 AM
    #1533
    Hypoxic12
    Hypoxic12 Member
    Oklahoma
    2020 Tacoma TRD Off Road DCSB
    Remote tailgate lock, anytime camera, rough country tonneau, bed mat, LED interior lights, all weather floor mats
    Did you get your camera installed, or get an answer for the red and black wires? I just received my kit with what sounds like the same wiring and have the same concern.
  14. Nov 30, 2020 at 7:01 AM
    #1534
    AtomicRyan
    I spliced the red wire into the green power wire of the harness and ran the black to a ground... Worked perfectly.
  15. Nov 30, 2020 at 7:21 AM
    #1535
    Hypoxic12
    Hypoxic12 Member
    Oklahoma
    Is this the wire you had?
    gJE5MM9YRTC1cXX7NK_7EO0PVWOyUxcO8DHz0a6T_f0e42be3883e14a929bd18105504e4bc84dfb727.jpg
  16. Nov 30, 2020 at 8:18 AM
    #1536
    AtomicRyan
    Sorry man... That image is way too small for me to see.
  17. Nov 30, 2020 at 8:38 AM
    #1537
    Hypoxic12
    Hypoxic12 Member
    Oklahoma
  18. Nov 30, 2020 at 8:40 AM
    #1538
    AtomicRyan
    Yep... That looks like mine.
  19. Nov 30, 2020 at 7:16 PM
    #1539
    Hypoxic12
    Hypoxic12 Member
    Oklahoma
    Got my anytime camera put in today and is working as advertised. Thanks for help AtomicRyan
  20. Nov 30, 2020 at 7:31 PM
    #1540
    AtomicRyan
    It's a really functional mod... Glad you got it worked out!
