Anytime Rear Camera Mod for 2nd Gen Tacomas
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Logistics91, Feb 24, 2018.
  1. Feb 24, 2018 at 1:40 PM
    Logistics91
    Logistics91 [OP] Well-Known Member
    JJ
    2017 Quicksand Tacoma TRD OR
    Tacoma World,
    Just as the title says! Anytime Rear Camera for the 2nd Gen Tacomas 2009-2015! The mod will work on both the rear view mirror and head unit cameras and is very easy to install. Just follow step by step instructions! I personally use mine (3rd Gen) ALL the time. I tow from time to time and love having a way to check trailer connections and cargo while driving. I also love being able to watch my tow/recovery strap become taught while pulling/recovering a buddy out of a hole. I also use it to make sure I pull far enough into the garage/parking spots. Your use may vary.
    This kit "tricks" the rear view mirror or head unit backup camera into thinking the vehicle is in reverse at anytime you flip the switch. It can be activated at ANYTIME, or even all the time. This kit is especially awesome because it has the ability to activate the reverse camera without triggering the reverse lights. The reverse camera and lights still work as normal while shifting the vehicle to Reverse.
    Free shipping is included on all kits. The kit takes about 30 minutes to install and you can mount the switch anywhere you would like (may require extending wires in certain circumstances). All you need is the ability cut, strip, and splice some wires (instructions provided) and you're all set! This kit includes a pre-wired harness that is soldered and wrapped in heat shrink. This is NOT a "plug" and play kit. You WILL need to cut one wire and splice into a couple more.
    $15 Basic kit Includes - BYOS 'Bring Your Own Switch' Also Compatible with Switch Pros SP8100+ and SPODs: Click Here to Order
    -Step by step installation guide
    -1x Inline "Y" pre-wired harness
    -1x Wiring diagram and step by step full color installation instructions.
    $50 OEM STYLE Kit includes: Click Here to Order
    -Basic kit with a provided OEM style "REAR CAMERA" illuminated push button switch. All switches are black with white lettering. Illumination is standard Blue, but also available in White, Red, and Green. Other colors are made to order and will take extra time. The switch is pre-wired, soldered, and wrapped in heat shrink with 2' of additional lead wires. Long enough to reach the cubbyhole on the left side of the steering wheel. This switch will fit inside the "blank" spots. No trimming required to fit. SPECIFY WHETHER YOU HAVE A REAR VIEW MIRROR OR HEAD UNIT CAMERA AND WHERE YOU ARE MOUNTING THIS SWITCH; CENTER STACK AREA OR CUBBYHOLE AREA ON DRIVERS LEFT. There are two sizes/shapes of the OEM Style Switches. Center stack switches may take a little longer to ship.
    Each kit is tested for functionality with a multi-meter before shipping. A full color installation guide is included with all kits.
    For those that remember the old kits made by @brendanwebster911 he is an Army buddy and I have taken over the production of these kits from him. Kits are still Veteran designed and assembled.
    To Order: Message me or click the PayPal link below. Be sure to leave shipping address and the the type and color kit wanted.
    PayPal: LOGISTICS91@GMAIL.COM
    3rd Gen Tacoma Thread
    https://www.tacomaworld.com/threads/anytime-rear-camera-its-back.534785/
  2. Feb 24, 2018 at 2:00 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I'm interested. If I was to order the switch for the center part (blanks underneath hvac controls) in white, would there be a wait time?
  3. Feb 24, 2018 at 2:03 PM
    Logistics91
    JJ
    Nuno,
    Slight delay, waiting for center switches to come in. Upon purchase, I could ship you the rest of the kit and ship the kit once it comes in. This way you can have everything wired ahead of time.
    Like the pic with J-Lau. It's impossible for him to take a non-creepy pic. Haha
    Thanks
    JJ
    Cativelense[QUOTED] likes this.
  4. Feb 24, 2018 at 2:06 PM
    Cativelense
    Nuno
    CT
    LOL! He's my guy. I'd wait for it all, no rush. I'll place the order later. On my phone right now.
    Thanks for the quick reply!
    Tatts521 likes this.
  5. Feb 24, 2018 at 2:06 PM
    Logistics91
    JJ
    Anytime man. Thanks for reaching out.
  6. Feb 24, 2018 at 2:09 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Will this work with aftermarket head units
    Fiesta346, kgarrett11 and fatfurious2 like this.
  7. Feb 24, 2018 at 2:10 PM
    Logistics91
    JJ
    Rick,
    As long as you have a stock rear camera now that is functioning with the aftermarket head unit? If so, then yes it will work.
    Thanks
    JJ
  8. Feb 24, 2018 at 2:12 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Sweet I want one with the smaller under console switches please.
    Cativelense likes this.
  9. Feb 24, 2018 at 2:16 PM
    Logistics91
    JJ
    PM Sent
  10. Feb 24, 2018 at 2:47 PM
    Charles135
    Charles135 Well-Known Member
    LA-Orange county
    19 cement trd
    Pictures of harness/wiring assembly?
  11. Feb 24, 2018 at 2:50 PM
    Logistics91
    JJ
  12. Feb 24, 2018 at 3:10 PM
    EatMeImATaco
    EatMeImATaco Well-Known Member
    Portland, Oregon
    2014 DCLB TRD Sport 4x4
    07MAR14 - Husky 3-piece floor liners 07MAR14 - AVS 4-piece in-channel air vents 07MAR14 - Clear Bra 15MAR14 - Extang BlackMax Tonneau (Removed) 11APR14 - MetalTech Rock Sliders 11APR15 - Sport Hiline SnugTop Shell + Sportsmen Package 24JUL17 - CalKing seat covers 02OCT17 - OME 2886 Shocks and Coils, & leaf replacement 04NOV17 - Maglite Mount 18FEB18 - SPOD install 18MAR18 - CKMA12 in Engine Bay 21APR18 - SSO Hybrid Slimline with Smitty X20 10k and Heisse combo bar 13MAY18 - Relentless Pod mounts, Mictuning pod lights 13MAY18 - CB Radio with external PA 03JUN18 - Sleeping platform with drawers and marine carpeting
    So very much interested in this, any chance you are in or near Oregon? I hate PP with a passion unrivaled by the stars.
  13. Feb 24, 2018 at 3:11 PM
    Logistics91
    JJ
    I’m in Arizona. I’ll shoot you a PM, see if we can’t work something out.
  14. Feb 24, 2018 at 3:12 PM
    captn.fat.beard
    captn.fat.beard Well-Known Member
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
  15. Feb 24, 2018 at 3:17 PM
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    Payment sent for BYOS
  16. Feb 24, 2018 at 3:19 PM
    Logistics91
    JJ
    Thanks for your order. Will process and ship ASAP.
    JJ
    Ridgeline001[QUOTED] likes this.
  17. Feb 24, 2018 at 3:27 PM
    EatMeImATaco
    Portland, Oregon
    Just payed for the OEM Left kit in white. Looking forward to getting it!
  18. Feb 24, 2018 at 3:29 PM
    Logistics91
    JJ
    Payment received. Much appreciated D.
    JJ
  19. Feb 24, 2018 at 3:35 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Where in AZ?
  20. Feb 24, 2018 at 3:40 PM
    R242
    R242 I want a dog
    Rick
    Milford, OH
    2019 Sport AC 6spd
    Me me me...pm sent:dancingbacon:
