Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Oct 21, 2018 at 7:54 AM
    #221
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
    So where does the relay pull power from? The radio somewhere? I assume I have to run a power wire from the camera back to the relay, so its not pulling power 100% of the time.
  2. Oct 21, 2018 at 8:45 PM
    #222
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    I connected the red power wire for the relay to the red wire coming off the over ride harness. I did not want my front camera on unless I was watching it.
    All the info is in this threads previous posts. Wiring diagrams, pictures and explanations....:thumbsup:
    95GLH[QUOTED] likes this.
  3. Oct 22, 2018 at 6:11 AM
    #223
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    I've been pouring over all the diagrams. Got em on my phone too. Does it pull power from the radio or do I need to run something like a remote for an amp? I'll keep looking regardless...
    edit- holy sh*t the power thing is on the first page. my searcher is busted...derp. Thanks @payrow
    payrow likes this.
  4. Oct 24, 2018 at 8:20 PM
    #224
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
  5. Oct 27, 2018 at 3:24 PM
    #225
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Were you perfectly centered? I did that and didn’t check my pilot hole. Too close to some mounting hardware for the TSS and I couldn’t get the retaining nut on. Had to move over.... now I need a plug. :)
    Also, how did everyone get through the firewall? Push through the engine bay to cab, or vice versa? And did you use part of the existing hole or did you have to puncture the boot?
  6. Oct 27, 2018 at 5:31 PM
    #226
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    I had to puncture the boot. I was afraid of poking a hole in an existing wire as they are pretty tight together. I went from cab to engine with coat hanger. Then i cut the boot next to the hanger maybe 1/8th inch with razor. Then i pulled the wire from engine to cab.
  7. Oct 27, 2018 at 6:08 PM
    #227
    RushT
    North Texas
    I got that all done.... pretty happy with the final product. I ended up doing something like you. Need to figure out what’s up with my hood though. Somehow I have my release cable jacked and the clasp won’t fully engage.
    Sushi time though. Been working on yard and garage all day.
    Papadave418[OP] likes this.
  8. Oct 27, 2018 at 10:07 PM
    #228
    Papadave418
    Papadave418 [OP] Well-Known Member
    Glad it went well!
  9. Oct 28, 2018 at 5:22 PM
    #229
    RushT
    North Texas
    Finished my install this weekend, and am pretty happy with the final result (had to move the camera once). I have two questions:
    1) what fuse are you guys using for power? Probably one I’m already using for something else. Lol.
    2) coincidentally, I seem to have lost the Bluetooth mic, or at least nobody on the other end can hear me when I call them via the Bluetooth connection.
    There are coincidences of course..., but odds are I hosed something. Any suggestions on the latter?
    This has been the project that keeps on giving. :)
    TwilightTaco and doublethebass like this.
  10. Oct 28, 2018 at 7:04 PM
    #230
    Papadave418
    Someone else had an issue like this, I think the harness wasn’t plugged all the way in
  11. Oct 28, 2018 at 7:18 PM
    #231
    RushT
    North Texas
    Thanks, not a complicated solution. :)
    Be back in 15.
  12. Oct 28, 2018 at 7:40 PM
    #232
    orion808
    Florida
    Oh, and as for fuse...none. IT ends up tapping the hot within the harness to power the relay and camera. I posted a diagram a few pages back:
    https://www.tacomaworld.com/threads...and-rear-cameras.567192/page-10#post-18893676
    Note the black wire at the bottom left of the diagram is from the harness and when switched, will send power to the camera and relay as needed.
  13. Oct 28, 2018 at 7:42 PM
    #233
    RushT
    North Texas
    Not that.... at least from a cursory unplug/plug cycle.
  14. Oct 28, 2018 at 7:46 PM
    #234
    RushT
    North Texas
    Hmmmm, what the hell did I connect to the fuse box then? Ah, camera directly too a switched source. But I can swap over so it’s only on when needed vs when driving.
    orion808[QUOTED] likes this.
  15. Oct 30, 2018 at 5:26 PM
    #235
    hrivera007
    hrivera007 Well-Known Member
    2017 Off Road Auto
    I have a question: did you plugged the front camera rca to the female rca marked with black stripe?
  16. Oct 30, 2018 at 5:33 PM
    #236
    RushT
    North Texas
    Yep!
  17. Oct 30, 2018 at 5:34 PM
    #237
    SCUBADIVINGJOE
    SCUBADIVINGJOE Well-Known Member
    Mark
    2017 Toyota Tacoma
    Seat covers, LED Low Beams, LED FOG Lamp, Dash Cover, Pop and Lock Tailgate, Tuffy Security Console Insert, Steel Nerf Bars I want to add Hood QuickLIFT ELITE Gas Struts and High Beam LEDs
    How long does it take to install? Going to try Friday and then take the truck in for its 20K check up.
  18. Oct 30, 2018 at 5:48 PM
    #238
    Papadave418
    Took me like an hour all together. Now that I’ve done it once, 15 minutes. Always an expert too late!
  19. Oct 30, 2018 at 5:52 PM
    #239
    RushT
    North Texas
    It took me a bit of time. I’d say start to end maybe 3 hours? If you get all your stuff ready, rather than figure it out on the fly, it’ll go much faster than me. I got halfway first weekend in about 2 hours. Then another 2-3 the next weekend. It should go in 3 or less if you’re more prepared than I.
    • Make pigtails
    • Know your wiring pattern
    • Know where you’re putting your camera
    • Know wire loop cuts to get video orientation correct
    • Know how you’re getting through firewall
    • Have all your connectors/tools etc
    • If you’re putting in a rocker switch, don’t let your wife take the Dremel to a dog show
    • Just go ahead and take off the kick panel and lower dash
    • Other stuff I can’t think of right now
    orion808 likes this.
  20. Oct 30, 2018 at 5:57 PM
    #240
    RushT
    North Texas
    Clearly I wasn’t prepared well, or my ocd is off the chart. I was also trying out two different cameras. And of course had to lay out markers up front to map divergence of fov so I could compare cameras. That’s a whole lot of in/out of the truck. Then of course I had to run to Lowe’s to see if I could salvage the first hole I drilled; too close to the TSS box and couldn’t get the retaining nut on.
    I’d give myself 2 hours if I was doing a buddy’s solo. 1 hour if working together.
