Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Nov 4, 2018 at 9:20 AM
    #261
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Bw? Black white? Backward?
  2. Nov 4, 2018 at 9:40 AM
    #262
    eddy out
    eddy out Well-Known Member
    George
    Huntington Beach, CA
    2018 TRD Sport 4x4
    Lexus key card, Gentex homelink mirror, Beat-Sonic front camera harness, Wet Okole seat covers, Focal 3-way front and 2-way back speakers, JL Audio 5ch amp and 10" stealthbox sub, Pro Grill, Thule Trac one rack, Morimoto XB fogs, Meso Gasshole and Turn signals, Powder coated Sport wheels with Toyo 265/65/17 AT, XD 5K HID headlights
    My camera looks Black and White when sunny outside. The camera angle is pointed more out than down and the colors get washed out easily.
  3. Nov 4, 2018 at 10:29 AM
    #263
    BETX983
    BETX983 Active Member
    2017 TRD Off-road
    Apologies to the ambiguity. Black/White
    I'll play with the angle and see if that changes things.
    Voltage before the cameras one button wire harness is 12V, supplied by in cab switch. The camera side 4 prong push connection is 3V.... Can anyone with this camera and a voltmeter tell me there voltage drop across the one button harness?
    Thanks TW
  4. Nov 4, 2018 at 11:38 AM
    #264
    nokio2252
    nokio2252 New Member
    2018 Quicksand TRD Off-Road Long Bed
    Tinted rear lights, tinted windows, LED interior lighting
    Hey All,
    I have the same set up (2018 TRD OF DCLB Premium) and the switch works great, but when I put it in reverse, the screen just goes blank. Any advice? Much appreciated!
  5. Nov 4, 2018 at 12:08 PM
    #265
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Definitely sounds like two cables reversed. Many have questioned the quick flash, but I think it's in the opposite direction. Check the thread, I believe comments are here.
  6. Nov 4, 2018 at 1:01 PM
    #266
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Where'd you get the switch face in your pic??
    I really want to do this, a lot of times I have my bike in the back and the side mirrors are so small.
    ZKH likes this.
  7. Nov 4, 2018 at 1:34 PM
    #267
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    When you are in reverse and the switch is in the off position, you should be seeing the rear camera and (while in reverse) if you push the switch (activating the relay and shorting the red and black wire from the override harness) you should see the front camera. While the switch is pressed, it shouldn't matter what gear you are in, your display should be showing the front camera until the switch is turned off.
    I would double check your wiring.
    Look back through this thread, I think we pretty much have covered all wiring scenarios.
  8. Nov 4, 2018 at 1:36 PM
    #268
    Pympede
    Pympede Active Member
    2017 DCSB Sport 6MT
    Just pulled the dash apart again to confirm what I did with wiring.
    Red wire from relay is tied into red wire from harness as well as the red wire from the front camera and that goes into the red wire on my switch.
    Black wire from harness goes into green on switch.
    Black from relay is grounded.
    Confirmed that when I put it into reverse the relay gets triggered which switches view to front camera.
  9. Nov 4, 2018 at 1:51 PM
    #269
    payrow
    Los Santos
    '18 DCSB Sport
    Sound like you have it wired correctly, what switch did you go with? How many wires come off of the back of the switch? Your switch should basically be shorting the black and red wires from the override harness.
  10. Nov 4, 2018 at 2:01 PM
    #270
    Pympede
    2017 DCSB Sport 6MT
    It's a Ch4x4 single pole push button switch.
    4 wires out of the switch, two are hooked up to the camera, one ground, and one 12v to power the illumination.
  11. Nov 4, 2018 at 2:43 PM
    #271
    Pympede
    2017 DCSB Sport 6MT
    Not sure if it helps but I just checked and if I completely unplug the switch going into reverse still shows front camera
  12. Nov 4, 2018 at 2:58 PM
    #272
    payrow
    Los Santos
    '18 DCSB Sport
    Rules out the switch... Sounds like the relay is getting power from somewhere else or it may be stuck on. With the switch out, check to see if the red wire has 12v on it. It shouldn't.
  13. Nov 4, 2018 at 3:10 PM
    #273
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    The only power coming into the system should be from the black wire from the harness. No other external power or fuse.
    payrow likes this.
  14. Nov 4, 2018 at 4:41 PM
    #274
    Pympede
    2017 DCSB Sport 6MT
    Got a hold of the site owner and he recommended a diode on the red wire coming from the relay.
    I ordered one and I'll report back once I've installed it.
    I do want to say how absolutely impressed I am with the level of customer support anytime backup cameras offers, truly incredible. If anyone is on the fence about this product I cannot urge you enough to pull the trigger!
    orion808 and cruxx like this.
  15. Nov 6, 2018 at 7:16 PM
    #275
    tweet562
    tweet562 Well-Known Member
    SoCal
    2017 TRD Sport 2WD
    TRD Pro Grill Nerf bars Bakflip MX4 Subaru tweeters Tailgate Pop&Lock OV tune SCS Ray10 17" Matte Black
    Does anyone know if this camera can be installed with wire up? Do I need to cut any wire? I have a Pro grille and would like to hear from anyone.
    Ther AOBswitch is OOS. Anyone know where to get the switch?
  16. Nov 6, 2018 at 7:24 PM
    #276
    iNfectious
    iNfectious Well-Known Member
    Q
    Lone Star State
    '18 TRD Sport 4X4 DCSB
    Yup! I was testing it out on my old tv to make sure that by cutting the green wire, it changes to normal view (front view).
    SCUBADIVINGJOE likes this.
  17. Nov 6, 2018 at 7:34 PM
    #277
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    Looks like a great product, but why did they have to use comic sans font for the toggle switch? Makes an otherwise well put together system look amateurish.
    Papadave418[OP] likes this.
  18. Nov 6, 2018 at 9:17 PM
    #278
    tweet562
    SoCal
    2017 TRD Sport 2WD
    Thanks
  19. Nov 7, 2018 at 10:00 AM
    #279
    tweet562
    SoCal
    2017 TRD Sport 2WD
    What switch is this? Can you provide a link? Thank you.
  20. Nov 7, 2018 at 6:58 PM
    #280
    cruxx
    Huy
    2017 TRD Sport
    Couldnt tell ya. Took it off another post. Looks like a simple toggle switch to me
    tweet562[QUOTED] likes this.
