Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Dec 19, 2018 at 2:40 PM
    #361
    Onemorodeo
    Onemorodeo Well-Known Member
    OC SoCal
    ‘18 dclb TRD Sport 4wd Cement
    So I switched out my camera that I originally installed for the Yumi camera because the image was reversed and then inverted after cutting the green wire. Unfortunately, the Yumi image is shaky and real poor resolution. Not sure how to correct this. Any suggestions???
  2. Dec 19, 2018 at 2:49 PM
    #362
    Papadave418
    Papadave418 [OP] Well-Known Member
    So the image shakes when you drive? My image is stable and clear. Take a photo of the poor resolution.
  3. Dec 19, 2018 at 3:30 PM
    #363
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    If its shakey, put the bolt on tighter
  4. Dec 19, 2018 at 3:34 PM
    #364
    Onemorodeo
    OC SoCal
    So it's not shaking from movement. It's the same whether or not the trucks moving. All connections appear to be good. Will post a photo shortly.
  5. Dec 19, 2018 at 3:42 PM
    #365
    Onemorodeo
    OC SoCal
    Went out to the truck to get a pick of the screen and now no video is coming through when switched to the front camera. Argh!
  6. Dec 19, 2018 at 4:08 PM
    #366
    cruxx
    Huy
    2017 TRD Sport
    Check your connections and crimps. Mine didnt work because of the crimp
    Papadave418[OP] likes this.
  7. Dec 19, 2018 at 4:13 PM
    #367
    Onemorodeo
    OC SoCal
    Will do, thanks. I will let you know what I find out. I have to go to work for a few days so I'll get back at it on Sunday or early next week.
  8. Dec 20, 2018 at 5:55 AM
    #368
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    If your original camera is the same Chuanganzhou one I have, the manufacturer/seller told me to try grounding one end of the snipped green wire to turn the image right side up. They also said that it will require trial and error, because one end of the green wire flips the image when grounded, the other end results in no image at all if grounded. In my case, there wasn't much point in that fix, because the image flips randomly - sometimes it's right side up, sometimes it's inverted. Oh yeah, one other amusing tidbit. In spite of many posts in this thread stating that this camera is supposed to be mounted with wires horizontal, the seller states that it's supposed to be mounted with wires vertical. *shrug*
  9. Dec 20, 2018 at 7:37 AM
    #369
    Papadave418
    That’s why I bought it, then struggled to get the image right. So I changed the orientation but didn’t love the perspective. I’m glad I changed out my camera, it was a $13 mistake but that’s life.
    ohioboater[QUOTED] likes this.
  10. Dec 20, 2018 at 4:03 PM
    #370
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    Any current promo codes? Want to get this. Also can someone exactly explain the purpose of the nav over ride. Thanks you.
  11. Dec 20, 2018 at 4:37 PM
    #371
    chriscamilo
    chriscamilo Well-Known Member
    2018 Tacoma DCSB Sport
    Nav override allows you to type on the head unit while moving/driving.
  12. Dec 20, 2018 at 4:58 PM
    #372
    Jdmkun
    Jdmkun Member
    2016 White Tacoma TRD Pro
    I already use my composite video input on the radio for something else (Roku). Does the Anytime front camera also have to use the video input as the rear camera doesn't use it? I've got a 2016 Tacoma gen 3.
  13. Dec 20, 2018 at 5:03 PM
    #373
    Tacohumper13
    Menifee
    So without it the nav is frozen?
  14. Dec 20, 2018 at 5:05 PM
    #374
    chriscamilo
    Yeah, all the keys will be grayed out and wont let you type anything in the navigation screen.
    Tacohumper13[QUOTED] likes this.
  15. Dec 20, 2018 at 5:08 PM
    #375
    Tacohumper13
    Menifee
    For the entire time? Or only with the camera is activated?
  16. Dec 20, 2018 at 5:16 PM
    #376
    chriscamilo
    The nav over ride is a different function from the camera set up. Neither function affects the other, although they use the same wiring harness.
    From the factory, the head unit does not let you type while the vehicle is in motion. This is a safety feature. The nav over ride tricks the head unit and makes it think the vehicle is stopped thus allowing you to type.
  17. Dec 20, 2018 at 5:18 PM
    #377
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    yub likes this.
  18. Dec 20, 2018 at 5:20 PM
    #378
    Tacohumper13
    Menifee
    Ahhh now I see. Cool thank you.
  19. Dec 20, 2018 at 5:21 PM
    #379
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    My wife uses the nav override to input Navigation changes on long trips. Simple $8 mod since I was already in there. You can also edit settings that are normally not allowed unless in park.
    Hit switch on, make changes, hit switch off, navigation kicks back in 3-5 seconds.
  20. Dec 20, 2018 at 5:25 PM
    #380
    orion808
    Florida
    This mod basically takes the current rear camera, splices that input and adds a relay to select between the two.
