Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016+)' started by Papadave418, Sep 7, 2018.
  1. Jan 25, 2019 at 6:50 AM
    #461
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    holding
    Check the Tacoma Parts site... I believe you’re looking for a small switch cover (I only have found the large on on Amazon). Could be the part ID 55539 / 55539B on this diagram, but not guaranteed (had to check a trim version that has a blank switch cover, like an SR)...
    https://parts.toyota.com/a/Toyota_2...ENT-PANEL--GLOVE-COMPARTMENT/674470-5551.html
    Papadave418 [OP] likes this.
  2. Jan 25, 2019 at 7:21 AM
    #462
    skiploder
    skiploder Personally holding a grudge against Falken
    Under a piece of wood
    Taco/4Runner/FZJ80
    This is the part number for the small hole:
    55539-28160-C0
    Papadave418 [OP] and ZKH like this.
  3. Jan 25, 2019 at 9:06 AM
    #463
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
  4. Jan 25, 2019 at 9:21 AM
    #464
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2018 Cement TRD OR, 2008 FJ
    I'm hoping he will release a switch in the future that matches the stock blue switches, isn't unnecessarily super bright, and the front vs rear lights work properly. This switch is perfect for eliminating a two switch setup, but it could use a few tweaks.
    Pyrotech and Papadave418 [OP] like this.
  5. Jan 26, 2019 at 3:45 PM
    #465
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Every switch I've seen except one has simple though hole 3mm leds and 1/4w axial resistors ~1k, both can be swapped to other colors or to lower brightness to better march oem or choice. The exception used smd leds and resistors that while tiny were still changeable. Be nice if he mentioned whether it's possible with his.
  6. Jan 27, 2019 at 12:09 PM
    #466
    TheGetLostTaco
    TheGetLostTaco Active Member
    Deryl
    Southeast GA swamp
    2018 Cavalry Blue Tacoma TRD Pro
    Can the ARB Linx be used to actuate the cameras relays?
  7. Jan 29, 2019 at 1:07 PM
    #467
    DerekV87
    DerekV87 MT native exploring the wilds in the Tacoma.
    Missoula MT
    2018 Tacoma TRD Off Road Cement
    Xenon Dept HID Kit TRD Pro Grill TRD Pro 17" Wheels BFG KO2 265/70/17 De-badged Leer 180 Topper Topper LED lights Bed Platform LED Bulbs everywhere except interior Clazzio Leather Seat Covers OCD Center Console and Glove organizers Phone Mount found on Etsy Ultra Gauge Subaru Tweeter Upgrade AC Drain Mod Yellow Fog Light Bulb Bed Rug Tailgate Cover
    I did hear that if the black wire from the switch is left disconnected, the switch will not be illuminated. Makes sense. I am planning to go this route. The light doesn’t add much imo especially being on all the time and off color.
  8. Jan 29, 2019 at 6:55 PM
    #468
    bagleboy
    Scott
    Norcal, Santa Rosa
    Probably ground, if left unconnected the led(s) won't light no matter where they get power. I may get one of these to free up an extra switch location there and to see/show how to alter the lighting.
  9. Jan 29, 2019 at 6:56 PM
    #469
    bagleboy
    Scott
    Norcal, Santa Rosa
    If it can supply .1A then yes.
  10. Feb 2, 2019 at 10:16 AM
    #470
    DerekV87
    Missoula MT
    Well leaving the switching black wire disconnected didn’t kill the switch backlight light Brian at Anytime indicated. All it did was kill the amber indicator lights when the front camera is selected. When selecting the rear camera, the indicator light still comes on.
    So I just took the switch apart and covered the led with electrical tape. Done
    Dogg23 likes this.
  11. Feb 2, 2019 at 12:00 PM
    #471
    Berttholio
    Berttholio Member
    2018 Cement Tacoma TRD
    Anyone have some ideas, just installing this mod, and getting this as a signal from the rear camera. C224C0D9-85E4-4120-8B16-C797DC8A8111.jpg
  12. Feb 2, 2019 at 12:12 PM
    #472
    Kevinpd325
    Kevinpd325 Active Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    SSO Slimline bumper Smittybuilt XRC winch Prinsu cab rack Leisner Designs ACS Leitner Designs bed stiffeners Firstworld Fab bedside and corner mounts Herculiner bed coating Icon extended travel stage 4 w/ tubular UCA Procomp 285-75-17 all-terrains K&N air filter Pedal Commander Anytime backup camera w/ 2nd rear camera LED interior light conversion LED headlights LED fog lights Genesis dual battery system sPOD Bantam Caliraised LED 42" light bar Auxbeam front & rear ditch lights OPT7 Quantum rock lights Expedition Essentials TPAM w/ Blue Sea USB Expedition Essentials bedside compressor mount w/ ARB twin 67 Designs phone mount Meso Customs lower switch panel Rago CB antenna mount Anytone AT-768 UHF/VHF radio Cobra Bearcat CB radio Kicker DS 6×9 Kicker DS 6 1/2 Kicker dash tweeters Kicker 10" powered sub
    Anyone install a 2nd rear camera for use in tailgate down situations? I've been looking at video switches to accommodate such a thing, but just wondered if anyone has already attempted this?
  13. Feb 2, 2019 at 12:51 PM
    #473
    MGMSangTaco
    MGMSangTaco Well-Known Member
    Adam
    Denver, CO and Cape Cod, MA
    2017 TRD OR MGM DCLB
    Has anyone in here installed this set up with a switch pro? If so is it farily straight forward? I know it says they are compatible ob the website but looking for first hand experience.
  14. Feb 2, 2019 at 3:26 PM
    #474
    Berttholio
    Berttholio Member
    Both front and rear camera are giving me this pixelated signal. Not sure what could be causing it. Any thoughts?
  15. Feb 2, 2019 at 8:35 PM
    #475
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    Actually working in this now. Ran into a snag though, so if you are patient, I'll provide plenty of details.
    Worked initially, then think i shorted something.
    Edit: I assume we are both talking about er total cameras. One front, two rear.
    r_to_the_k and Kevinpd325 like this.
  16. Feb 2, 2019 at 8:56 PM
    #476
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - De Sais.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    .. Good write up and just did mine awhile ago. Pretty straight forward and satisfied with the install..
    Here's a video.. :thumbsup:
    https://youtu.be/5ifYWyF_Kh8
    orion808 likes this.
  17. Feb 3, 2019 at 2:30 PM
    #477
    Kevinpd325
    Kevin
    San Diego
    That is exactly what I'm talking about. 3 cameras total. 1 front, and 2 rear.
    r_to_the_k and orion808 like this.
  18. Feb 4, 2019 at 6:54 AM
    #478
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    '18 TRD OR DCSB 4x4 Cement
  19. Feb 4, 2019 at 1:25 PM
    #479
    orion808
    Florida
    If you undo the mod, does the rear camera still function normally?
    Could be a bad video connection at the relay or harness. My best guess.
    Try connecting the video cables on the harness together. Leave the relay and front camera out of the loop.
  20. Feb 4, 2019 at 1:34 PM
    #480
    Berttholio
    Berttholio Member
    I spoke with Brian, The anytime backup works, looks like I got a bad relay or video harness. They are sending a replacement no problems!
