Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Mar 28, 2019 at 8:51 AM
    #561
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    The camera included with the kit is decent but you can find better quality (viewing angle, connectors, nighttime quality, etc).
    I used this one: https://www.amazon.com/NATIKA-Backu...se/dp/B07H852D49?ref_=bl_dp_s_web_17442842011
    Pyrotech likes this.
  2. Mar 28, 2019 at 10:05 AM
    #562
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Thanks. I saw another user on FB use that one too so I think I will go with that one along with the kit.
  3. Mar 28, 2019 at 2:56 PM
    #563
    Pyrotech
    Pyrotech Well-Known Member
    I use the same one..
  4. Mar 30, 2019 at 5:13 PM
    #564
    apm417
    apm417 Member
    Hey TW,
    So I bought the two different push switch setup (CH4x4 front and rear switches) and I wanna be able to switch each one on separately, so it sounds like I need a diode. Does anyone know specifically what diode? Or will any old diode do? Thanks in advance
  5. Mar 30, 2019 at 5:21 PM
    #565
    mk2tmr2
    mk2tmr2 Member
    So, I need a little help. I just received my full kit from ABC and wired it up. I’m not a noob at automotive wiring, but this isn’t working for me.
    I am pretty sure I have everything wired up properly. Triple checked it all. (Pretty easy when all of the wire colors match). When I switch to the rear camera it works properly. But when I switch to the front camera, both indicators (front and rear) illuminate on the switch and I get a black screen.
    I don’t know if I’ve done something wrong or if something in the kit is faulty (switch or relay). Help is appreciated!
  6. Mar 30, 2019 at 8:16 PM
    #566
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Both indicators illuminate when the switch is set to Front. Don't know why, but that's what the site says. Afraid I can't help you with the black screen as I have yet to install my kit.
  7. Mar 30, 2019 at 8:32 PM
    #567
    mk2tmr2
    mk2tmr2 Member
    I went back and found that on the switch product page. Hadn’t seen that before. That helps rule one variable out. I thought both indicators illuminated was an indication of a problem. Now I am tending to think the issue is the camera itself. Will keep at it tomorrow. Probably going to hook another video source to the RCA just to verify everything downstream of that connection works properly.
  8. Mar 30, 2019 at 8:48 PM
    #568
    CAG Gonzo
    2018 OR DCLB BarRed
    I can't think of any logical reason why the lower indicator illuminates when in Reverse, but both illuminate in Front. Just doesn't make sense.
  9. Mar 30, 2019 at 9:29 PM
    #569
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    Got my kit installed this afternoon/evening. Big thanks to both @n6vmo doing the edit with the original high tech @capequahog schematic, and of course @Papadave418 for starting this. Only thing different on mine is that my wire off the relay I got was green rather than red. Hooked everything up and it works perfectly. I went with one of the $15 Amazon cameras and I think I may go back and put one of the better quality units in. Haven’t seen video quality in the daylight yet but the night video quality is not great and it easily washes out with headlights. The lack of dimmer on the camera switch isn’t a huge deal right now, but I would like to have it dim.
    And the 30 feet of video cable was fun to secure behind the head unit.
    Overall very happy with the camera mod with the listed issue but definitely a good mod.
    n6vmo and Papadave418[OP] like this.
  10. Mar 31, 2019 at 5:59 AM
    #570
    Landpirate
    North Texas
    I installed mine off of the centerline.
    The camera is just about inline with where my forward line of sight normally is. I'm still getting "Clean Sensor" errors on my Pro grille (I have an SR5) and I didn't want to mess with having the camera module right over the sensor.
    The crossbar on the red limit line is about 1 foot off of the leading edge of my bumper. The green crossbar is about 4 feet. Daytime video quality is ok, but I think I'm going to upgrade the camera to better quality unit. It's not bad, but I think I'm going to want a little better video quality. I'll see how I like it over time.
    This is the camera I ordered:
    https://www.amazon.com/gp/product/B00RD05MOO/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Nighttime illumination from the camera icon is rather bright.
    Excellent job with the switch, looks very close to an OEM unit, wiring was very easy.
    n6vmo and Kabogski like this.
  11. Mar 31, 2019 at 6:56 AM
    #571
    Papadave418
    Papadave418 [OP] Well-Known Member
    Nice install!
    Landpirate[QUOTED] likes this.
  12. Mar 31, 2019 at 7:11 AM
    #572
    Landpirate
    North Texas
    Thank you sir. I was back and forth on the idea but your thread got me through it. If I'm researching something and see a thread from you on it, it's a must-look for me. Thanks for contributing all that you do.
  13. Mar 31, 2019 at 7:58 AM
    #573
    Landpirate
    North Texas
    Quick note:
    On the most recent batch from ABC the wires coming off of the relay are black and green, there is no longer a red wire. At least on the kit that I just received.
    Papadave418[OP] likes this.
  14. Mar 31, 2019 at 8:32 AM
    #574
    3Six
    3Six Well-Known Member
    NoVa - Ashburn/Sterling
    2017 OR DCSB
    Icon Stage 4, Method NV 305, 285/75/16 Wildpeaks, C4 armor, CMC, CaliRaised Sliders
    Think it's about time to order this now that I have my switchpro going in soon. Only took me about 3 months to order.
  15. Mar 31, 2019 at 8:35 AM
    #575
    capequahog
    capequahog Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
    the cubby unit pops out with a little help with a knife or plastic trim tool
  16. Mar 31, 2019 at 12:04 PM
    #576
    Ziggyman
    Ziggyman Well-Known Member
    2018 TRD OR DBL 4x4
    So I purchased the integration module and a camera for the front. I'll see how it goes.
    Germes Lab. RFCC TTG2
    https://www.amazon.com/gp/product/B07DKH6J4W/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
    As to camera - I got the one that fits in the toyota emblem - although I have a solid emblem for the TSS. I think with my OR grill it will fit in there...I'll show some pics.
    CAIRUTE 420 TVL HD CMOS
    https://www.amazon.com/gp/product/B07DC139L8/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    I will use the factory backup cam - I wanted to see if the integration unit would take a third input from a trailer - but I don't think it will.
    enduringsnark likes this.
  17. Mar 31, 2019 at 7:44 PM
    #577
    mk2tmr2
    mk2tmr2 Member
    An update on my situation:
    It turned out to be a problem with the wiring to the relay in the ABC kit. After many hours of installing/uninstalling and wiring/rewiring different powers and grounds, testing continuity, etc - I finally got a picture from the front camera when I had the relay loose and not secured in place. After wiggling things around a bit I determined it was an issue with the bundle of three white wires going to the relay.
    I finally decided to cut the heat shrink tubing off those wires to see what was going on underneath and as soon as the heat shrink was off I got a solid, clean image from the front camera. I taped those wires back up with electrical tape and the problem has been gone ever since.
    I can't pretend to know why this fixed it, what was wrong or if the problem will stay fixed. Only time will tell.
  18. Apr 1, 2019 at 2:27 AM
    #578
    capequahog
    Cape Cod MA
    Interesting, are the white wires just going into the black there and taped together, if so maybe a loosie in the relay itself
  19. Apr 1, 2019 at 2:16 PM
    #579
    Breakr007
    Breakr007 Well-Known Member
    Hi all. I just finished the install of the front and back kit. Using the front camera is great, and only makes me wish that this video feed can be recorded. Application would be go pro style, or even as a dashcam of sorts.
  20. Apr 1, 2019 at 2:27 PM
    #580
    mk2tmr2
    mk2tmr2 Member
    Definitely not loose inside the relay. It was certainly that particular joint where the heat shrink is, about .5" before the relay. Underneath the heat shrink those wires are spliced together and it's a bit of an odd, open splicing situation. I taped it back up and it's been fine ever since.
    There are mobile DVR products out there that you could easily put in-line with the front camera. Some of them even take multiple feeds so, presumably, you could get both the front and rear camera feeds from the ABC harness and record them simultaneously.
    You'd need to wire the front camera to constant power and not to switched power to make it work.
