Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. May 31, 2019 at 2:03 PM
    #641
    Papadave418
    Papadave418 [OP] Well-Known Member
    Can’t see mine in the view
    Dogg23 likes this.
  2. May 31, 2019 at 2:31 PM
    #642
    Ray1989
    Ray1989 Well-Known Member
    SoCal
    3rd Gen Sport
    Where did u place ur camera? And can u send me a link of the camera u got?
  3. May 31, 2019 at 3:06 PM
    #643
    Papadave418
    I am the OP, literally the whole first post is my build with camera choice and photos of where it is mounted :wave:
    :thumbsup:
    Dogg23, k8md and Ray1989[QUOTED] like this.
  4. Jun 1, 2019 at 10:21 AM
    #644
    LDS 77
    LDS 77 Well-Known Member
    2016 OR
    I used this thread to install my the kit with front cam and switch 2 months ago and it’s been working great until today.
    When I use the switch to select the rear cam or when I just shift into reverse I just get a black screen until I use the switch to select the front cam which does come on than back to rear cam and than the rear cam will work. If I’m in reverse than I have to switch from off position to front than back to off or rear and than the rear cam works.
    Sometimes the rear cam will come on for a second than get fuzzy and go black but usually it’s just a black screen. After selecting the front first to make it work I can go straight to rear and it will work like normal for a few minutes than back the black screen a I have to select front cam first again.
    Any tips or advice would be much appreciated. Maybe a bad relay or switch?
    Thanks.
  5. Jun 1, 2019 at 10:25 AM
    #645
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    I mounted mine on the bar so I could adjust it's view and not be blocked by the tube .
    Tacospike and Papadave418[OP] like this.
  6. Jun 1, 2019 at 10:31 AM
    #646
    Papadave418
    I wonder if your relay has gone bad? Is your front camera power connected 100% of the time, or just when actuated by the relay?
  7. Jun 1, 2019 at 10:37 AM
    #647
    LDS 77
    2016 OR
    Just when actuated by the relay
  8. Jun 1, 2019 at 10:37 AM
    #648
    Papadave418
    If you open the dash up to where the relay is, does it actuate (click) when you flip the switch? That will help isolate if it’s the switch or relay.
  9. Jun 1, 2019 at 10:42 AM
    #649
    LDS 77
    2016 OR
    I will try that out a little later today. I will update with my results. I also emailed Brain at ATBC so I’m sure he will replay next week.
    Thanks Man!
  10. Jun 1, 2019 at 11:15 AM
    #650
    whitepony04
    whitepony04 The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    What would be required to mount the switch in the useless cubby by the steering wheel?
  11. Jun 1, 2019 at 11:21 AM
    #651
    Papadave418
    I would lean towards a cubby switch plate, a number of companies sell them, I got mine from @CaliRaisedLed. Very easy to install
    I put my camera switch where the OEM alarm thingy would be824ABB46-1AC5-4A39-9F4A-879B6BFFEE31.jpg
  12. Jun 1, 2019 at 11:23 AM
    #652
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Was there enough wire to reach the cubby or did u do some extending?
  13. Jun 1, 2019 at 11:26 AM
    #653
    Papadave418
    I had to add simple 18g wire. See post 1
  14. Jun 2, 2019 at 7:12 AM
    #654
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Papadave418[OP] likes this.
  15. Jun 2, 2019 at 7:57 AM
    #655
    kayakzkh
    kayakzkh New Member
    Zane
    northern Kentucky
    I also went with a product from forty2skates. I got one with two switch holes, one for the camera selection and one for the navigation over-ride, which I chose to use a flux capacitor switch for.
  16. Jun 2, 2019 at 8:03 AM
    #656
    Ray1989
    SoCal
    3rd Gen Sport
    What mount is this?? U got a Link?
  17. Jun 2, 2019 at 8:58 AM
    #657
    hawaii_dave
    2017 trd pro
  18. Jun 4, 2019 at 8:28 AM
    #658
    Papadave418
    Did you diagnose the issue yet? I wonder if the terminals on the relay are loose
  19. Jun 4, 2019 at 6:11 PM
    #659
    LDS 77
    2016 OR
    Not yet. I’ve been busy with work. I was waiting to here back from Brain. I sent a new email through the website. First email I sent was a reply from a previous email so maybe he didn’t get it.
    I’ll check it tomorrow after work.
    Thanks
  20. Jun 5, 2019 at 8:10 PM
    #660
    LDS 77
    2016 OR
    I just pulled the head unit out to check the relay and when I select the front camera the relay does click. When I go back to off coming from front cam the relay clicks again.
    When I go to rear cam there is no click. Also no sound when I go from rear back to off.
    I’m not sure if that’s normal or not. I did here back from Mat so I’ll let him know the symptoms.
    I found this an it looks to be the same relay so I will just order them and see.
    Update: I forgot to mention that the rear cam was functioning correctly again before I pulled the head unit to test the relay. After putting it back together it still working so I haven’t tested the new relay to see if it clicks. I only drive the truck on weekends so haven’t used the cameras much.
    If it starts acting up again I will test the new relay and update.
