Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Aug 3, 2019 at 3:30 PM
    #721
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    can't help with #2 but #1 is definitely not normal. my reverse camera works like it's supposed to.
  2. Aug 3, 2019 at 3:57 PM
    #722
    ZKH
    ZKH Well-Known Member
    northern Kentucky
    2018 TRD-OR DCLB A/T 4x4 BBP Prem+Tech
    Regarding number 2, at the end of the video cable behind the grill, did you connect the red pigtail from the video cable to the red pigtail on the camera cable?
  3. Aug 3, 2019 at 5:49 PM
    #723
    DanvilleTrain
    DanvilleTrain Well-Known Member
    Edward LongMember
    2015 Tacoma
    Yes. I know that the 12V power has to come from the Relay in the dash. So, the 12V originates at the relay (and is controlled by the switch) and travels down the RCA cables and jumps from the RCA extension cable to the camera 12V power cable that comes with the front camera. I had an idea after I gave up today to temporarily cut the 12V cable at the front camera and just power it directly from the battery. If the front camera then works, then I know the camera is good and there is an issue with 12VDC coming from the relay or the switch.
  4. Aug 3, 2019 at 7:10 PM
    #724
    BSCowboy
    BSCowboy Well-Known Member
    RENTON, WA
    19 Taco-TRD.OR.DC.LB
    Dirt & dogs LEER 100XR Topper NOICO Sound Deadener & Insulation OEM Audio Plus Decked Marathon Seat Covers Pop & Lock WeBoost Drive Reach {removed} Anytime Camera install Falcon Suspension System Nitro 5.29s {soon} Method 702 (not sure on tires)
    I installed the kit on my truck with OEM Audio + set up. It worked great until it started causing my head unit to restart over and over. While diagnosing the problem I reached out to anytimebackupcamera, he was responsive and helpful...even when my responses were nonsensical. I disconnected the camera and haven't had a problem since. Soon, I'll take the time to pull everything out and get rid of it here, if possible. I am going to miss the anytime camera...it's super helpful when I am towing.
  5. Aug 6, 2019 at 5:41 PM
    #725
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    You ship to Canada?
  6. Aug 6, 2019 at 5:42 PM
    #726
    Canadianguy91
    Sean
    2016 Limited
    Why didn’t it work?
  7. Aug 6, 2019 at 6:46 PM
    #727
    irANTHONY
    irANTHONY Well-Known Member
    How did y’all mount your relay harness?on the YouTube videos... there is a metal part that you connect to the right side bolt in the bay... but idk if they are shipping a different relay harness out now
  8. Aug 6, 2019 at 7:32 PM
    #728
    Taco de Naranja
    Taco de Naranja Well-Known Member
    Benny
    NW WI
    2017 TRD Sport DCSBAT-Inferno
    There are (2) 10mm bolts behind the radio. I mounted the relay on the right side bolt. As simple as it sounds, that relay was a bear to mount. I’d explore a zip tie method to the bolt if possible saving time and frustration.
  9. Aug 6, 2019 at 7:42 PM
    #729
    Canadianguy91
    Sean
    2016 Limited
    Can I mount mine on a power tray under the hood?
  10. Aug 6, 2019 at 8:06 PM
    #730
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Crimp crimp and recrimp....thats why i didnt get power to front cam
  11. Aug 6, 2019 at 9:38 PM
    #731
    Taco-Obsessed
    let us know what happens and if you got it to work.
  12. Aug 6, 2019 at 10:07 PM
    #732
    Papadave418
    Papadave418 [OP] Well-Known Member
    You’d have to email Brian at anytimebackupcamera.com to find out
    Canadianguy91[QUOTED] likes this.
  13. Aug 7, 2019 at 3:48 PM
    #733
    BSCowboy
    RENTON, WA
    I have no idea. All I know is that my head unit started rebooting and stoped when I removed the anytime backup camera harness. I suspect the slight modification between the OEM Audio + harness and the anytimebackupcamera harness didn't get along.
    Papadave418[OP] likes this.
  14. Aug 9, 2019 at 12:10 PM
    #734
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    Hey everyone,
    I am looking to add an Anytime Front and Rear camera, as well as the Navigation Lockout Bypass, and Wifi Smartphone Mirroring all in one mod.
    https://www.amazon.com/dp/B07DKH6J4W will get get me front and rear camera with the steering wheel controls
    https://www.anytimebackupcamera.com/collections/frontpage/products/anytime-backup-and-front-camera will get also get me front and rear camera via a double switch, but what would be the procedure to add Navigation Lockout Bypass like mentioned in this thread:
    https://www.tacomaworld.com/threads...one-mirroring-mod.473033/page-4#post-14798424
    and and Wifi Smartphone Mirroring like mentioned in this thread:
    https://www.tacomaworld.com/threads...one-mirroring-mod.473033/page-3#post-14761375
    maybe with this:
    https://www.amazon.com/Upgraded-Dis...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
    I am hoping for a plug and play solution, or a least only modifying a plug and play harness if possible.
    Any help would be appreciated.
    BSCowboy likes this.
  15. Aug 9, 2019 at 12:20 PM
    #735
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Not without extending the wires. Plus, it's easier to mount it in the area behind the head unit.
  16. Aug 9, 2019 at 12:21 PM
    #736
    Bunk Moreland
    Bunk
    It's complicated.
    That's the relay that came with my kit. I zip-tied it to the steel arm to the right of bolt (there's a small pocket that is a perfect fit.)
    Taco de Naranja likes this.
  17. Sep 11, 2019 at 7:59 PM
    #737
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Completely redid my 3 camera system after I installed my bed rack. Figured I'd drop the color coded schematic I had to draw to straighten my brain out during the installation. Installed switches in Meso Customs panel. All in all I'm pleased with the functionality. I can select either front or rear camera any time, and if the tailgate is down I can flip the SPST switch right next to the DPDT and see the tailgate. Thanks to orion808 for the assist.
    Taco de Naranja and k8md like this.
  18. Sep 11, 2019 at 8:03 PM
    #738
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Very nice. I'll tuck this away for future spending.
  19. Sep 15, 2019 at 11:49 AM
    #739
    cyked
    cyked Well-Known Member
    Anyone know what diode is in this wire harness? Mine has been on the fritz (won't work sometimes when in reverse), removed the shrink cover over the diode after diagnosing it as the issue. Clean break right through the middle, so need to replace it. They have one on their website that says 540 MIC, but it's not clear if it is a replacement for this or for other things (it mentions usage for using 2 switches as one application though). At least I think it's a diode.
  20. Sep 15, 2019 at 12:49 PM
    #740
    cruxx
    Huy
    2017 TRD Sport
    From my understanding, the diode is only neccesary when you install 2 switches. A single dpdt switch does not need diode and i believe there has only been a single type of diode used
