Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Feb 15, 2020 at 10:50 AM
    #941
    bluedevils9
    bluedevils9 Well-Known Member
    2020 Cement TRD Off Road
    100%, tried it that way when i first did it and went out yesterday and tried it again after seeing your post.....setting up a phone call with him to see if we can figure out what is going on. I appreciate the help!
  2. Feb 15, 2020 at 1:56 PM
    #942
    NEIPA27
    NEIPA27 Well-Known Member
    Florida
    2020 OR
    Okay, just making sure. DuesExMachina had the reversed when he first installed his, and the symptom was the head unit not powering up. I had mine connected to the left two connectors at first, and the head unit ran fine, but the camera switch didn't do anything .
    Hope you get it figured out and the guy backs his product if it's defective.
    bluedevils9[QUOTED] likes this.
  3. Feb 23, 2020 at 6:21 PM
    #943
    elmontemike
    elmontemike Well-Known Member
    I bought that same camera and it works great.
  4. Feb 23, 2020 at 6:36 PM
    #944
    elmontemike
    I bought my kit in May of 2019. I finally installed it today and it works great. I have a 2018 sport model truck. At first the front camera wouldn't work and I was getting a really weird picture from the rear camera. It took me a few minutes before I realized my tailgate was down. Put the tailgate up and the rear camera worked perfectly.
    :annoyed: :censored: :crazy: :goingcrazy::facepalm:
    Took a break and tried to figure out why the front camera wouldn't work. Turns out I had a bad ground connection. Redid the ground connection and it works great. I didn't use the camera from ABC but purchased this one, like many others.
    https://www.amazon.com/NATIKA-Backu...Camera,IP69K+Waterproof&qid=1581545653&sr=8-3
    The only issue I have left is the switch. Everything works fine on it but for the illumination, how re you guy getting the switch to dim with the rest of the panel when you want to dim it? Any help would be appreciated.
    :cheers:
  5. Feb 23, 2020 at 6:37 PM
    #945
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    What install guide did you use?
    elmontemike[QUOTED] likes this.
  6. Feb 23, 2020 at 6:49 PM
    #946
    elmontemike
    I used the one on ABC site and watched a couple of different youtubes. Running for Tacos and Rob Motive if I remember correctly.
    Yann[QUOTED] likes this.
  7. Feb 26, 2020 at 7:38 AM
    #947
    NEIPA27
    Florida
    2020 OR
    Yeah that's a good camera. The one they give you in the kit is absolute garbage. As for the dimming option, I have not tried actually dimming it, but the way it is wired in it will turn on and off with the other switch illumination when the headlights are turned on or off .
  8. Feb 26, 2020 at 10:00 AM
    #948
    caribe makaira
    Caribbean, Puerto Rico
    Does the system behave as OEM if no buttons are selected? (Reverse on transmission, reverse cam shows)
  9. Feb 26, 2020 at 10:04 AM
    #949
    stiles88
    stiles88 Well-Known Member
    Seattle (Bothell WA)
    2020 GLE 350, 2008 FJ
    Yes
  10. Feb 26, 2020 at 10:32 AM
    #950
    NEIPA27
    Florida
    2020 OR
    I will second that yes, from my experience as well. When the switch is in the middle position, all systems function as OEM.
    elmontemike and stiles88[QUOTED] like this.
  11. Feb 26, 2020 at 11:48 AM
    #951
    Toyotako
    Toyotako Well-Known Member
    2020 Cement TRD Off-Road 4x4 DCSB
    No problem here either. Remember the override harness & video only enable the rear camera to trigger on when pressing the switch, same applies with the front camera when viewing.
  12. Feb 26, 2020 at 1:02 PM
    #952
    caribe makaira
    Just did not know if the added harness has a diode to prevent the reverse input to the rest of the reverse output system...
    Or is it the DPDT switch acting as a diode?
  13. Feb 26, 2020 at 1:39 PM
    #953
    NEIPA27
    Florida
    2020 OR
    There is a diode on the back of the switch, connecting two of the terminals. Perhaps that is what it is for. I can tell you that when I engage the rear camera with the switch, that is the only reverse action that occurs; the backup lights to not come on, and the system doesn't do the reverse shift
    "beep."
  14. Feb 26, 2020 at 1:53 PM
    #954
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I haven’t read all the pages...
    anyone have a source to a replacement front camera?
    Bought and installed the front camera kit but the included camera has illumination LEDs and where mounted in my grill, the LED light reflects off my white bumper and the Iris closes and the image sucks.
    I’ve bought 4 different cheap cameras now from eBay vendors that have the small black connector instead of the yellow RCA at the camera and none are wired the same so they don’t work.
    any help on finding a non LED camera with the small black connector greatly appreciated!!
    -Ed
  15. Feb 26, 2020 at 1:57 PM
    #955
    empty_space
    empty_space Well-Known Member
    Check out this post. This seems to be the one to buy. Pricey, but looks like its actually worth it.
  16. Feb 26, 2020 at 2:02 PM
    #956
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Thank you!
  17. Feb 26, 2020 at 2:03 PM
    #957
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    The Nakita is the one I got. Had it for months and have had zero issues.
    EdinCincinnati likes this.
  18. Feb 26, 2020 at 2:04 PM
    #958
    NEIPA27
    Florida
    2020 OR
    this will have the little black connector on it as well, but it also has the adapter to connect to the yellow RCA wire with the red wire coming out. look at my post from the top of page 46 to see it.
  19. Feb 26, 2020 at 2:09 PM
    #959
    caribe makaira
    Any chance you can get a pic?
  20. Feb 26, 2020 at 2:11 PM
    #960
    NEIPA27
    Florida
    2020 OR
    I took one before I installed it. Here ya go.
