Anytimebackupcamera.com Install- Front and Rear Cameras
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Sep 7, 2018.
  1. Feb 26, 2020 at 2:19 PM
    #961
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  2. Feb 26, 2020 at 2:24 PM
    #962
    caribe makaira
    Caribbean, Puerto Rico
    :thumbsup::thumbsup::thumbsup:
  3. Feb 26, 2020 at 10:58 PM
    #963
    Bradg93
    Bradg93 Well-Known Member
    Port Hope, Ontario, Canada
    2020 TRD Sport DCLB Cement Grey
    Can you take some pictures so I can see what you mean about bracket/mount. Also can you take a few so we see what tour view is having it mounted higher thank what everyone else is doing?
  4. Feb 27, 2020 at 10:16 PM
    #964
    Toyotako
    Toyotako Well-Known Member
    2020 Cement TRD Off-Road 4x4 DCSB
    Look on page 46 and dig up some of my old posts to see it. It looks OEM and wide in viewing angle and full HD. https://www.amazon.com/Backup-Water...akita+bac&sr=8-6#immersive-view_1582870128797 I used polyethylene split tubing and wire loom to hide the long RCA cable in there going right under the horn and in front of the radiator and running along side of the frame body by the battery. I zip tied and wrapped with electrical tape every few feet as it goes. The rest of the cable was pulled back up behind the head unit, zip tied in a bundle and tuck it right in the middle of the AC hoses.
  5. Feb 29, 2020 at 1:04 PM
    #965
    rhaliuk
    rhaliuk Well-Known Member
    Ross
    CT
    2018 TRD SPORT DC SB
    TRD sport door badge, TRD coin bucket, D2S 5.0 HID projectors, XB5500K HID Morimoto Kit with Highbeam Splitter, DD SS3 PRO Yellow fog lights, TRD PRO Grill with TSS, MESO TRD PRO shift knob Stage 2 (ECT/Front Cam), Anytime F/R camera, 2020 TRD pro wheels.
    You are absolutely right. My camera is shit and I had to google to order a new one. They ignored my complaint about the camera. I even asked what other camera with wider angle and better quality would work.
    Just ordered a Natika camera based on tacomaworld reviews.
    NEIPA27[QUOTED] likes this.
  6. Feb 29, 2020 at 1:37 PM
    #966
    NEIPA27
    NEIPA27 Well-Known Member
    Florida
    2020 OR
    Out of my own morbid curiosity, did the the camera that came with your kit have the LED ring, and the nut with the notch cut out that wouldn't tighten? Lots of people got that one, including me, and had their complaints ignored. I emailed them asking for them to make it right, and their response was "Sorry, these things happen." World class customer service there.
    rhaliuk[QUOTED] likes this.
  7. Feb 29, 2020 at 1:41 PM
    #967
    rhaliuk
    Ross
    CT
    Yes!!! It wouldnt tighten and I had to squeeze the nut together. It still didnt fit right.
    Next time I wont get their camera.
  8. Feb 29, 2020 at 1:45 PM
    #968
    rhaliuk
    Ross
    CT
    I think they know exacty what they are selling. Is there anybody else who sells the same harness without a camera?
  9. Feb 29, 2020 at 1:54 PM
    #969
    NEIPA27
    Florida
    2020 OR
    That, I do not know. I'll be very interested if someone was, because you're looking at about five bucks worth of materials, plus the labor to put it together. Compare that to the price tag of the kit, and the stuff you have to buy yourself just to get it to work, and it's kind of infuriating.
  10. Feb 29, 2020 at 1:59 PM
    #970
    NEIPA27
    Florida
    2020 OR
    A lot of people on here said they tried to squeeze it tighter with pliers or vice grips and ended up breaking it. I was able to creep mine a little bit tighter with a bench vise without breaking it, but it didn't really fix the problem. The nut just alternated between extremely tight and loose with about every 90 degrees of turn, all the way down the shaft of the camera bolt. Useless.
  11. Feb 29, 2020 at 2:23 PM
    #971
    rhaliuk
    Ross
    CT
    FYI
    I used these connectors from Home Depot installing the camera kit. They work great and look clean. Packaging says they are waterproof (to some degree and if used appropriately).
    I used it for 2 wires connections and for 2smaller and 1 regular wire connections.
    Blackwolf likes this.
  12. Feb 29, 2020 at 4:28 PM
    #972
    rhaliuk
    Ross
    CT
    Just swapped the shitty anytimebc camera with Natika. They sent extra harness and goodies but all you need is the camera which comes with a 4 pin connection. Now thats what a front cam should look like!
  13. Feb 29, 2020 at 4:39 PM
    #973
    caribe makaira
    What model # is the Natika?
  14. Feb 29, 2020 at 4:40 PM
    #974
    rhaliuk
    Ross
    CT
  15. Mar 2, 2020 at 1:32 PM
    #975
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Dumb question, when you hook it up like this is the camera always powered on or does the switch in the kit turn it on/off? I've got an aux fuse box with plenty of empty slots so this would be super convenient, but the kit I got has the camera with the led's around the lense. Wouldn't want those on all the time.
  16. Mar 2, 2020 at 10:06 PM
    #976
    Papadave418
    Papadave418 [OP] Well-Known Member
    Yeah this version is always powered on, so you’d want to route the power through the relay so it powers on with the switch
  17. Mar 2, 2020 at 10:12 PM
    #977
    caribe makaira
    What does the relay in this setup do? Switch the feed? I mean since you stated both cameras are always ON.
  18. Mar 2, 2020 at 11:15 PM
    #978
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Yes.
  19. Mar 2, 2020 at 11:20 PM
    #979
    empty_space
    empty_space Well-Known Member
    Here's an ugly schematic I made when I first got my kit to understand what was going on. When you shift into reverse, the orange wire that goes to the HU goes HIGH (marked HU below). Diode blocks the signal from propagating through the switch to trip the relay, which will switch to the front camera.
    When you flip the switch to the FRONT position, you send a HIGH signal to the HU, which makes it show the camera screen. And at the same time, you energize the relay which flips the camera signal from back to front.
  20. Mar 2, 2020 at 11:32 PM
    #980
    caribe makaira
    You're missing the part when you want to see the Rear Cam or Front Cam without shifting into Reverse...don't see it in your drawing.
    Also, where or when does the front Cam have juice? I'm thinking only when selected...
