Anzo/Ebay Halo projectors - Output/pictures - ASAP
Discussion in 'Lighting' started by Swank, Dec 10, 2015.
  1. Dec 10, 2015 at 8:20 AM
    Swank
    Swank [OP] Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    Output pic in last post - I will not be buying these.
    Anyone have any pictures of these installed?
    Debating on these vs some stock headlights.
    Interested in seeing the output & some more pictures.
    I found one thread when @RearViewMirror had them on his 05-11, but i'm looking for a head on shot on multiple trucks if possible.
    I've searched here, and on Google and haven't found much.
    http://www.ebay.com/itm/For-2005-2010-Toyota-Tacoma-Dual-CCFL-Halo-LED-Projector-Black-Headlights-Set-/400662275081?fits=Model:Tacoma&hash=item5d49552409:g:UfkAAMXQVT9TE~I7&vxp=mtr
    or
    http://www.amazon.com/AnzoUSA-12128...e=UTF8&qid=1449763547&sr=8-52&keywords=tacoma
    Thanks y'all.
  2. Dec 10, 2015 at 8:52 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    CAN BE DELETED - THANKS - Output pictures in last post.
    Actually found some more photos, I like them.
    Just want to see light output shots.
    I know someone has these!
  3. Dec 10, 2015 at 9:06 AM
    chasten_beck11
    chasten_beck11 Well-Known Member
    Chasten
    Arab, Alabama
    2005 Blue Tacoma TRD off road
    3" lift kit, complete sound system, more to come..... just got this truck
    I wanna see light output too! I am planning on getting some but changing the bulbs to led and having the halos colorshifting
  4. Dec 10, 2015 at 3:34 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    I'm curious too. I tried to open the headlight to do a HID retrofit and completely screwed it up. I no longer want to do it.
  5. Dec 10, 2015 at 8:19 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    The first truck pictured was my old truck. Don't waste your money. Light output was meh at best.
  6. Dec 10, 2015 at 8:46 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    What's your definition of meh? I know they won't be like retro output, but was there a cutoff/decent amount of light. And was that with a HID kit or just the stock bulbs when you had it?
  7. Dec 11, 2015 at 3:30 AM
    RearViewMirror
    Craig Christ
    Just the bulbs that came with the lights themselves (non-HID). I forget what type of bulb they use in them but for the money they are more for looks than they are for light output. I would say that you get about 2/3rds of the light output of stock headlights and the cutoff isn't what I would call great. More of a "V" pattern instead of a straight line IIRC. It's been about 3 years since I owned that truck but I recall not being very impressed with them. Definitely not worth the money and IMO and are more for looks than anything. Your results may vary.
  8. Dec 11, 2015 at 4:56 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Okay cool, thanks for the info!
  9. Dec 11, 2015 at 7:41 AM
    RearViewMirror
    Craig Christ
    One other thing I forgot to mention... Mine had a tendency to fog when the temperature changed. Such as if it were relatively cool outside and I had the parking lights on (which is what activates the halos) and turned them off... the lights would get condensation inside right above the halos. Never affected anything and after the temp in the lights was the same as the outside temp it would go away. More annoying than anything.
  10. Dec 11, 2015 at 7:42 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Which brand of them did you have? The ebay or anzo? Usually I'll run a bead of silicon around the seal before I install any lights to help with the moisture problem.
  11. Dec 11, 2015 at 8:24 AM
    RearViewMirror
    Craig Christ
    Anzos. I don't think a bead of silicon will help with the condensation problem with these lights. They were sealed very well. It's just the nature of these lights... or so it seems to be.
  12. Dec 11, 2015 at 8:34 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Damn, alright. Thanks for the heads up!
  13. Dec 11, 2015 at 8:37 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Just wondering, why don't you like your retrofits?
  14. Dec 11, 2015 at 8:39 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    They're adjusted as high as they can be(light output doesn't shine far enough) and i'm too lazy to have to take them back apart and redo them.
  15. Dec 11, 2015 at 8:41 AM
    ChadsPride
    I understand, I'm looking at a similar model for my 15' just dont want to waste 500$ then realize i should have saved for some expensive retros. Somebody is bound to have bought these and taken output pics...
  16. Dec 11, 2015 at 8:45 AM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Wherever you buy from, make sure they have a decent return policy. Try them out and if they're not to your standards, return them. :D
    ChadsPride likes this.
  17. Dec 11, 2015 at 12:51 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    i went with the spyder lights.... i can say the stock H1 halogen bulb that comes in them sucked big time for output. i swapped them out to HID's relatively quickly. that was the plan from the start. low beam side was easy. the high beam side, the mounting plate for the bulb has to be modified if you put HIDs in them. from a safety aspect, its probably better to leave the H1 halogen bulb in the high beam side. the warm up period for HID's in the highs can cause issues when switch over to them. no real light output for a few seconds.... kinda dangerous at highway speeds. did a HID swap for a friend on his older Chevy. he went the all HID route. quickly realized that he needed a modification done so he didn't lose light output when switching.
  18. Dec 11, 2015 at 4:11 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    That's crazy, I plan to run HIDs in them as well. Thanks for the input. I think I may order them and give them a chance.
  19. Dec 11, 2015 at 4:27 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    bump anyone have output pictures??
  20. Dec 11, 2015 at 5:09 PM
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Per @Moose1988 - I will not be buying these headlights. Thanks for the picture!
    Output:
