Apex Designs RPV (Rapid Precision Valves)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chase8059, Nov 1, 2021.
  1. Nov 1, 2021 at 7:27 AM
    Chase8059
    Chase8059 [OP] Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Has anyone use these puppies on the trucks?
    https://www.apexdesignsusa.com/products/rapid-precision-valve
    I air down frequently as I'm on the beach about every weekend from Spring to Fall and hate spending time deflating my tires. I currently use some screw on deflators that work well, but these look like I could down my air down time to about a minute total.
    I was curious if anyone has any real world experience with them and could offer a review.
    I did have a question about their chuck compatibility section. I can't imagine they require a special chuck to inflate, but they have 4 types listed. I'm curious if those chucks are for rapid inflation instead of standard.
    TIA
    Chase
  2. Nov 1, 2021 at 7:37 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    No experience with them myself, but looks like a cool idea and a time saver if you air down regularly.
    Wonder if our TPMS systems are compatible?
  3. Nov 1, 2021 at 7:41 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Ive heard they work well. But best practice is still doing one tire at a time. They let down FAST. Turn your back to long and your wheel will be on the ground.
    Chase8059[OP] and SR-71A like this.
  4. Nov 1, 2021 at 7:42 AM
    Chase8059
    Chase
    ESVA
    They aren't, they sell adapters that require you to cut up the TPMS sensors to fit. Not a deal breaker, but brings the cost up to about $150 for a set of 4.
    SR-71A[QUOTED] likes this.
  5. Nov 1, 2021 at 7:44 AM
    Chase8059
    Chase
    ESVA
    Yea, I think I saw it will take a 37 from 30psi to 15psi I'm about 14sec. My skinny 33s will be super quick :rofl:
    I already have to go around to each tire to add a deflator and then wait. So going one by one, for a few seconds each, would be much quicker.
    jlemmond[QUOTED] and SR-71A like this.
  6. Feb 13, 2022 at 1:32 PM
    Chase8059
    Chase
    ESVA
    I ended up getting a set for Christmas and just had them installed. Have yet to test them as we haven't made a trip to the beach, but fishing season isn't too far off so I'll report back.
    I did have some trouble with the shop installing them. Had to take the truck back x2 and have them reseated as they kept leaking. The shop did get them set correctly and from the brief usage I've had of overfilling and then bleeding them to get to my desired pressures these things are insanely quick.
    SR-71A likes this.
  7. Feb 13, 2022 at 2:19 PM
    TacoTuesday1
    SoCal
    for now I have a Staun automatic deflator
  8. Feb 13, 2022 at 2:39 PM
    Chase8059
    Chase
    ESVA
    I have some Amazon knock offs and they worked great. They would still take about 5mins or so to air down from 40 to 18/20.
  9. Feb 13, 2022 at 2:54 PM
    TacoTuesday1
    SoCal
    as long as they work. Runnin4Tacos even sells some cheaper ones.
    was always paranoid an aftermarket might not be reliable and air down to the correct pressure but it’s probably not hard to copy the design (spring, etc) and if yours works well then that’s a good deal
    I might need to add a pro shop hand gauge even if just to use for measuring and adjusting
    Because the gauge on my ViAir 88P compressor is pretty vague
    Like if I try to air them back up to 29psi door spec cold / +4? Hot psi (1+ mile driving) = 33psi on all 4, the ViAir gauge is not accurate enough to get exactly that and would need adjusting later
  10. Mar 7, 2022 at 8:52 AM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 Supercharged DCSB TRD OR 4x4
    Yes
    @Chase8059 have a good chance to use these yet? any issues with the TPMS adapter? looking at buying a couple sets for myself
  11. Mar 7, 2022 at 9:07 AM
    Chase8059
    Chase
    ESVA
    Yes, the deflate time for me (255/80r17) from 35 to 18 is about 6sec per tire. I probably spend more time unscrewing the cap and then screwing it back on then actually deflating.
    My local tire shop didn't want to touch these because of the TPMS work but I found another shop that does more general work and they had no issue. So far I haven't had an issue with TPMS and I'm really happy with how fast these deflate.
    Even the fiance noted how quickly I can air down when we go to the beach which is about every weekend.
  12. Mar 7, 2022 at 9:39 AM
    HappyGilmore
    Huntsville, AL
    Yes
    Awesome news - thanks for sharing man!!
    Chase8059[QUOTED][OP] likes this.
  13. May 22, 2023 at 5:32 AM
    SR-71A
    Zack
    Southern Maine
    Bringing this thread back with another follow-up. It sounds like you took the factory TPMS and cut the stems off along with the Apex OEM adapter kit? Or did you get new TPMS that bolt to the standard RPV?
  14. May 22, 2023 at 6:59 AM
    Chase8059
    Chase
    ESVA
    Correct, you have to remove a few mm from your factory TPMS stems to get them to work with the adapter kit. Apex designs sends out the instructions with the TPMS adapter kit. I could have done it, but I don't have the equipment to remove and reseat my tire and rim so I had a shop do it.
  15. Jul 31, 2023 at 9:50 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Bumping an old thread here but it's really the only thread on the RPV's. I just had these installed and they work great. I opted to waste an extra $100 and buy some Schrader EZ-Sensor 33500 TPMS and had the shop clone my stock ones because I didn't want to fuck around with shaving them.
    Chase8059[OP] likes this.
  16. Jul 31, 2023 at 11:36 AM
    SR-71A
    Zack
    Southern Maine
    Thanks for bumping it, I forgot to follow up after getting mine installed. These things frigging rock! Skinny 33s from ~35 psi down to about 20 in roughly 10 seconds
    I opted to waste even more money by getting the Schrader / Ateq S41 programmer tool so now I can do all my own TPMS :D
  17. Jul 31, 2023 at 12:55 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Would they still be worth it if you owned a set of stauns that did the job good enough? Still kicking around the idea of picking some up.
  18. Jul 31, 2023 at 1:01 PM
    SR-71A
    Zack
    Southern Maine
    stauns?
  19. Jul 31, 2023 at 1:08 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I've had the RPVs for a while now and def one of my top 5 mods. I go from 35 -> 15psi in about 10 seconds with my 285s. I really like that you can attach a gauge to watch the psi drop in live time.
    SR-71A likes this.
  20. Jul 31, 2023 at 1:11 PM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    I've been running these with my racelines since I installed them several years ago, and they are by far one of the best and most used mods I have ever made. Not only super fast and convenient to air down, but they also aid in fast air ups due to the unrestricted flow.
    And they are somewhat local to me, so that seemed like a win win to support local when it makes sense.
