App for truck stats?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jan 31, 2019.
  1. Mar 14, 2019 at 6:26 PM
    #81
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Style > frame > background color > back inner and outer color: 00000000
    This will be the setting for the display in the foreground.
  2. Mar 15, 2019 at 6:05 AM
    #82
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Easy enough! I tried looking for all sorts of stuff, and it's as easy as that. Didn't realize that would make it clear......thanks!
  3. Mar 15, 2019 at 8:12 AM
    #83
    Rujack
    Glad it worked out
    ihatemytruck[QUOTED] likes this.
  4. Nov 20, 2019 at 7:14 AM
    #84
    JasonCz
    JasonCz Well-Known Member
    2020 TRD PRO 6MT
    I see the "Toyota 2019 Enhanced Diagnostics" listed as an available package in OBD Fusion.
    Since I have a 2020, do I need to wait for a 2020 package to be released, or would the 2019 version work properly?
  5. Nov 20, 2019 at 8:00 AM
    #85
    ihatemytruck
    Dave
    Southern California
    @JasonCz good question.....might wanna email the company. I have before and they got back to me pretty quick.
  6. Nov 21, 2019 at 8:04 AM
    #86
    JasonCz
    2020 TRD PRO 6MT
    For anybody with a 2020, this is what OBD Fusion recommended:
    We have a 2019 Toyota Tacoma 3.5 L in our enhanced database. This may work with your vehicle. You can read about setting up and using the enhanced add-on on the page at the link below:
    https://obdsoftware.force.com/s/article/enhanced-diagnostics-in-obd-fusion
    Please note that you should change the vehicle year to 2019 for your 2020 Tacoma in Settings > Vehicle Editor in order to get the add-on to work with your vehicle.
    ihatemytruck likes this.
  7. Nov 21, 2019 at 8:19 AM
    #87
    ihatemytruck
    Dave
    Southern California
    Did you try it? Seems like it will work.
  8. Nov 21, 2019 at 8:26 AM
    #88
    JasonCz
    2020 TRD PRO 6MT
    My OBD reader is being delivered today. I will post my results in this thread.
    The only reason I questioned if it would work was because they offered the add-on for every model year, not just every generation. This implied to me that there were changes.
  9. Nov 21, 2019 at 10:14 AM
    #89
    ihatemytruck
    Dave
    Southern California
    I hear ya, I would of waited to get the add on until I knew if it worked too.
  10. Nov 22, 2019 at 5:25 AM
    #90
    JasonCz
    2020 TRD PRO 6MT
    I tested the OBDLink MX+with OBD Fusion and the 2019 Toyota add-on (on my 2020 Tacoma), and everything seemed to work fine. I did have to change the vehicle year manually to 2019, per OBD Fusion's instructions.
    I tested Toyota specific items such as the radar cruise distance, commanded acceleration, set speed, hvac info, etc. and it all seemed to work fine.
    Overall I'm very impressed by the OBD reader, OBD Fusion, and the Toyota add-on, and would recommend it to anybody wanting to snoop on all the info the ECUs are collecting.
  11. Nov 22, 2019 at 9:20 AM
    #91
    ihatemytruck
    Dave
    Southern California
    It really is a good product.
  12. Mar 18, 2021 at 11:10 AM
    #92
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    There does seem to be a way to increase the charging voltage wit VF/OV tuner. There is a thread about it.
  13. Mar 18, 2021 at 11:12 AM
    #93
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. I have flashed a few Tacos with AGM update now that we have the ability.
    The resources around here are pretty stellar.
    :cheers:
  14. Mar 18, 2021 at 11:30 AM
    #94
    Sunsetsearider
    San Francisco
    I just did mine and am trying to figure out what all these various voltages are reading. Unfortunately, my test meter crapped out and I’m waiting for a replacement. I might go back to stock to see what they all read before. It’s nice to see the alternator duty ratio. I left those settings alone and just did the numbers from the other 2017 trucks that were working. My battery guy is excited to see the changes. He is mostly a boat guy and is very knowledgeable about the finer details of batteries and charging.
  15. Mar 18, 2021 at 11:33 AM
    #95
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think the best way to test this is to monitor it while driving? I told my folks to monitor with an OBD reader or power port voltage read out for the first week or so and again when the weather changes.
    It would be cool to here the thoughts from your battery guy.
  16. Mar 18, 2021 at 11:42 AM
    #96
    Sunsetsearider
    San Francisco
    I am, but the various sources all have different readings. I did just run it down a little and the output duty went to 100% until it came back up.
  17. Mar 18, 2021 at 11:44 AM
    #97
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahaha! They do.
    I would use just one source and compare it to the numbers at the battery terminal. Basically calibrate it to the source and go from there.
    If your device is off by 0.2v compared to the terminals, then just add / subtract that in your head.
  18. Mar 18, 2021 at 11:50 AM
    #98
    Sunsetsearider
    San Francisco
    My replacement meter should get delivered today. At least all the numbers seem within acceptable realm.
    tonered[QUOTED] likes this.
