APR 4.0 Fuel Rail Upgrade Kit
Discussion in 'Performance and Tuning' started by Torspd, Mar 30, 2012.
  1. Jul 9, 2013 at 11:16 AM
    #41
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Good timing and lucky man you are! Every step and you are that .uch closer to a fully built engine! :D
  2. Jul 9, 2013 at 11:37 AM
    #42
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Ya an that much poorer lol
  3. Jul 9, 2013 at 11:56 AM
    #43
    Brunes
    Brunes abides.
    Rotorhead
    Around
    in the wallet...but that much richer in horsepower...
  4. Jul 9, 2013 at 12:50 PM
    #44
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Haha well said!!!
  5. Jul 9, 2013 at 7:25 PM
    #45
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    So a little birdie told me the fuel lines apr makes arnt much better than stock ones
  6. Jul 9, 2013 at 7:33 PM
    #46
    Torspd
    Tor
    The Great America!
    Did you just buy the rails or more?
    I only purchased the rails. Then, got rid of all the fittings that came with it, for larger ones. As I am going to run -8AN or -10AN, from the pump.
  7. Jul 10, 2013 at 5:28 AM
    #47
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Yup that's what I'm gonna fo
  8. Jul 10, 2013 at 11:42 AM
    #48
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    So I had 2 order the bolts that come in from the side that bolt to the mains so when I get those ill be able 2 have a short block by Saturday. Also got info about my pistons they can hold 125hp per cylinder an they have the right clearance piston to cylinder wall clearance for a turbo application with 25psi and the rings have been gapped perfectly. I just ordered the whole fuel rail setup regulator an all this truck is gonna be insane
  9. Oct 29, 2013 at 10:10 PM
    #49
    Rakk187
    Rakk187 New Member
    05 Trd sport
    K&n cai, uni-chip piggy back ecu, banks monster exhaust, full system with kicker L7 10s in custom box, u2 22" rims with nitto 420s 275 22
    Can someone post the link that I can order this fuel rail system from I cannot find it
  10. Oct 30, 2013 at 4:20 AM
    #50
    Torspd
    Tor
    The Great America!
