AR15xAR10s N180 Winter Beater/Party Truck 2000 Highlander 5spd
Discussion in '4Runner Builds' started by AR15xAR10, Aug 26, 2019.
  1. Sep 28, 2019 at 3:31 PM
    #341
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Get one. I freakin love it
  2. Sep 29, 2019 at 2:02 PM
    #342
    AR15xAR10
    O2 sensor ordered. I sure hope thats all it is
  3. Sep 29, 2019 at 4:04 PM
    #343
    AR15xAR10
    So i learned some things about 3.4s in my extensive research about my check engine light
    The coolant temp sensor is bad. It keeps giving the ECM a bad reading on engine temps, thus the motor runs rich and burns up the O2 sensors/cats
    Its been like this for so long that the cats will need replaced. But i’m not replacing them until after i replace the coolant temp sensor and the upstream o2 sensor. After i do that, the motor should run correctly and then the bad cats will cause the downstream o2 sensor to fail telling me its finally time to finish fixing the exhaust. Thats my plan and i’m sticking to it. Ordering a temp sensor.
  4. Sep 29, 2019 at 4:05 PM
    #344
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    How much is the temp sensor
    AR15xAR10[OP] likes this.
  5. Sep 29, 2019 at 4:47 PM
    #345
    AR15xAR10
    Dunno. Maybe $25
    You gotta calm down sir... lol
  6. Sep 29, 2019 at 4:48 PM
    #346
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Stuck thermostat typically sets that code.
    Or the ect is reading incorrectly.
    AR15xAR10[QUOTED][OP] likes this.
  7. Sep 29, 2019 at 5:14 PM
    #347
    AR15xAR10
    Think it might be stuck open? Because this thing heats up and cools just fine....
  8. Sep 29, 2019 at 5:33 PM
    #348
    Empty_Lord
    Dan
    stuck open will eventually reach operating temp. but it takes longer. which in turn throws that code. how long does it take to make it to the operating temp on the gauge.
  9. Sep 29, 2019 at 5:34 PM
    #349
    AR15xAR10
    Very quick. Completely normal.
    I’m almost certain its the coolant temp sensor on the intake by the fuel rails
  10. Sep 29, 2019 at 5:35 PM
    #350
    Empty_Lord
    Dan
    Ah if it’s warming up quick it’s probably that sensor. Live data should show it
  11. Sep 29, 2019 at 6:45 PM
    #351
    AR15xAR10
    My scanner is so basic it doesn’t show much, but i appreciate the help! Very much :)
  12. Sep 29, 2019 at 6:47 PM
    #352
    Empty_Lord
    Dan
    i have the older version of the one you have. should have live data. The engine ECT sensor will show up as ECT. ideally 180-200 ish is what your looking for. the gauge sensor is the one at the back of the engine so the only way to see the computers ECT sensor is with the scan tool
  13. Sep 29, 2019 at 6:59 PM
    #353
    AR15xAR10
    JennJenn likes this.
  14. Sep 29, 2019 at 7:00 PM
    #354
    AR15xAR10
    Oh okay, i’ll have to check into it
  15. Sep 29, 2019 at 7:01 PM
    #355
    JennJenn
    JennJenn Remembering Rick ❤
    Jenn aka (dzzyneon)
    Boise, Idaho
    2021 Army Green Trd sport dclb!!~Sold~2008 Indigo ink TRD Sport DCLB!!
    Thank you Mason! <3
  16. Sep 30, 2019 at 8:01 AM
    #356
    AR15xAR10
    Absolutely, i hope it was magical :D
  17. Sep 30, 2019 at 8:02 AM
    #357
    AR15xAR10
    Its raining this morning, went to move the 4runner, alternator is howling again.
    I remember when @Pyrite_Pirate s alrernator was going bad, he had troubles when it rained. So i guess i should just fess up and buy one....
  18. Sep 30, 2019 at 11:14 AM
    #358
    AR15xAR10
    Just drove it two towns over to class without issue....so maybe i should wait until the alternator shows a bigger problem?
    Or when it starts getting colder maybe it’ll die
  19. Oct 1, 2019 at 2:34 PM
    #359
    AR15xAR10
    Picked up a duralast coolant temp sensor today. Gonna slap that in later.
    Also my O2 sensor and gasket should be here tomorrow
    greengen1 likes this.
  20. Oct 1, 2019 at 7:27 PM
    #360
    AR15xAR10
    went ahead and replaced the coolant temp sensor. Took maybe 15 minutes.
    Cleared the codes and drove it back and forth between the next town over. Varying speed and load. No more check engine light. I hope it was that simple.
    I think i’ll still go ahead and replace the o2 sensor when i get it just to be safe. Its leaking around the one thats in there anyway. So i might as well. Its already paid for.
    Alternator howling is also getting worse. So i might as well just order one of those too
