ARB Bumper Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IndyBill, Apr 21, 2017.
  1. Apr 22, 2017 at 5:33 PM
    IndyBill
    IndyBill [OP] Well-Known Member
    Bill
    2013 Spruce Mica Tacoma TRD
    3" lift, 285 75 R16's, ARB front end, Warn 9000K winch, black leather interior, heated seats, alarm, TonnoPro bed cover.
    @vssman @MikeyMcFly super great info. I now know what I need to do. I'm going to get it fixed so it is correct. This is how TW should work. I can't thank you all enough.
    I will be at Moab next Spring. Perhaps we shall all meet. Cheers!
  2. Apr 22, 2017 at 5:44 PM
    icegrill
    icegrill Well-Known Member
    Oregon
    2015 Tacoma TRD (sold) bmw F80 M3 current
    Make sure and cut it a few mm longer also.... a little more wiggle room.
    How are people splicing the marker lights these days? I still haven't hooked mine up.
  3. Apr 22, 2017 at 6:09 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I didn't use mine @ all. Replaced then with a Philips Daylight 4 LED DRL kit. Gave me a more modern look up front.
  4. Apr 23, 2017 at 9:37 AM
    mizhop
    mizhop Well-Known Member
    central IL
    05 Prerunner, 2WD 6spd(mine) & '95 DLX 2WD (his)
    Thanks for the explanation, Mikey! It sounds like you're still using the ARB foglight housings, somehow...? (It's entirely possible I completely misunderstood that.) There's a slew of 4" foglights around, but can't figure out how to make them work with the ARB mounting holes, unless I have my nephew fab me up something.
    I appreciate the guidance!
  5. Apr 23, 2017 at 10:42 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Well, I was (and still would be...). I just cut / splice the tab of the long life H3 and hoped I wouldn't have to tear into it all that often. The Lamin-X film was to give me the yellow fog color I desired. I had previously done it with yellow bulbs but after burning through a couple with the ARB assemblies, I just said eff it.
    The other thing I did to make life easy was to splice a male H11 connector onto the ARB lamp wiring so it would interface with my OEM wiring without cutting / splicing anything on the truck. Made for a quick removable of the whole fog lamp assembly in a pinch.
  6. Apr 23, 2017 at 10:50 AM
    mizhop
    central IL
    Thanks again, Mikey, that helps a lot! :thumbsup:
  7. Apr 23, 2017 at 11:14 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    No problem. Just verify your bulb type before you buy a male connector (if you do) as I believe the 05-11 trucks had different fog bulbs than the 12-15.
  8. Apr 23, 2017 at 11:34 AM
    Cuntender
    Cuntender Active Member
    2014 dcsb
    Do you guys worry about the air bags at all when installing these?
  9. Apr 23, 2017 at 11:51 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    ARB claims it's airbag tested. In my aacident my bags didn't blow but I don't know if they would have otherwise.
  10. Apr 23, 2017 at 8:28 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    so much better with with the bumper cut :D
    love cutting up shit :D
  11. May 10, 2018 at 4:16 PM
    oldnotdead
    oldnotdead Member
    Jeff
    southern Ma.
    15 tacoma
    Did you guys have to go with stiffer springs up front. I know those bumpers are heavy if not did you get any sag with the stock springs? Love the classic ARB look but thinking of going with an aftermarket aluminum one .
  12. May 10, 2018 at 4:29 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The bumper adds 131lbs net additional weight without a winch. I didn't drop very much at all on my stock springs, maybe 3/16".
  13. May 10, 2018 at 4:32 PM
    oldnotdead
    oldnotdead Member
    Jeff
    southern Ma.
    15 tacoma
    Thanks! Already rubbing a bit at full turn with 2" toytec spacers and 285's.
    Should be OK once I due the cab mount chop.
    drewnali likes this.
  14. May 10, 2018 at 4:34 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Most running 285s need to flatten the pinch weld or cab mount chop regardless of bumper type or lift.
  15. May 10, 2018 at 4:37 PM
    #35
    oldnotdead
    oldnotdead Member
    Jeff
    southern Ma.
    15 tacoma
    True I've just ben putting it off. Lol
  16. May 10, 2018 at 4:57 PM
    #36
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    If I remember right the grill bolts/clips to the piece you cut off and keep.
  17. Jun 11, 2019 at 9:04 AM
    #37
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Reviving a dead thread. Does anyone have the PDF instructions?
    llamasmurf likes this.
  18. Jun 11, 2019 at 12:02 PM
    #38
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    trktwo and 20workman13 like this.
  19. Jun 11, 2019 at 12:50 PM
    #39
    20workman13
    20workman13 Well-Known Member
    Loveland, Colorado
    2015 Tacoma DCLB
    llamasmurf[QUOTED] likes this.
  20. Jun 11, 2019 at 12:52 PM
    #40
    llamasmurf
    Wes
    Northern Ontario
    Yep took lots of pics, ill put some here. All of them are in my build thread.
    All modifications were made to the truck, none to the bumper.
