ARB CKMA12 problems
Discussion in 'Technical Chat' started by m.reed.1, Feb 5, 2014.
  1. Feb 5, 2014 at 7:49 PM
    m.reed.1
    m.reed.1 [OP] Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    hey, I'm having slight problems with my arb compressor. I have everything wired the way it should be following the ARB wiring diagram. I have a 40amp relay and a 40amp fuse protecting the battery. I have the compressor wired so I have an in cab switch. I will try to draw out my diagram and get it posted. The compressor works just fine if its working, but once the pressure switch reaches the psi limit and cuts off, the compressor shuts off like it is suppose to. about 5 seconds later, the 40amp fuse blows... not sure whats causing this.
  2. Feb 5, 2014 at 9:14 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    wiring as of right now, the 40amp fuse is the one that continues to blow after the pressure switch turns off the compressor.
  3. Feb 5, 2014 at 10:41 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    That circuit does not look right. The switch should go to ground, not to power.
  4. Feb 5, 2014 at 11:07 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Are the black and black/white wire both going to the neg bat terminal?
    Just wire the harness as listed in the arb instructions. If everything is exact email arb, they have awesome tech support.
  5. Feb 5, 2014 at 11:42 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    I did not have an arb wiring harness, nor lockers so I did not need all the extra on a arb harness, so i followed and made my own off of their specs. No they are not grounded to the battery terminal but they are grounded to where the battery is grounded to on the truck's inner fender
  6. Feb 6, 2014 at 7:44 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Can’t believe I have a turd gen.
    The switch supplies 12v to the pressure switch, which then if below the set PSI completes the circuit at the relay to turn the compessor on and off when the set pressure is reached....:notsure:
  7. Feb 6, 2014 at 12:06 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    Bump. :notsure:
  8. Feb 6, 2014 at 12:41 PM
    tan4x4
    Rick
    Folsom, CA
    The power comes from the relay. The manual switch, and pressure switch simply interrupt the path to ground.
    What relay are you using? I don't think its wired up correctly as well. When I installed an ARB air locker, I did not use the ARB compressor, I set up my own compressor and control circuitry. A relay is an electrical switch, where a low-amp circuit (primary) controls a high-amp circuit (secondary). The manual switch and pressure switch are hooked up the the primary. The compressor is hooked up to the secondary. This is my diagram of my setup. Note the relay wiring:
    Hope this helps.
  9. Feb 6, 2014 at 1:05 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
  10. Feb 6, 2014 at 1:08 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
