ARB CKMTA12 Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, Jun 10, 2017.
  1. Jun 15, 2017 at 10:24 AM
    DarkestCon
    DarkestCon Well-Known Member
    DC
    SF Bay Area
    2017 White Tacoma TRD Off Road
    Bone Stock
    @OdiN1701 Thanks for the write up, Ill be doing the same install myself.
    Do you have a link for that T that you used on the compressor. Is the part that goes into the compressor a male 1/4 NPT as well or some other thread?
  2. Jun 15, 2017 at 10:30 AM
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    DarkestCon[QUOTED] likes this.
  3. Dec 21, 2017 at 10:21 AM
    KumaMoose
    KumaMoose Member
    Sorry for the Necro, What relay did you use for this ?
    Thanks a bunch!
  4. Dec 21, 2017 at 10:30 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Old thread, but damn, it's exactly what I've been looking for.
  5. Dec 21, 2017 at 10:31 AM
    OdiN1701
    Colorado
  6. Dec 21, 2017 at 10:44 AM
    KumaMoose
    KumaMoose Member
    Thank you :D
  7. Jan 22, 2018 at 2:08 PM
    madmanxing
    madmanxing Well-Known Member
    2017 Cement Tacoma Trd Pro
    for the record, you dont need to use any relays.
    there are relays in the Compressor. you will see them once you take the cover off.
    If there was 8 Amps going through the switch wire that came through your firewall why would ARB make it so thin?
    just pointing it out for others to be helpful! :oops:
    _gray_knight_ likes this.
  8. Jan 22, 2018 at 2:09 PM
    OdiN1701
    Colorado
    I'm just going by what is documented, and they never responded to my inquiry....so I'm doing it this way.
  9. Jan 22, 2018 at 2:10 PM
    madmanxing
    i called them :D
  10. Jan 22, 2018 at 2:11 PM
    OdiN1701
    Colorado
    They didn't respond, so :)
  11. Feb 20, 2018 at 8:43 AM
    OdiN1701
    Colorado
    An interesting bit of information.
    My wife's car had a flat tire this morning so I fired up the compressor to air it up so she could at least drive it to get new tires (the tread was pretty low let alone the leak).
    Anyway I turned on the compressor and kept hearing a loud sound - it was the safety valve blowing out over and over. Well it was also -8° this morning so apparently when it's that cold the regulator or whatever shuts off the compressor does not like to work. I don't know what exactly would have happened without the safety valve, but at least it did it's job and didn't let the compressor over-pressurize itself. Once it was warmed up after filling the tire it stopped when it was supposed to.
  12. Feb 20, 2018 at 9:11 AM
    mrretep
    mrretep Well-Known Member
    CA
    2017 TRD OR DCLB
    sweet, install. I want one of these. But I'm concerned about fitment in this location with a dual battery setup in the future.
  13. Feb 20, 2018 at 9:17 AM
    OdiN1701
    Colorado
    Yeah I'm not sure I'll run dual but they also make side-by-side mounts for the driver side battery location.
  14. Jun 21, 2019 at 9:22 AM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    This is old, but any con to just using add a fuse for the 8amp line needed for the switch?
  15. Jun 21, 2019 at 9:31 AM
    #35
    OdiN1701
    Colorado
    Where? Supposedly it isn't 8A, but ARB never responded to my questions so I don't know what it is. I just don't like running high amp wire through the firewall.
  16. Jun 21, 2019 at 9:43 AM
    #36
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    In their instructions, "The desired outlet should supply positive 12VDC for a CKMAT12 OR 24VDC for a CKMAT24, be fused at a minimum of 8 amps, and be live only when the vehicle ignition key is in either the 'ACC' position or in the 'ON' position."
    This is where I'm getting the idea of just doing add-a-fuse to the switch. I'll try to give them a call as this is where I'm kinda stuck. Doing the driver side bed mounting.
  17. Jun 21, 2019 at 10:13 AM
    #37
    OdiN1701
    Colorado
    Well you need the inline fuses for the main power. Then you need the power to switch it on. Another poster said there were relays in the compressor itself, but I ran off another relay to flip on power. It may not have been needed. You could probably just do the add-a-fuse as from other replies it doesn't sound like the power switch wire really is high amp - I'm not sure why they state to fuse it at a minimum of 8A.
  18. Jun 21, 2019 at 5:02 PM
    #38
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Yeah i saw that comment a few post up. Thanks!
  19. Jul 26, 2019 at 4:26 PM
    #39
    tommytrdpro
    tommytrdpro Member
    T
    2018 trd pro
    For bedside installation, where are folks attaching the ground wire under the bed?
