ARB Compressor Mounting Schemes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tomtom, Jun 1, 2013.
  1. Jun 4, 2013 at 9:39 AM
    tomtom
    tomtom [OP] Well-Known Member
    The Desert SW
    2012 FJ
    I may put it in that spot for now until I can get the shelf built. Tired of having paid for a front locker and still running it open.
  2. Jun 4, 2013 at 1:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Rugged Ridge 3" LED Pods w/Amber covers Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    FWIW, there is room for the twin ARB if you don't have ABS. :D It is a tight fit. We did have to move the control module and cruise controller over a bit to make enough room.
  3. Jun 4, 2013 at 1:30 PM
    TRIAD Powderworks
    TRIAD Powderworks Powder Coater/ Dirt Thrower
    Andrew
    San Diego CA.
    97 LT 5 Lugger
    Just wanted to let you know I have now spent the entire day at work watching these videos...
    I will now sell my LT 2WD and buy a 4WD and armor the shit out of it..
  4. Jun 4, 2013 at 1:36 PM
    BigOly
    BigOly Well-Known Member
    Bay Area, NorCal
    14 MGM DCSB TRD/OR 4x4
    lol, I'm on my lunch break right now and too scared to revisit that site. Productivity here will go way down if I do :p
  5. Jun 4, 2013 at 7:14 PM
    tomtom
    The Desert SW
    2012 FJ
    Tonight I did another hour's worth of work. Took the metal I already bent and cut it down a little and drilled holes for the side bolts:
    And so two mounting options available, 1.:
    and 2.:
    I like #2 better. Now, just have to figure out how to anchor it on the wheel well, make better measurements and fab up the end product.
    I'm still looking at putting it on the firewall like BigOly posted but I'm perplexed as to how they did it. Going to see if there is a write-up for it.
  6. Jun 4, 2013 at 9:24 PM
    tomtom
    The Desert SW
    2012 FJ
    Hmmm, reading the paperwork on the compressor, I can rotate the manifold to re-orient the solenoid and pressure holes relative to each other. This solves one riddle.
    I'm still attempting to figure out how the compressor shown sits so low. I wonder if they cut the pinch seam. When I hold mine in the same position, the mounting feet touch the hood seal.
  7. Jun 5, 2013 at 5:09 PM
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    hmmm good luck haha
  8. Jun 9, 2013 at 1:51 PM
    tomtom
    The Desert SW
    2012 FJ
    I think I found my solution. Was over at Silas' and checking out the latest trail wear from Moab. Peaked into his engine bay to check how he routed his locker air line. Noticed a module sitting in the big open space I have. Looks to be a cruise control unit. Anyways, it is sitting on this nice, heavy duty bracket. So, I'm off to the dealership tomorrow to order the bracket and I'll deform it into a nice shelf.
    Should've snapped a picture while I was there. Maybe if he stops by later to check out the new skidplate.
  9. Jun 9, 2013 at 8:25 PM
    tomtom
    The Desert SW
    2012 FJ
    Part No. 88291-04020, just ordered it. Hopefully it'll be here by the weekend and can get this going again.
  10. Jun 14, 2013 at 3:37 PM
    tomtom
    The Desert SW
    2012 FJ
  11. Jun 15, 2013 at 8:08 PM
    tomtom
    The Desert SW
    2012 FJ
    Test fit the cruise control bracket:
    And the compressor:
    Have to do some trimming on the bracket and possibly cutting and bending but going to work.
  12. Dec 28, 2014 at 3:40 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Know I'm way late to the game... but for what it's worth, I was thinking I'd put it there when I ordered it, but when I got it, it's way too heavy to put there without putting nuts on the other side of the metal... I ended up putting it in the same place the OP did, but just shared a bolt with the electronic unit right next to it (toward the front of the truck), and drilled on more hole and bolted it... easy installation.
  13. Dec 29, 2014 at 9:01 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
  14. Dec 29, 2014 at 2:56 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Are the ARB's not reliable???
  15. Dec 29, 2014 at 3:35 PM
    #35
    tan4x4
    Rick
    Folsom, CA
    At least twice, I've seen guys on the Rubicn with a failed ARB compressor. Really pissed off, with all the money they spent on the locker, and can't use it. This was many years ago, so maybe the units are better now.
  16. Apr 2, 2015 at 6:25 PM
    #36
    dirtymike420
    dirtymike420 Well-Known Member
    TEXAS
    TuRD off oad
    So what happened?
