ARB compressor wire melting?
Discussion in 'Technical Chat' started by Naveronski, Feb 26, 2023.
  1. Mar 2, 2023 at 3:57 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    This wouldn’t be the first time they haven’t been much help with their products. I read some other testimony with them not being too helpful with their old crappy locker seals and just blaming the installers before they finally revised the seal design.
    They likely outsource their harnesses to bulk supplier who builds to spec. They seem to outsource a lot more of their stuff than people realize. They don’t build those UCAs their logo is on. A harness with quality crimped connections, quality fuses and wire shouldn’t just melt all the sudden.
  2. Mar 2, 2023 at 4:01 PM
    MGMDesertTaco
    Can you get a replacement harness with fuses from ARB?
  3. Mar 2, 2023 at 6:59 PM
    Naveronski
    Naveronski [OP] Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    If they don't replace it, I'll cut off the problem area and the fuses, then replace with a more robust solution.
    That's disappointing.
    I don't mind the outsourcing; many companies outsource components to specialty firms, but they still need to stand behind their products.
    wi_taco, Bivouac and deanosaurus like this.
  4. Mar 3, 2023 at 3:27 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Thanks for posting this.
    I'm doing OBA soon and it's good to know there's no point in paying the ARB premium anymore.
  5. Mar 13, 2023 at 7:09 AM
    Naveronski
    Fort Worth
    Well, ARB USA has gone dark.
    Looks like I'll have to replace this myself.
    MGMDesertTaco and Bivouac like this.
  6. Mar 13, 2023 at 7:48 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Sucks. These days I pretty much assume that warranty/customer service is gonna be worthless. /-:
    GTGallop likes this.
  7. Mar 13, 2023 at 11:46 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Are you good to go or do you need help?:thumbsup: Feel free to DM any questions if you were closer I would be glad to help in person DFW is just a tad to far to stop over for a few hours.
    I would guess your response was from a clueless Customer Service person looking at a computer screen .:evil:
    Which is as close to the real product as they have ever been. The sad fact far to much Customer service is now in that fashion.:annoyed::annoyed:
    Good Luck!
  8. Mar 13, 2023 at 11:53 AM
    Naveronski
    Fort Worth
    Thank you for the offer and well wishes. Current plan is to cut fuses out, go from the battery to two 40a Bussman circuit breakers with 8 awg wire, then connect the rest of the existing wiring harness to the other side of the breakers.
    https://www.amazon.com/Bussmann-CB285-40-Surface-Mount-Circuit-Breakers/dp/B01G5WHRPC
    as an example.
    It seems like ARB broke up each compressor into its own wiring/fuse, so I intend to keep it that way.
    essjay, 3JOH22A and Bivouac[QUOTED] like this.
  9. Mar 13, 2023 at 12:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^These type of breakers are good. It's convenient to press the button to open the breaker and de-power the circuit for servicing.
    I use a single 100A version of this (BP/CB185-100) for my AliExpress compressor (which draws up to 90A) and it's been reliable.
  10. Mar 13, 2023 at 12:08 PM
    Bivouac
    I had something similar on my lift gate.
    As that is just an example I would look at 40amp weather proof being under the hood just in case. :thumbsup:
    I am sure we would love to see more pictures of the cause of this melt down.
  11. Mar 13, 2023 at 12:11 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Curious, OP, did you put a amp meter on it to see what it was actually drawing when running? I bet it’s higher than what it’s normally rated for. Hopefully the compressor itself is in good shape. This is also why I wouldn’t put electric equipment like a compressor in the engine compartment, especially if I was in a rust belt area with road salt.
    I’m just curious if the compressor motor is driving extra amps due to internal corrosion.
    YF_Ryan and Naveronski[OP] like this.
  12. Mar 13, 2023 at 12:34 PM
    Naveronski
    Fort Worth
    Good point, I didn't consider the weatherproof requirement - but you're right.
    No... we don't have the same corrosion issues here as many other parts of the country, but it's still possible. I haven't considered measuring it, but it might be worth buying a tool.
    Would this work? https://www.amazon.com/Proster-Auto...s=hi&sprefix=amp+meter,tools,124&sr=1-30&th=1
    Then I "clamp" over each wire with the compressor running?
  13. Mar 13, 2023 at 12:47 PM
    Bivouac
    only the positive wire one at a time.
    All motors have in rush current at start up might be as high 3 times normal current .
    Another thing if your voltage drops to low the amperage will increase.
  14. Mar 13, 2023 at 3:53 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Normally the ARB twin draws 50A total or 25A per "channel". It's well under the 40A rating of the fuse and the 8 ga wires are normally good for 40A. It's likely a substandard crimp at the fuse holder.
    That one measures AC current only, not DC. DC current clamps are more expensive: https://www.amazon.com/KAIWEETS-Multimeter-Auto-ranging-Temperature-Capacitance/dp/B07Z398YWF/
  15. Mar 13, 2023 at 5:28 PM
    #35
    OnHartung'sRoad
    A multimeter can measure amps- more accurate as well. But not that many! The DC clamps may work as above. If the internals of the compressor are corroded and shot, it could draw more amps as well. But you are right, it’s more likely the crimped connectors.
    Naveronski[OP] likes this.
  16. Mar 13, 2023 at 6:13 PM
    #36
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Also the draw increases as the pressure rises. At tire pressures it only reaches 50A(25A per) but if you push it nearer the limit of the compressor it rises to 68.5A.
    Naveronski[OP] and 3JOH22A like this.
  17. Mar 13, 2023 at 6:48 PM
    #37
    Naveronski
    Fort Worth
    That’s total amps, not per each compressor, right?
  18. Mar 13, 2023 at 10:06 PM
    #38
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes. Under 30A total no load, ~50A at 29 psi topping out at 68A+ By the time it hit 150psi. Likely not occurring unless you need that much or have a tank and 150psi pressure switch.
  19. Mar 14, 2023 at 6:12 AM
    #39
    Naveronski
    Fort Worth
    I do have a tank; the pressure switch is what came with the compressor.
    Don’t think I need that much though, so I could replace the pressure switch to a lower one to save wear on the compressor?
    Just use it for lockers and tires.
    edit: possible replacement: https://www.summitracing.com/parts/arb-co35sp
    Bivouac likes this.
  20. Mar 14, 2023 at 11:44 AM
    #40
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes, that will lessen the wear on the compressor.
