ARB Diff Breather install: Extra parts for install on 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JasonLee, Nov 24, 2018.
  1. Nov 24, 2018 at 1:56 PM
    JasonLee
    JasonLee [OP] Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I have the ARB 170112 Differential Breather Kit sitting in the parts bin and I'm going to install it on the next nice day that I can crawl around the truck on the street.
    Will I need any extra parts to install to my 2003 Doublecab 4x4 automatic?
    Initially, I'll be connecting up the rear diff and the automatic transmission.
    I know that both of those locations something like this one-way vent:
    I assume those need to be replaced with something like this:
    If that is the case, what is the thread size and pitch that I need to match?
    Eventually, I'll extend the existing front diff/transfer case breathers to connect to the ARB manifold so if you know those thread specs, that would be helpful as well.
    opteron likes this.
  2. Nov 24, 2018 at 2:02 PM
    02hilux
    Planet: EARTH
    1/8"-28BSPT
  3. Feb 8, 2019 at 9:18 AM
    Firstgen619
    Firstgen619 Well-Known Member
    Jeremy
    San Diego
    1999 Tacoma 4x4
    Did you ever do the install looking to do mine soon have any pics or problems installing ?
  4. Feb 8, 2019 at 9:36 AM
    JasonLee
    15 TRD OffRoad
    It's been single digits and snow on the ground here, so I haven't rolled around in the street to install it yet. I did buy a brass fitting from the hardware store that should work. I'll post up when I get it installed - hopefully this weekend.
  5. Feb 8, 2019 at 2:29 PM
    Firstgen619
    Jeremy
    San Diego
    1999 Tacoma 4x4
    Nice hell yeah let me know
  6. Feb 8, 2019 at 10:17 PM
    TacoDeAlex
    TacoDeAlex TTC #0177
    Alex
    Houston, Texas
    2003 DC 4WD
    I’ve been contemplating diff breathers, it’s good to have. Could you do a write up OP?
  7. Feb 8, 2019 at 10:56 PM
    JasonLee
    15 TRD OffRoad
    Sure, here's you're write up: If you're considering it, you should know better. Do it already.
    Cheap way: bulk fuel line routed up to your gas filler cap area.
    Expensive way: ARB breather kit. Think way too much about the correct threading of a barbed fitting to replace the stock axle vent to extend the lines, let the ARB kit sit in your closet for almost a year. Purchase the "correct" brass barbed fitting to install into the axle with the ARB kit, but let that sit in your cupholder for 3 months. Upgrade your stereo and then get a reminder on this thread that you still haven't installed the diff breather kit. Look outside at the single digit temps and think to yourself, "Well, I'm just driving around in salty shitty roads. I can put this off for a few more months.". Continue to let that $80 ARB kit sit in the closet.
    Colchicine, SwampYota, Wsidr1 and 2 others like this.
  8. Feb 9, 2019 at 7:05 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    TacoDeAlex[QUOTED] likes this.
  9. Feb 9, 2019 at 9:40 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    bunch already here on TW. Here is a good one (and yes, its a 2nd gen but its essentially exactly the same)
    https://www.tacomaworld.com/threads/my-differential-breather-mod-photos.111954/
    Toyota union 90404-51319
    Toyota breather 90930-03136
    Source it at your local dealer or order from @gunny1005 or you can improvise but the cost is cheap enough, I ordered the OE parts. Source the tubing locally.
  10. Feb 9, 2019 at 10:58 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I just got the parts off Amazon:
    https://www.amazon.com/gp/product/B01MTMXM2O/ref=ppx_yo_dt_b_asin_title_o09__o00_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B01H79JUQQ/ref=ppx_yo_dt_b_asin_title_o09__o00_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B01FSZ9YY4/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
    I put mine in the gas filler. Took like 10 minutes.
    Colchicine and TacoDeAlex like this.
  11. Feb 9, 2019 at 10:59 AM
    TacoDeAlex
    Alex
    Houston, Texas
    2003 DC 4WD
  12. Feb 9, 2019 at 11:01 AM
    jbrandt
    Justin
    No, those are already routed fairly high in the engine compartment. I suppose you could rout them even higher if you really wanted, but it's not necessary.
    Mine are on the driver side, right under the brake master cylinder.
  13. Feb 9, 2019 at 3:37 PM
    JasonLee
    15 TRD OffRoad
    Sure, but the point of my thread is to find out what the threading is and not just buy the random union part since I have a hardware store with lots of good hardware and I can ensure the tubing will fit.
    I can't remember which one isn't extended up to the engine bay, but it's either the transfer case or transmission that only has one of the one-way valves on top like the rear axle. I am planning on extending this as well to the ARB breather.
  14. Feb 9, 2019 at 4:40 PM
    jbrandt
    Justin
    See my post with the links, that's the one you want.
    That's true, there are only 2 breathers in the engine bay... might be the t-case... ??
  15. Feb 9, 2019 at 5:51 PM
    Area51Runner
    yep and was just giving a quick reference since he was looking for a write up and yours is still in the works. :hattip:
    JasonLee[QUOTED][OP] likes this.
  16. Feb 22, 2019 at 5:43 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    The breather is a one way breather you need a 2 way breather for this to work correctly
