ARB locker question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Jun 3, 2009.
  1. Jun 3, 2009 at 5:38 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Can you still make it work even if you have an Auto LSD on a Prerunner?
    What about actaually making it LOCK?? air compressor............
  2. Jun 3, 2009 at 7:47 PM
    SaltySteve
    SaltySteve Well-Known Member
    Denver
    2012 4runner
  3. Jun 3, 2009 at 7:53 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    LSD gets removed, the locker + an OBA system gets installed to make it lock.......
  4. Jun 3, 2009 at 8:01 PM
    Lentsnh
    oba?
  5. Jun 3, 2009 at 8:03 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    On-board Air
  6. Jun 3, 2009 at 8:04 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    On Board Air
  7. Jun 3, 2009 at 8:17 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    You need an air tank, compressor and the air lines to connect it all.
    The air pressure engages the locker.
  8. Jun 3, 2009 at 8:29 PM
    Lentsnh
    theres alot of money to go with the ARB locker isn't there
  9. Jun 4, 2009 at 12:25 AM
    DDD
    Derek
    Santa Clarita, CA
    About $800 for the locker alone.
    The on board air system is seperate.
  10. Jun 4, 2009 at 12:29 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    yea its def not cheap. I want one bad on my truck!
  11. Jun 4, 2009 at 12:42 AM
    johnecon2001
    Phoenix, AZ
  12. Jun 4, 2009 at 12:49 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    i also looked at just swapping my rear end for a used rear with the factory locker. It was like over 2k
  13. Jun 4, 2009 at 4:28 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have an 06...
    Do you have the Auto LSD w/ Atrac/VSC stuff?
    Or
    Do you have the mechanical LSD?
    If you have the mechanical LSD (inside the diff), and you install the ARB in the rear.....the LSD will need to be removed. You'll need to buy new gears and you'll need a complete ARB install & gearing setup for the rear end.
    Yes, the ARB needs air to actuate. You can get a small cheaper setup (for example) ARB has a small compressor that serves the purpose well. You can get a better/larger air compressor to supply a tank of air (so you can air up your tires) OR you can even get a liquid CO2 setup to operate the ARB (do some research on this).
    For starters, I'd highly recommend getting a small air compressor (like the ARB) and hook it all up. Easy & quick.
    And if you want a full blown onboard air system - you can do that later on when you've had time to research how you want to set that up. THere's a bit more complexity in installing onboard air systems and you don't want to jump in too quickly.
  14. Jun 4, 2009 at 11:30 AM
    Lentsnh
    Cheaper than the ARB + the goodies?
  15. Jun 4, 2009 at 12:26 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    The ARB setup is not cheap but its well worth it, If your goin to wheel your truck
  16. Jun 4, 2009 at 1:16 PM
    johnecon2001
    Phoenix, AZ
    My rear locker cost me $1260 installed.
  17. Jun 4, 2009 at 1:17 PM
    silver07taco
    COIL
    Maryland
    I am around $1300
  18. Jun 4, 2009 at 1:18 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    not to sure, after seeing how much they were I stopped looking at them...for now. ha
  19. Jun 4, 2009 at 1:26 PM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    I paid right around $1175 for my ARB + Compressor. That includes all the parts and labor.
  20. Jun 4, 2009 at 3:42 PM
    Lentsnh
    Yep Im gonna wait a while lol
