ARB Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by usmcgoose, Jan 15, 2010.
  1. Jan 15, 2010 at 7:26 AM
    usmcgoose
    usmcgoose [OP] One shot is all I need
    Virginia
    05 Tacoma 4X4
    Just an inquiry because I haven't located a thread on this. I was wondering if anyone has installed the ARB Locker on their non-TRD Tacoma. How is it? How well does it work? Difficulty to install? And all the other normal questions.
    Thanks in advance
  2. Jan 15, 2010 at 7:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There is ARB information everywhere!! And yes...lots of people have them. Did you use the search button in the upper top blue bar?
    I had two of them in my Jeep. They are AWESOME!!
    ARB's are expensive and are not something you can install yourself. It should be installed by a professional who's experienced with installing gears & locker.
    Sure - anyone can learn how to do it, but if its not installed properly...your investment could be destroyed in a matter of time.
    Along with the ARB (which replaces the entire differential carrier), you have to buy gears (ring & pinion), and an air supply to operate the locker. Installing the ARB requires setting up ring & pinion gears - again, should be done professionally.
    If you think you'll need to use it on extreme offroading trails....and you can afford to do it - then go 4 it. Otherwise -think long & hard whether or not you actually need it. It'll cost you $1000 and more to have it all done.
  3. Jan 15, 2010 at 7:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    Everyone who has one loves it when the use it. As long as you size it correctly you should be fine.
    As far at the install- It is a difficult install to rebuild gears and set the internals- but if you know how to do that (which means you are really good with cars) you'll be able to manage it. I think it requires some special tools too....
  4. Jan 15, 2010 at 7:56 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    being in VA you should absolutly call East Coast Gear Supply and talk with Chase. Thay will be the very best at this and can do a 3rd memeber core swap with the ARB and R&P gears already installed. http://eastcoastgearsupply.com/
  5. Jan 15, 2010 at 8:08 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I'm quite handy with a wrench and I'd never attempt to install an ARB. It takes many special tools, specific tolerances, etc. The "lunch box" lockers and spools can be installed by a good shade tree mechanic. ARB is not one of those.
    Other than that, the only complaint I've ever heard about ARB lockers is the price.
  6. Jan 15, 2010 at 8:21 AM
    usmcgoose
    Virginia
    05 Tacoma 4X4
    Thanks for the post. That was the info I was looking for.
