ARB Lockers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dirt..ee, Feb 8, 2010.
  1. Feb 8, 2010 at 6:59 PM
    Dirt..ee
    Dirt..ee [OP] New Member
    07 4x4 doublecab TRD
    3" Revtek lift Iron Bull bumpers
    I am looking to put in ARB air lockers front and back. Does anyone know if the open diff mode (lockers not engaged but in 4 wheel drive) operates with the same characteristics as the stock open diff when in 4 wheel drive? :confused:
  2. Feb 15, 2010 at 5:24 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    Yes it will operate as open differential just as long as you don't turn on the locker.
  3. Feb 17, 2010 at 8:52 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    Does anyone have a locker in the front diff here? how do you like them?
    (I will be putting one in when I get a truck)
  4. Feb 17, 2010 at 9:07 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Few things to consider
    1. Front locker on IFS is more for loose ground, mud, snow only. Otherwise you will be blowing CV's very often.( you still get few spare ones and familiarize yourself with replacement procedure)
    2. Your truck locked on the front and rear will have turning radius of aircraft carrier.
    3. You may want to consider low lift if you running a front locker. Too much stress on components at weird angle. 1.5 inch most likely would be a top.
  5. Feb 17, 2010 at 9:13 PM
    Series1000
    Vancouver Canada
    Lots
    hmm, I was hoping for a 2.5 OME inch lift, would a limited slip be better?
  6. Feb 17, 2010 at 9:22 PM
    BlueT
    NorthEast
    You can have 3 inch lift as long as you install 1.5 diff drop o nthe front. Otherwise CV's may have too much angle to handle when locked.
    Also I dont think there is limited slip for 2gen front.
    Then again I may be thinking too much in terms of 1gens :D that had 27 spline CV's
  7. Feb 17, 2010 at 10:04 PM
    Series1000
    Vancouver Canada
    Lots
  8. Feb 17, 2010 at 10:29 PM
    Series1000
    Vancouver Canada
    Lots
    I was thinkin about getting a trd sport. Then it would have a limited slip rear diff and a locked front. In my opinion the best combo.
  9. Feb 17, 2010 at 10:36 PM
    Series1000
    Vancouver Canada
    Lots
    Sorry, I was talking about adding an arb locker a few posts up, and I ment after I add the locker it would have a locked front and a limited slip rear. So when the going gets tough I can press the tough button :cool:
  10. Feb 17, 2010 at 10:44 PM
    diablo_Alex2777
    diablo_Alex2777 Well-Known Member
    Alejandro Gonzalez
    Mira Loma
    05 tacoma dcab Trd off road. 4x4
    Icon UCA's,coilover, Demello front,rear bumper All-pro 3in rear leaf spring Miler maker m8000 winch\ 33's coopers stt's Demello's skip plate 3 hellas 500's
    I have E-locker on the back and i have 05 tacoma and only use them maybe 4 -6 time this hole time. all you really need is the rear. save some money on Cv's. and become a better drive:D jk.
  11. Feb 18, 2010 at 2:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    An ARB install is NOT to be taken lightly. Along with the install of the locker, you have to do a 'gear setup' - also, not to be taken lightly.
    If it's not done right.... you'll be blowing $800 of ARB out the window.
    If you're not familiar with the ARB and what's involved to install them - then I'd highly recommend paying a professional to do it.
  12. Feb 18, 2010 at 2:31 PM
    Janster
    Jandy
    Lancaster, PA
    Shop around...the cost can vary. Make sure it's a reputable shop that has plenty of experience installing ARB's.
    Back in 2001 in my Jeep - I had 2 axles (D44's) and had ARB's, gearing (4.56), bearings, & seals installed in both axles for $1200 labor at Hoaks 4WD. One guy is known for his work and has been installing ARB's for YEARS. We trusted his work...and didn't mind paying the cost. Those ARB's & gears lasted for 8 years at least - we sold the jeep and they were still going strong.
  13. Feb 18, 2010 at 2:46 PM
    BlueT
    NorthEast
    you are in NC you have some of the the best shops there :D
  14. Feb 18, 2010 at 3:07 PM
    BlueT
    NorthEast
  15. Feb 18, 2010 at 5:47 PM
    Rhino8541
    Rhino8541 I like ze best!
    AZ
    2017 QS DCSB OR
    I kinda want a locker, but I would probably regear at the same time.
  16. Feb 18, 2010 at 10:08 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Shoulda got an OR. HA!
  17. Feb 19, 2010 at 5:54 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    A Non E-locker rear end is a bigger, (stronger) unit. You could argue equipped with and ARB it would be a better set up, especially if you upgrade the compressor for added on board air...:cool:
  18. Feb 19, 2010 at 6:59 AM
    Series1000
    Vancouver Canada
    Lots
    Really...
  19. Feb 19, 2010 at 7:11 AM
    BlueT
    NorthEast
    Yep thats true. R&P on non e-locked is 8.5 vs 8 on elocked.
    So with ARB you actually have stronger rear diff then with e-locker.
    Plus re- gearing has more options
  20. Feb 19, 2010 at 7:16 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2...F*** it, just do a SAS!!! :woot:
