ARB Recovery Point Installed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Mar 23, 2019.
  1. May 24, 2021 at 11:19 AM
    #61
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Where did I say this? "angle of pull equal to the steering angle" as justification"
  2. May 24, 2021 at 11:21 AM
    #62
    chuam
    Marcus
    San Diego
    Pulling force should always be perpendicluar to the pin to ensure you don't side load the pin. The only way to guarantee that is to attach the strap to the pin and let the shackle rotate on the recovery point.
    Doesn't matter what the orientation of the ARB recovery point is. Very much apples to apples.
  3. May 24, 2021 at 11:21 AM
    #63
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    The only verbiage I see quoted that has these words is directly from the ARB website.
  4. May 24, 2021 at 11:22 AM
    #64
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    I literally posted the instruction card from ARB. Not sure why we're continuing to beat this to death. Do you what you feel is safe.
    Grindstone and chuam like this.
  5. May 24, 2021 at 12:15 PM
    #65
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I thought we were discussing loading a recovery point. Not personal statements.
  6. May 24, 2021 at 2:19 PM
    #66
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    Just in case anyone is wondering, while installing an Elka suspension setup with 2" front lift it became apparent that the ARB recovery point is not compatible with my suspension. The remote reservoir bracket is also a swaybar relocation shim and use the same space as the very back upper part of the ARB recovery point. It's just a weird coincidence I guess. Something to be aware of folks.
  7. May 24, 2021 at 2:35 PM
    #67
    chuam
    Marcus
    San Diego
    I was just trying to figure out why you mentioned steering angle when I'd never mentioned it as my justification.
  8. Feb 14, 2023 at 4:38 PM
    #68
    hafjell
    hafjell Well-Known Member
    Idaho
    2023 TRD OR MT
    Meaning, turned the wheel all the way to the right?
  9. Feb 17, 2023 at 6:15 AM
    #69
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Yep
  10. Jul 16, 2023 at 6:49 PM
    #70
    bajatx6mt
    bajatx6mt New Member
    Jack
    2021 TRD Offroad DblCab Short Bed
    TRD Beadlock Wheels wrapped in 265/75R16 BFG KO2's Sherpa Equipment Co Roof Rack OEM Audio Sound System
    I've spent the better part of a day installing this recovery point. Do you have any tips for the "nut on a stick"? It's the last bolt I have to install and then I'm all done. Any advice would be appreciated, thank you!
  11. Dec 5, 2023 at 9:16 AM
    #71
    lsrmath
    lsrmath Well-Known Member
    2023 Yoda TRD OR
