ARB twin to Switch Pro 9100
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trl1990561, Sep 1, 2021.
  1. Sep 1, 2021 at 6:03 PM
    trl1990561
    trl1990561 [OP] Well-Known Member
    Tyler
    Jupiter, FL
    2021 Lunar Rock Tacoma TRD Pro
    Prinsu Rack, 265/70/R17 KO2,RRW R7-H RCI Rock Sliders,RCI 18" Bed Rack, Decked System,Baja 40" Amber Roof Light bar, Baja Amber Ditch Lights,Baja Amber Fogs, ARB Twin Compressor, Switch Pro, Blaze Offroad Wiring
    Looking to wire a ARB twin compressor to a switch pro 9100 and need to know how to wire any info would help thanks. Im looking to see if the ARB quick connector to switch pro is the easiest cleanest route.
  2. Sep 1, 2021 at 6:05 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Check out the 9100 bs thread. I think it's been brought up a few times in there. Maybe @Shellshock has beta
  3. Sep 1, 2021 at 6:08 PM
    NJOffRoad
    NJOffRoad Well-Known Member
    Anthony
    Pine Barrens, NJ
    2021 Cement TRD OR 4x4
    -Off-Grid Engineering Dual Battery system with Redarc BCDC1225D and Full Throttle Group 35 AGM -SPOD BantamX -Expedition Essentials 3TPAM -Spiker Engineering hood struts -Taco Vinyl raptor grill -Baja Designs Squadron Sport fogs -Baja Designs Squadron Pro ditch lights -KC Cyclones under-hood lights -ARB Twin Compressor -Mobtown Offroad Skids & Sliders -Diamondback Tonneau Cover
    I use a Spod but the concept should be the same. The fused power wires go directly to battery cause of load.
    The purple wire goes to controller positive terminal.
    That's it.
  4. Sep 1, 2021 at 6:54 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    As mentioned, the SP9100 BS thread has multiple posts. Otherwise, you'll need to be more specific. Are you only running the compressor? Will you need to also connect the switches to a front and/or rear air locker or something else that the compressor will be connected to? (Also covered in the 9100 thread btw).
