ARB winch bumper/tire clearance question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toy Yoda, Apr 18, 2011.
  1. Apr 18, 2011 at 9:52 AM
    Toy Yoda
    Toy Yoda [OP] gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    current set up suspension wise: 5100's at 1.75 up front and 2 inch block rear and stock in the back.
    Getting the ARB winch bumper and was wondering if i would be able to fit 285/75/16's with the 5100's at 2.5 and the arb bumper. or will the tires still rub like with a stock bumper? would i need spacers?
  2. Apr 18, 2011 at 9:55 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    After the addition of the bumpers weight you will probably rub with the 285's if you are using stock springs with your 5100's.
  3. Apr 18, 2011 at 9:58 AM
    Toy Yoda
    Garrett
    06 DCLB
    i was concerned about the weight of the bumper...what coils would be best for supporting the bumper without raising the front higher than the rear?
    edit: would spacers solve that problem?
  4. Apr 18, 2011 at 10:03 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Do not put spacers on the 5100's that have been adjusted for lift. What is your truck, Reg/Access/D-cab?
  5. Apr 18, 2011 at 10:12 AM
    Toy Yoda
    Garrett
    06 DCLB
    d cab long bed
  6. Apr 18, 2011 at 10:13 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Get the 886 springs.
  7. Apr 18, 2011 at 10:21 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    do you plan on putting a winch in it?
  8. Apr 18, 2011 at 10:32 AM
    Toy Yoda
    Garrett
    06 DCLB
    yes
  9. Apr 18, 2011 at 11:51 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    886s will settle and you will be fine.
    Tires will rub the front of the ARB at full compression most likely.
  10. Apr 18, 2011 at 12:03 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Mine do not.
