Arcticelf's sold his truck BS thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Arcticelf, Jul 27, 2015.
  1. Feb 24, 2019 at 4:34 PM
    #521
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No definitely not. And it’s a good excuse to get an alignment because I’m always knocking mine around.
    Arcticelf[QUOTED][OP] likes this.
  2. Mar 15, 2019 at 4:18 AM
    #522
    Arcticelf
    Arcticelf [OP] Well-Known Member
    Gladiator
    Mostly for future reference. Estimated tool box weight is 350#, Expo box is about 50#.
    It's time to order new rear springs and get this piglet back on good legs.
    Grand dude likes this.
  3. Mar 15, 2019 at 7:48 AM
    #523
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    "that piglet"
    up to 6500# yet
  4. Mar 16, 2019 at 5:06 AM
    #524
    Arcticelf
    Gladiator
    Tsb pack is 6 3/4 Arch and 53 1/2 eye to eye, 1 3/4 pack thickness. Leaves are 1/4 thick.
  5. Mar 16, 2019 at 6:39 AM
    #525
    Arcticelf
    Gladiator
    Today's mystery: where's the brake fluid going?
  6. Mar 16, 2019 at 7:18 AM
    #526
    Grand dude
    Dave
    lehigh valley, PA.
    Aliens ?
    fatfurious2 likes this.
  7. Mar 16, 2019 at 9:35 AM
    #527
    Arcticelf
    Gladiator
    No. That's the hard part. But it's not staying in the reservoir either.
    Blackout14 likes this.
  8. Mar 16, 2019 at 9:35 AM
    #528
    Arcticelf
    Gladiator
    Possible.
    Grand dude[QUOTED] likes this.
  9. Mar 16, 2019 at 9:43 AM
    #529
    Arcticelf
    Gladiator
    A quart of air in the last 6 months?
    fatfurious2 and EatSleepTacos like this.
  10. Mar 16, 2019 at 9:47 AM
    #530
    Redmann
    Redmann DILLIGAF
    Reds
    Philly
    2009 AC TRDOR
    Plausible. Chester.
  11. Mar 16, 2019 at 9:48 AM
    #531
    Arcticelf
    Gladiator
    That's possible too.
    Either it's getting sucked into the engine through the vacuum line, or it's slowly leaking into the caliper or drum and burning off before it can leave an oil stain.
  12. Mar 16, 2019 at 9:50 AM
    #532
    Arcticelf
    Gladiator
    Hmm I'll have to look at that. But yes, that's why it's a mystery.
  13. Mar 16, 2019 at 2:20 PM
    #533
    Arcticelf
    Gladiator
    (09-14)Ford F150 2wd, 4wd
    43-1783
    43-1783HD
    New Pack:
    Eye Loops at 1 1/2" ID
    3(W)X31-5/8(S.E.)X31-5/8(L.E.) 5/1 Lvs: 1/.401 1/.401 1/.360 1/.322 1/.322 1/.812
    7 3/4 arch
  14. Mar 17, 2019 at 4:28 AM
    #534
    Arcticelf
    Gladiator
    Yeah. I'll be calling Junior on Monday.
  15. Mar 17, 2019 at 12:48 PM
    #535
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Im calling @Mobtown Offroad on monday :D:cool:
  16. Mar 18, 2019 at 1:10 PM
    #536
    Arcticelf
    Gladiator
    Did you get your slider plates?
  17. Mar 18, 2019 at 1:22 PM
    #537
    Arcticelf
    Gladiator
    how to figure out correct shackle length for a swing up type shackle: first the 2 extremes- at full droop the shackle should be horizontal, or even a little under. you then have to limit it with straps to just above horizontal. the other extreme (bump) is debatable. i personally do them so the shackle is about the 1'oclock position. i have some *odd* theoretical ideas about why this is preferred. so there is about 120 degrees of shackle movement you want. now you'll take the growth of the spring, and figure it from there.
    lets say we had a growth of 8 inches.
    8(growth)*3 (120 degrees is 1/3 of a circle, so multiply by 3 to get circumference) = 24". now you solve for radius: 24/ 3.14 (pi)=approx 8" diameter /2 = 4" radius. NOW TO SIMPLIFY THAT EQUATION A BIT: just take your growth number and divide it by 2. a little simpler, but i think you should understand an equation in order to use it correctly. so a spring with 8" growth needs a 4" shackle. a spring with 10" growth needs a 5" shackle. and so on. this is only if you subscribe to my shackle angle part.
    from here: https://www.race-dezert.com/forum/threads/shackle-length-s.11369/
    steele-taco and Blackout14 like this.
  18. Mar 18, 2019 at 1:41 PM
    #538
    fatfurious2
    David
    Ashburn, VA
    I have them already. Need to at least tack them on. Or i can just leave them for the 31st.
    I was calling Mobtown on another order :cool: regarding refrigeration :D
  19. Mar 18, 2019 at 1:44 PM
    #539
    Arcticelf
    Gladiator
    Okay, not a big deal to weld on. Biggest thing is making sure all the legs are the same length and the ends are square.
  20. Mar 18, 2019 at 1:53 PM
    #540
    fatfurious2
    David
    Ashburn, VA
    I had to cut one plate off, and I think i cut a little too much (no sawzall, cutoff wheel used) so im thinking i need to grind down the rest a little bit. Maybe I should leave it for you. If i mess with it, I might grind all of the legs off..
