Are 1" aal available?
Discussion in 'Suspension' started by markc6606, Nov 21, 2010.
  1. Nov 21, 2010 at 8:45 AM
    markc6606
    markc6606 [OP] Well-Known Member
    SoFlo
    '13 Off-Road
    Hey All,
    I've been doing quite a bit of searching but havent quite found anything. I was looking to lift the rear of my 2010 dc another inch or so and was searching around for an extra leaf to accomplish this. All i seem to find are 1.5 or 2" leafs
    I've got a set of 1" blocks but I'm trying to avoid them, plus I'd like the extra load capacity. I've had the rear spring tsb done , but still would like a little extra.
    Does anyone know of a vendor that sells these or are they a custom fab that would be too expensive? Really don't want to go to a 1.5 and possibly have the truck come up that much. I've got billy's all the way around now withe the front set to 1.75 and the truck sits pretty much level with my heavy job box in back. I don't want drastic rake back just slightly higher out back.
    I would appreciate any suggestions or opinions. Thanks alot. Members on TW are the best. Be lost without you guys
  2. Nov 21, 2010 at 9:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A local spring shop should be able to make a pair for ya.
  3. Nov 21, 2010 at 1:50 PM
    markc6606
    SoFlo
    '13 Off-Road
    Thanks Chris think there's a shop close to me in conshohocken I'll try them. Is there anything special you can think of that I should bring up to them when I ask about them? Again I really don't want a lot of added lift.
    What are your feelings on the blocks I already have? They would prolly give me the lift I want but I've been reading horror stories here bout them.
    I used to run them no problems on my old K-5's and F-250s years ago but I know the tacomas are different animals, This is my third. Most of my offroading is from entering some pretty ripped up construction sites everyday, so I'm not too concerned about breaking a block. More bout the added spring wrap. Thanks
  4. Nov 21, 2010 at 2:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I know a couple folks who have run blocks with out an issue, but it does tend to exacerbate axel wrap. As for the AAL, Have them make the AAL long (about 2" shorter than the spring clamps on the existing pack), and have about 1/16" more arch on the driver side to help account for the extra weight and you should be golden :)
  5. Nov 21, 2010 at 3:04 PM
    markc6606
    SoFlo
    '13 Off-Road
    Thanks man!! I'll check it out this week. Hope they're reasonable.
  6. Jan 2, 2011 at 8:45 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Hey mark, did you ever look further into doing the custom 1" aal's? I am thinking of doing this, as I also don't want a full 1.5" in back.
