Are 2010 V6 Tacoma pre wire for fog lights
Discussion in 'New Members' started by jrock534, Mar 14, 2012.
  1. Mar 14, 2012 at 5:24 PM
    jrock534
    jrock534 [OP] New Member
    Stev
    Chilliwack, BC.
    Tacoma
    Are 2010 V6 Tacoma pre wired? Located wires for interior toggle but no relay or wire harness I can see.
  2. Mar 15, 2012 at 11:06 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Welcome from SoCal! You may get more responses if you post this in the 2nd Generation section. That said, 2005 and newer Tacomas are essentially wired the same way-cheaper to do it this way. While the wiring harness for your truck should be there, you will need to get a relay (relay socket next to battery) and a switch to install in one of the blank switch openings to the left of the steering wheel. And, of course, fog lights if you don't have them. Good luck.
