Are 5100's adjustable while installed on truck?
Discussion in 'Suspension' started by SamSter0077, Sep 6, 2008.
  1. Sep 6, 2008 at 12:34 PM
    SamSter0077
    SamSter0077 [OP] Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Can you adjust the 5100's while they are installed on the truck? Does that adjustment require special tools? Does that adjustment require another alignment?
    Thanks in Advance.
    -Sam
  2. Sep 11, 2008 at 11:48 AM
    ap53
    ap53 Well-Known Member
    Art
    NJ
    06 PreRunner
    You need to take them off and move the ring to the next grove, not sure about the alignment
  3. Sep 11, 2008 at 11:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any time you adjust the height of your truck, you will need an alignment.
