Are all front diff's at risk?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 350u, Nov 14, 2010.
  1. Nov 14, 2010 at 11:50 PM
    350u
    350u [OP] Member
    ab canada
    07 access cab 4x4 trd
    I just purchased my first tacoma,i have been reading this site for days (great site,very helpful)....but I was amazed to find the thread about all the front diff bearings going out!
    Can someone tell me how prevelent this is?......sounds like it happens alot!
    I was planning on a 2.5" lift up front,now Im not sure!
    thanx so much.
  2. Nov 15, 2010 at 4:49 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It's hit or miss. You either have it or you don't. Lifting it doesn't make it happen, it just brings the problem to light. You can take the lift off and the sound will go away.
    I have it on my truck. It's kinda annoying, but I'm slowly getting used to it. I had one dealer turn me down on it, but I'm taking it to another one that works very closely with out local club and has no issues working on lifted/modified vehicles.
    Additionally, if you have read all the fun stuff like you said, you will also know that there are guys who've been riding around with it for over 2+ years that haven't broken their truck or had it get worse. :)
    Hope that helps, and good choice on the truck. 07 FTMFW Woo! :woot:
    Where in Alberta are you? I'm hiding in Cowtown.
  3. Nov 15, 2010 at 8:28 AM
    350u
    350u [OP] Member
    ab canada
    thanx Krasy.
    I wonder how many early 2nd generations out there made it to 200k plus on the front diff?
    Also are the 2011's still the axact same?or updated?
    Between red deer and edmonton on farm
  4. Nov 17, 2010 at 8:27 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I don't know to be honest. They're the same type of axle if that's what you mean but whether they get afflicted when lifted as well, no clue.
  5. Nov 17, 2010 at 9:14 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    2001 4WD, no differential problems: 136,000 miles in nearly 5 years.
    2005 4WD, no differential problems: 102,000 miles in 4 1/2 years.
    2010 4WD, no differential problems: 18,000 miles in 11 months.
  6. Nov 17, 2010 at 9:37 AM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I had a front diff issues but not when I lifted the truck. I installed the lift a few weeks back and it rides great. The issue I had ruined my front diff carrier bearings on the drivers side. This is a huge deal and thats why it is costly, b/c they have to remove alot to get to it. I noticed when we did the work to repair it the front diff carrier bearings are pressed into the carrier, I dont like that idea, but that is one other thing that is not cheap, you cannot just purchased the carrier bearing (at least they did not let me here) I had to buy the whole carrier. New everything, to the tune of like over $600 just for one fried bearing. Like I said not the best idea. I have had no issues at all after the carrier was replaced. Pushing 70,000 and she is riding nice! JOE>
  7. Nov 18, 2010 at 1:12 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Yea. I was reading around, rumor has it, they sell the bearings already pressed into the carrier as one piece and no other way. Of course if you can get them out and mic the shaft and case, you can buy whatever you need.
  8. Nov 18, 2010 at 7:28 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I wouldn't say it happens a lot. Look at the numbers for the popular polls on this site to see just how many people are on here voting, and you'll realize there's really only a dozen or less people that are experiencing the problem (even if it's 2 dozen, that's still a very, very small percentage). But this is definitely a problem Toyota is having. The Tundra's have a TSB out for the same problem and it's more prevalent with them. Those are being felt without lifts.
  9. Nov 18, 2010 at 8:34 AM
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    Hey so just wanted post on this thread since I am troubleshooting this problem. I just realised the loose bearing in the diff after I lifted the truck. I am sure the problem was pre-exsisting and was simply not making as much noise, as well as the fact I had not researched the problem. Really seems like a design flaw to me. I did find a site selling the bearings not sure anout geting the old out and the new in though.
    http://www.toyotapartsamerica.com/p...coma&year=2008&catalogid=1&displayCatalogid=0
    Difinitly intrested in any info, good luck with the first tacoma mine too.
  10. Nov 24, 2010 at 9:41 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    After some reading and looking at several 2nd Gen tacomas, I honestly believe that they all go at some point or another. They majority go well before what mileage I would say is acceptable. I think it was mentioned before that the lift just make the problem apperent. I have crawled onder quite a few of them now to move the CV's and belive that it is a major design flaw. Looking at the mechnical drawings leads me to believe that if left alone for to long the gear set in the diff may be harmed. Any Opinions?
  11. Nov 25, 2010 at 7:05 AM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    How many miles have you driven it like that though? I ask because I can live with the minor vibration but will fix it if it's going to leak to any major problems. I only average about 10k a year.
  12. Nov 25, 2010 at 8:56 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ive got minor vibes with 2years and 25,000 miles and no problems.
  13. Nov 25, 2010 at 9:40 AM
    Black06Taco
    Black06Taco Well-Known Member
    Dillon
    Thornton, CO
    06 Tacoma
    2 10" Type E's, Mud Tires, Backup Camera
    My '06 has 94k and there's no issue at all with my bearings
  14. Nov 29, 2010 at 11:31 AM
    ywen
    ywen Well-Known Member
    why can't a shop just open the carrier assembly and replace the bearing?
  15. Nov 29, 2010 at 12:09 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    One of the threads that you read was probably one that I started.
    What Krazie Sj and Moose wrote is pretty accurate -- it is hit or miss, and seems to be relatively rare. I have asked 5 different dealerships now how many 2nd gen Tacoma front diffs they have replaced over the years and each has said something to the effect of "a few, but it's very rare". Keep in mind they didn't specify whether those replacements were related to lifting. There is that thread over at Toyota Nation about this topic with hundreds of accounts of people having front diff vibes after lifting, but keep in mind that that thread is a concentrated collection of cases which may only represent a tiny fraction of the Tacoma owning population as a whole. I would guess that most people who lift their Taco and end up with vibes post about it on one of these forums, so be aware of that concentration bias.
    I am of the opinion that the jury is still out about whether or not a lift actually causes a front diff problem or if it merely unveils a problem that was pre-existing. Really, that point is moot, because whichever the case may be, the diff vibration problems seem to arise once lifts are put on. In most cases that I have read, the vibes disappear once the lift is removed. This was also the case for me.
  16. Nov 29, 2010 at 12:30 PM
    BenWA
    Boston burbs
    p.s., did you purchase any kind of power-train warranty with your truck that would cover a front diff replacement? If so, I would probably vote to go ahead with trying a lift, knowing that it may result in front diff issues. If it turns out that you have issues, have the diff replaced under warranty and, worst case scenario, undo the lift (assuming you have the mechanical wherewithall to do and undo the lift yourself without having to pay somebody else to do it).
    The only reason why I undid my lift is that my warranty lapsed long ago and I need my truck to last as many miles as I can squeek out of it, and I got spooked about the idea of costly out-of-pocket front diff replacement. If I still had a warranty, my truck would be lifted right now.
