Are all oil catch cans vehicle agnostic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 5, 2016.
  1. May 5, 2016 at 10:09 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    My gut feeling is that the answer is yes but just wanted to check. I think my PCV is sending some oil back into the engine, which causes a major oil loss (3.5 out of 5 qt every 1500 mi). I would like to install a catch can to confirm that and was wondering if ANY catch can will work for a 2nd gen Tacoma, V6. E.g., this one.
  2. May 5, 2016 at 10:19 AM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    Are you saying you lose 3.5 qts every 1500 miles? Only things to look at with the catch cans is if vent to atmosphere or not, mounting options and hose sizes.
  3. May 5, 2016 at 10:20 AM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    that seems like a lot ... I'd be more worried about the root cause
  4. May 5, 2016 at 10:22 AM
    foampile
    Mid-Atlantic
    of course. i completely rebuild the engine myself last September, lapped the valves and replaced the head gasket -- i may have a cylinder leaking and will do a leakdown test
  5. May 5, 2016 at 10:25 AM
    foampile
    Mid-Atlantic
    but i'm trying to see if it's the PCV sending oil back into the combustion chambers before blaming the head gaskets or valves for letting oil in
  6. May 5, 2016 at 12:29 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Ah...okay. That makes me feel a little better ;)
  7. May 5, 2016 at 12:30 PM
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    And that was your 666 message ... weird...lol. Where in the "mid atlantic" are you located?
  8. May 5, 2016 at 12:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    replace the pcv valve, its cheap quick and easy.
    That stated, my truck does not use a drop of oil in 5k miles and i dont run a catch can.... so you have other issues at hand and a catch can will not solve or help you out much.
    digitaLbraVo likes this.
  9. May 5, 2016 at 12:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @foampile I remember reading your last few threads, I'm expecting gold again... :facepalm:
    Also you have way bigger problems than PCV if you're losing 3.5quarts.
  10. May 5, 2016 at 1:03 PM
    foampile
    Mid-Atlantic
    I also have no smoke coming from around the engine bay or tail pipe, which makes me hopeful it's not burning oil
  11. May 5, 2016 at 1:05 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Smoke from the tailpipe, especially at startup in the morning? If so, could be valve guide seals.
    1MK likes this.
  12. May 5, 2016 at 1:11 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Posted before I saw your last post. If no smoke with that much oil loss, it ain't burnin' oil.
  13. May 5, 2016 at 1:12 PM
    Speedytech7
    Since you changed your head gaskets in the last episode, have you checked your coolant for oil?
  14. May 5, 2016 at 1:15 PM
    foampile
    Mid-Atlantic
    Yes, both oil and coolant are really clean. No signs of mixing
  15. May 5, 2016 at 1:17 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    So, no smoke, no oil/coolant mixing. That means one thing left, you got a leak.
  16. May 5, 2016 at 1:18 PM
    foampile
    Mid-Atlantic
    I do get some normal looking exhaust out of the tail pipe when I first start the engine. But it does stop when I start driving.
    I did replace all the valve stem seals.
  17. May 5, 2016 at 1:25 PM
    1MK
    1MK Desert Explorer
    Southern California
    That's an awful lot of oil being burned.
    If your getting smoke in the engine compartment, you most likely have a oil leak. If you're seeing smoke come out of the exhaust then I'd say valve guide seals were damaged during R&R of valves.
    _______________________________
    Fill engine oil level to exactly the full point. Drive vehicle and check every 500 miles and confirm rate of oil consumption.
    If your not seeing oil leakage, you're burning it, even if it's not visible.
  18. May 5, 2016 at 1:25 PM
    foampile
    Mid-Atlantic
    I did replace the oil pan gasket. No other signs of leakage around the engine, very clean
  19. May 5, 2016 at 1:28 PM
    1MK
    1MK Desert Explorer
    Southern California
    Also, in regard to your original question, all catch cans are basically universal and operate using the same principle.
    But.
    A catch can should never be needed on a stock engine. Even mildly built usually don't require one. If you were to run one you'd be basically band-aiding whatever the underlying cause is and are on borrowed time.
    foampile[OP] likes this.
  20. May 5, 2016 at 1:29 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Pull your spark plugs and check for contamination. If it isn't burning, and isn't going in the coolant, it is going somewhere. Or you forgot to put oil in.
    foampile[OP] and 1MK like this.
