Are all oil catch cans vehicle agnostic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 5, 2016.
  1. May 5, 2016 at 7:54 PM
    #41
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    On the leak down test, make sure the piston is at tdc before pressurizing the cyl. If you still have a cyl that has a higher leakage %, hunt down the leak path. Listen for air passing through. Leaking air sound in intake=intake valve. Sound in exhaust=exhaust valve. Sound in oil fill stand= rings/cyl wall clearance. Sound &/or bubbles through radiator fill= head gasket.
  2. May 5, 2016 at 8:03 PM
    #42
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Root cause lol you sound like a Tester or Dev.
  3. May 5, 2016 at 8:03 PM
    #43
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I'll do another leak down test in the morning
  4. May 5, 2016 at 8:07 PM
    #44
    foampile
    Mid-Atlantic
    But based on the findings posted thus far, can I rule out that I'm losing oil to combustion ? Or is that still a possibility ?
  5. May 5, 2016 at 9:08 PM
    #45
    windsor
    windsor Just a guy
    Homeless in Oregon
    Based on what you've said, I'd think oil is going somewhere else. However, not 100%. I won't say it isn't oil being burnt (you do have some fouling), but at the level of loss you mentioned, you should have smoke.
    Check pressure leakage again.
    Make sure oil is full. Check for leaks (pull skid pan off). If you have any oil on the motor, clean the motor, then drive it to get it up to operating temp. Once up to temp, give it a few good accelerations (in a safe and LEGAL manner) and check for smoke. Park the truck with a piece of cardboard under it (make sure it is under the truck from bumper to bell housing, wheel to wheel). That will help find leaks.
    foampile[OP] likes this.
  6. May 6, 2016 at 9:08 AM
    #46
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Guilty :anonymous:
  7. May 6, 2016 at 3:48 PM
    #47
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Aaaaaaaaaaaaand, he's back........... Anyway, I don't see how you could loose that much oil through a leak and not see it. And 3.5qts over 1500 miles and you'd have been out of oil real soon if you hadn't caught it. Now that you know, is this consumption steady? I would assume you're topping it off to the tune of about a 1/2qt a week. In for another epic thread.
